Part Number: MSP-EXP432P401R
Other Parts Discussed in Thread: BOOSTXL-SHARP128
My MSP-EXP432P401R LaunchPad was working fine. Bought a BOOSTXL-SHARP128 boost pack and plugged it into the LP. Now when I try to download a successfully built program I get some combination of the following error messages.
CORTEX_M4_0: * WARNING *: The connected device is not MSP432P401R
CORTEX_M4_0: GEL Output: Memory Map Initialization Complete
CORTEX_M4_0: GEL Output: Halting Watchdog Timer
CORTEX_M4_0: Error initializing flash programming: Your XMS432P401R material is no longer supported. We recommend you moving to production-quality MSP432P401R/M silicon by ordering samples at www.ti.com/product/MSP432P401R.
CORTEX_M4_0: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
CORTEX_M4_0: File Loader: Verification failed: Values at address 0x00007FF0 do not match Please verify target memory and memory map.
CORTEX_M4_0: GEL: File: D:\Product\DIGS\Code\DC2\MCU2-432\432-uSD\fatsd_MSP_EXP432P401R_nortos_ccs\Debug\fatsd_MSP_EXP432P401R_nortos_ccs.out: a data verification error occurred, file load failed.
Tried this with and without a microSD memory card inserted, then unplugged the Boost pack, then tried a different PC and get the same errors. What's the story with this?
