Part Number: TMDSEMU200-U
Other Parts Discussed in Thread: PGA900
Hello all,
I'm testing some things and I want to know if does possible do a firmware downgrade of XDS200.
If yes, where do I find the older releases?
Leonardo Trinta
Hello all,
Leonardo Trinta
Hello Ki,
Some version dated about 2015-2016.
I need to check if new versions may be causing problems to flash PGA900 OTP memory. I choose this because the reference documents are dated on this range.
Leonardo Trinta
You can try firmware version 1.0.0.6, which is fairly old, before 2016.
/cfs-file/__key/communityserver-discussions-components-files/908/xds200_5F00_firmware.zip
For instructions on how to manually update the firmware, see:
https://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_xds200.html#updating-the-firmware
ki
Hello Ki,
I managed to perform the update.
Thank you!
Leonardo Trinta
