Part Number: RM48L952
Other Parts Discussed in Thread: HALCOGEN
hi
I need to convert IAR to ccs is there any steps please suggest its helps me more.
thank you,
suguresh m
Hello Suguresh,
We don't have any documentation and tools for converting IAR project to CCS.
TI HALCoGen tool can generate driver and startup code for IAR IDE and CCS. You can use those two projects as references when converting your IAR project to CCS project.
hi wang its giving lots of errors and its giving gmake file error .
there is no solution for this?
thank you,
suguresh m
Hello Suguresh,
Do you mean that the HALCoGen generated files throw errors when compiling using IAR compiler?
I don't have IAR IDE to test. Did you select IAR tool in HALCoGen New Project GUI? The HALCoGen generated files for IAR were tested on IAR (old version) before.
hi wang i followed this pdf.
http://files.iar.com/docs/IAR_HALCoGen_Integration.pdf
thank you,
suguresh m
Did you try to compile your project on a old version IAR workbench? Please check IAR IDE user guide for configuring the project property.
