Part Number: TM4C1294NCPDT
HI,
I want to store some variable data in to flash memory on TM4c1294 using TI -RTOS. please check my attached portion of code
TI RTOS v 2.16.01.14
GNU Compiler v 7.2.1 (Linaro)
Khodidas
/* * Copyright (c) 2014, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== tcpEcho.c ======== */ /* XDCtools Header files */ #include <xdc/std.h> #include <xdc/cfg/global.h> #include <ti/sysbios/hal/Hwi.h> #include <xdc/runtime/Error.h> #include <xdc/runtime/Memory.h> #include <xdc/runtime/System.h> /* BIOS Header files */ #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Clock.h> #include <ti/sysbios/knl/Task.h> /* NDK Header files */ #include <ti/ndk/inc/netmain.h> #include <ti/ndk/inc/_stack.h> /* TI-RTOS Header files */ #include <ti/drivers/GPIO.h> /* Example/Board Header files */ #include "Board.h" #include #include #include #include #include "inc/hw_types.h" #include "inc/hw_memmap.h" #include "driverlib/sysctl.h" #include "inc/hw_gpio.h" #include "driverlib/gpio.h" #include "inc/hw_ints.h" #include "driverlib/interrupt.h" #include "driverlib/timer.h" #include "driverlib/pin_map.h" //#include "driverlib/rom.h" //#include "driverlib/rom_map.h" #include "driverlib/udma.h" #include "inc/hw_udma.h" #include "inc/hw_adc.h" #include "driverlib/adc.h" #include "inc/hw_flash.h" #include "driverlib/flash.h" #define dma false #define FLASH_BASE_ADDR ((uint32_t*)0x00020000) #define SIZE_N 1000 #define SIZE_HN 500 //============================Ethernet ========================// #define TCPPACKETSIZE 1024 #define TCPPORT 8080 #define NUMTCPWORKERS 3 //============================ETHERNET INITS========================// uint32_t g_ui32SysClock; //============================================================// SOCKET lSocket; struct sockaddr_in sLocalAddr; char mydata[41]; //============================================================// //============================ADC INITS ========================// #define ADC_SAMPLE_BUF_SIZE (1) // uint32_t ui32Config, ui32ClockDiv; //for ADC Clock test uint32_t udmaCtrlTable[1024] __attribute__ ((aligned(1024))); uint32_t ADC_OUT_1[6],ADC_OUT_2[6]; uint8_t DIGI_IO; bool PSFLT,ARC,IDSLW,TEMP,MAIN_IN; // uint16_t RF_FORWARD,RF_REVERSE,TEMPERATURE,VDS,ID,VGS; //============================================================// uint16_t RF_FORWARD[SIZE_N],RF_REVERSE[SIZE_N],TEMPERATURE[SIZE_N],VDS[SIZE_N],ID[SIZE_N],VGS[SIZE_N]; uint8_t DIGI_BUFF[SIZE_N]; uint16_t flash_counter; bool LOCK=false; uint8_t counter=0; uint32_t gp_count; void gpioButtonFxn0(unsigned int index) { /* Clear the GPIO interrupt and toggle an LED */ ARC=1; gp_count++; //GPIO_toggle(Board_LED1); sprintf(mydata,"*D01$%lu,%lu,%lu,%lu,%lu,%lu,%d#",ADC_OUT_1[1],ADC_OUT_1[2],ADC_OUT_1[3],ADC_OUT_1[4],ADC_OUT_1[5],ADC_OUT_1[0],DIGI_IO); send(lSocket, (char *)mydata,sizeof(mydata), 0 ); //GPIO_clearInt(Board_BUTTON1); } void ADCSeq0Handler(void) { // Clear the Interrupt Flag. ADCIntClear(ADC0_BASE, 0); // uint32_t ui32Mode = uDMAChannelModeGet(UDMA_CHANNEL_ADC0); if( uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT) == 0) { // GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0x08); uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT,UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0), ADC_OUT_1,6); uDMAChannelEnable(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT); counter++; // GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0x00); } if( uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT) == 0) { // GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0x08); uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT, UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0),ADC_OUT_2,6); uDMAChannelEnable(UDMA_CHANNEL_ADC0|UDMA_ALT_SELECT); // GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0x00); } } void InitUDMA(void) { uDMAEnable(); // Enables uDMA uDMAControlBaseSet(udmaCtrlTable); //IntEnable(INT_UDMA); uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC0, UDMA_ATTR_ALL); // Configures the base address of the channel control table. Table resides in system memory and holds control // information for each uDMA channel. Table must be aligned on a 1024-byte boundary. Base address must be // configured before any of the channel functions can be used uDMAChannelAttributeEnable(UDMA_CHANNEL_ADC0, UDMA_ATTR_USEBURST ); uDMAChannelControlSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT, UDMA_SIZE_32 | UDMA_SRC_INC_NONE | UDMA_DST_INC_32 | UDMA_NEXT_USEBURST |UDMA_CHCTL_ARBSIZE_1); uDMAChannelControlSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT, UDMA_SIZE_32 | UDMA_SRC_INC_NONE | UDMA_DST_INC_32 | UDMA_NEXT_USEBURST |UDMA_CHCTL_ARBSIZE_1); uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT, UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0), ADC_OUT_1, 6); uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT, UDMA_MODE_PINGPONG,(void *)(ADC0_BASE + ADC_O_SSFIFO0),ADC_OUT_2,6); uDMAChannelEnable(UDMA_CHANNEL_ADC0); //uDMAChannelRequest(UDMA_CHANNEL_ADC0); #if dma ADCIntEnableEx(ADC0_BASE, ADC_INT_DMA_SS0); // Enables ADC interrupt source due to DMA on ADC sample sequence 0 // IntEnable(INT_ADC0SS0); ADCIntRegister(ADC0_BASE,0,ADCSeq0Handler); IntMasterEnable(); #endif } void InitConsole(void) { SysCtlPeripheralReset(SYSCTL_PERIPH_ADC0); SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); SysCtlPeripheralReset(SYSCTL_PERIPH_UDMA); SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3); //RF_FORWARD GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_2); //RF_REVERSE SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK); GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_0); //TEMPERATURE GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_1); //VDS GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_2); //ID GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_3); //VGS //ADCClockConfigSet(ADC0_BASE, ADC_CLOCK_SRC_PLL | ADC_CLOCK_RATE_FULL, 1); IntDisable(INT_ADC0SS0); ADCIntDisable(ADC0_BASE, 0); ADCSequenceDisable(ADC0_BASE, 0); #if dma ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_ALWAYS, 0); #else ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_PROCESSOR, 0); #endif ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH0); ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH1); ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH16); ADCSequenceStepConfigure(ADC0_BASE, 0, 3, ADC_CTL_CH17); ADCSequenceStepConfigure(ADC0_BASE, 0, 4, ADC_CTL_CH18); ADCSequenceStepConfigure(ADC0_BASE, 0, 5, ADC_CTL_CH19|ADC_CTL_END); ADCHardwareOversampleConfigure(ADC0_BASE, 64); ADCSequenceDMAEnable(ADC0_BASE, 0); ADCSequenceEnable(ADC0_BASE, 0); } void digital_init() { SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK); //PSFLT GPIOPinTypeGPIOInput(GPIO_PORTK_BASE, GPIO_PIN_4); GPIODirModeSet(GPIO_PORTK_BASE,GPIO_PIN_4,GPIO_DIR_MODE_IN); // GPIOPinTypeGPIOInput(GPIO_PORTK_BASE, GPIO_PIN_5); //ARC // GPIODirModeSet(GPIO_PORTK_BASE,GPIO_PIN_5,GPIO_DIR_MODE_IN); GPIOPinTypeGPIOInput(GPIO_PORTK_BASE, GPIO_PIN_6); //IDSLW GPIODirModeSet(GPIO_PORTK_BASE,GPIO_PIN_6,GPIO_DIR_MODE_IN); GPIOPinTypeGPIOInput(GPIO_PORTK_BASE, GPIO_PIN_7); //TEMP GPIODirModeSet(GPIO_PORTK_BASE,GPIO_PIN_7,GPIO_DIR_MODE_IN); HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY; HWREG(GPIO_PORTD_BASE + GPIO_O_CR) = 0x80; SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); //FROM MAIN GPIOPinTypeGPIOInput(GPIO_PORTD_BASE, GPIO_PIN_7); GPIODirModeSet(GPIO_PORTD_BASE,GPIO_PIN_7,GPIO_DIR_MODE_IN); GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE, GPIO_PIN_6); GPIOPadConfigSet(GPIO_PORTD_BASE,GPIO_PIN_6,GPIO_STRENGTH_10MA,GPIO_PIN_TYPE_STD_WPU ); GPIODirModeSet(GPIO_PORTD_BASE,GPIO_PIN_6,GPIO_DIR_MODE_OUT); GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_6, 0x02); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM); //INTERLOCK PIN GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_1); GPIOPadConfigSet(GPIO_PORTM_BASE,GPIO_PIN_1,GPIO_STRENGTH_10MA,GPIO_PIN_TYPE_STD_WPU ); GPIODirModeSet(GPIO_PORTM_BASE,GPIO_PIN_1,GPIO_DIR_MODE_OUT); GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1, 0x02); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH); // FOR LED GPIOPinTypeGPIOOutput(GPIO_PORTH_BASE, GPIO_PIN_3); GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0x0); } /* * ======== tcpHandler ======== * Creates new Task to handle new TCP connections. */ Void tcpHandler(UArg arg0, UArg arg1) { fdOpenSession(TaskSelf()); lSocket = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP); if (lSocket < 0) { // System_printf("tcpHandler: socket failed\n"); Task_exit(); return; } memset((char *)&sLocalAddr, 0, sizeof(sLocalAddr)); sLocalAddr.sin_family = AF_INET; //sLocalAddr.sin_addr.s_addr = inet_addr("192.168.0.135");//htonl(INADDR_ANY); sLocalAddr.sin_addr.s_addr = inet_addr("192.168.1.135");//htonl(INADDR_ANY); sLocalAddr.sin_port = htons(arg0); while(connect(lSocket, (struct sockaddr *)&sLocalAddr, sizeof(sLocalAddr)) < 0) { SysCtlDelay(400000); } // System_flush(); InitConsole(); InitUDMA(); while (true) { #if dma #else // GPIO_toggle(Board_LED0); ADCProcessorTrigger(ADC0_BASE, 0); // ADCSequenceDataGet(ADC0_BASE, 0, ADC_OUT_1); if(uDMAChannelModeGet(UDMA_CHANNEL_ADC0|UDMA_PRI_SELECT) == 0) { uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT,UDMA_MODE_BASIC,(void *)(ADC0_BASE + ADC_O_SSFIFO0), ADC_OUT_1,6); uDMAChannelEnable(UDMA_CHANNEL_ADC0); // uDMAChannelRequest(UDMA_CHANNEL_ADC0); counter++; } /*RF_FORWARD[flash_counter] = ADC_OUT_1[1]; RF_REVERSE[flash_counter] = ADC_OUT_1[2]; TEMPERATURE[flash_counter] = ADC_OUT_1[3]; VDS[flash_counter] = ADC_OUT_1[4]; ID[flash_counter] = ADC_OUT_1[5]; VGS[flash_counter] = ADC_OUT_1[0];*/ #endif memmove(&RF_FORWARD[0], &RF_FORWARD[1], (SIZE_N - 1) * sizeof(RF_FORWARD[0])); RF_FORWARD[SIZE_N - 1] = ADC_OUT_1[1]; memmove(&RF_REVERSE[0], &RF_REVERSE[1], (SIZE_N - 1) * sizeof(RF_REVERSE[0])); RF_REVERSE[SIZE_N - 1] = ADC_OUT_1[2]; memmove(&TEMPERATURE[0], &TEMPERATURE[1], (SIZE_N - 1) * sizeof(TEMPERATURE[0])); TEMPERATURE[SIZE_N - 1] = ADC_OUT_1[3]; memmove(&VDS[0], &VDS[1], (SIZE_N - 1) * sizeof(VDS[0])); VDS[SIZE_N - 1] = ADC_OUT_1[4]; memmove(&ID[0], &ID[1], (SIZE_N - 1) * sizeof(ID[0])); ID[SIZE_N - 1] = ADC_OUT_1[5]; memmove(&VGS[0], &VGS[1], (SIZE_N - 1) * sizeof(VGS[0])); VGS[SIZE_N - 1] = ADC_OUT_1[0]; PSFLT=GPIOPinRead(GPIO_PORTK_BASE,GPIO_PIN_4); //ARC=GPIOPinRead(GPIO_PORTK_BASE,GPIO_PIN_5); IDSLW=GPIOPinRead(GPIO_PORTK_BASE,GPIO_PIN_6); TEMP=GPIOPinRead(GPIO_PORTK_BASE,GPIO_PIN_7); MAIN_IN=GPIOPinRead(GPIO_PORTD_BASE,GPIO_PIN_7); DIGI_IO = (MAIN_IN << 0)+ (TEMP << 1) + (IDSLW << 2) + (ARC << 3) + (PSFLT << 4) ; memmove(&DIGI_BUFF[0], &DIGI_BUFF[1], (SIZE_N - 1) * sizeof(DIGI_BUFF[0])); DIGI_BUFF[SIZE_N - 1] = DIGI_IO; // RF_FORWARD= ADC_OUT_1[1]; //PE3 // RF_REVERSE= ADC_OUT_1[2]; //PE2 // TEMPERATURE=ADC_OUT_1[3]; //PK0 // VDS =ADC_OUT_1[4]; //PK1 // ID =ADC_OUT_1[5]; //PK2 // VGS =ADC_OUT_1[0]; //PK3 if (ADC_OUT_1[1] > 4102 || ADC_OUT_1[2] > 4102 || ADC_OUT_1[3] > 3026|| ADC_OUT_1[4] > 3791|| ADC_OUT_1[5] > 3351|| ADC_OUT_1[0] > 3103 ||ADC_OUT_1[4] < 3146|| ADC_OUT_1[5] < 3138|| ADC_OUT_1[0] < 2482 || DIGI_IO > 0) { // GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1, 0x02); LOCK =true; } // else // { // GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1, 0x00); // LOCK =false; // } if(LOCK) { GPIO_toggle(Board_LED1); flash_counter++; GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1, 0x02); uint32_t pui32Data[2],readdata[2]; if(flash_counter>=500) { pui32Data[0] = 0x00000008; pui32Data[1] = 0x56789def; FlashProgram(pui32Data, FLASH_BASE_ADDR, sizeof(pui32Data)); // FlashProgram(RF_FORWARD, FLASH_BASE_ADDR, sizeof(RF_FORWARD)); flash_counter=0; readdata[0]=FLASH_BASE_ADDR[0]; readdata[1]=FLASH_BASE_ADDR[1]; // while(1); } } if(counter>10) { GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_3, 0x08); counter=0; sprintf(mydata,"*D01$%lu,%lu,%lu,%lu,%lu,%lu,%d,%d,%d,%d,%d#",ADC_OUT_1[1],ADC_OUT_1[2],ADC_OUT_1[3],ADC_OUT_1[4],ADC_OUT_1[5],ADC_OUT_1[0],PSFLT,MAIN_IN,IDSLW,ARC,PSFLT); send(lSocket, (char *)mydata,sizeof(mydata), 0 ); } } } /* * ======== main ======== */ int main(void) { // Task_Handle taskHandle; // Task_Params taskParams; // Error_Block eb; g_ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |SYSCTL_CFG_VCO_480), 120000000); /* Call board init functions */ Board_initGeneral(); digital_init(); Board_initGPIO(); Board_initEMAC(); GPIO_setCallback(Board_BUTTON0, gpioButtonFxn0); /* Enable interrupts */ GPIO_enableInt(Board_BUTTON0); // ui32Config = ADCClockConfigGet(ADC0_BASE, &ui32ClockDiv); /* Start BIOS */ BIOS_start(); return (0); }
