Part Number: MSP432P401R
how do I configure a button to change the period of the timer. Pressing the button once changes the Timer A toggle delay to 1 second. Pressing the button again changes the Timer A toggle delay to 2 seconds. Lastly, pressing the button a third time changes the Timer A toggle delay back to a half second delay. Additional button presses should cycle through this order. When the system is not toggling the light or handling button presses, it should be in low power mode.
I tried the below code but my loops don't work. It only blinks red. and doesn't toggle the rest of the timer LEDs
My code:-
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2013, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* MSP432 CODE EXAMPLE DISCLAIMER
* MSP432 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/.../mspdriverlib for an API functional
* library & https://dev.ti.com/pinmux/ for a GUI approach to peripheral configuration.
* --/COPYRIGHT--*/
// MSP432P401 Demo - Use TimerA in Low-Frequency mode with LPM0
// Description: Configure device to operate in Low-Frequency LPM0 with TimerA
// running and sourced by a low-frequency clock source. This examples builds
// up on msp432p401_pcm_05, which exercises the transition into LF active mode
// from active mode (LDO).
// Note: the code in this example assumes the device is currently in LDO mode
// AM0_LDO or AM1_LDO (Active Mode using LDO, VCore=0/1 respectively)
// Transition from DCDC mode to LF requires intermediate transition through
// LDO mode. For more information refer to the PCM chapter in the device user's
// guide.
// AM1_DCDC <-----> AM1_LDO <--@--> AM1_LF
// v
// AM0_DCDC <-----> AM0_LDO* <--@--> AM0_LF
// v
// LPM0_LF
// *: power state condition after reset
// @: transitions demonstrated in this code example
// MSP432P401x
// --|RST |
// | P1.0|--->LED
// William Goh
// Texas Instruments Inc.
// June 2016 (updated) | November 2013 (created)
// Built with CCSv6.1, IAR, Keil, GCC
#include "ti/devices/msp432p4xx/inc/msp.h"
#include <stdint.h>
void error(void);
int main(void)
uint32_t currentPowerState;
WDT_A->CTL = WDT_A_CTL_PW | // Stop WDT
WDT_A_CTL_HOLD;
// Terminate all remaining pins on the device
P1->DIR |= 0xFF; P1->OUT = 0;
P2->DIR |= 0xFF; P2->OUT = 0;
P3->DIR |= 0xFF; P3->OUT = 0;
P4->DIR |= 0xFF; P4->OUT = 0;
P5->DIR |= 0xFF; P5->OUT = 0;
P6->DIR |= 0xFF; P6->OUT = 0;
P7->DIR |= 0xFF; P7->OUT = 0;
P8->DIR |= 0xFF; P8->OUT = 0;
P9->DIR |= 0xFF; P9->OUT = 0;
P10->DIR |= 0xFF; P10->OUT = 0;
PJ->DIR |= 0xFF; PJ->OUT = 0;
CS->KEY = CS_KEY_VAL ; // Unlock CS module
// Switch MCLK, SMCLK, ACLK sources over to REFO clock for
// low frequency operation first
CS->CTL1 = CS_CTL1_SELM_2 |
CS_CTL1_SELS_2 |
CS_CTL1_SELA_2;
CS->KEY = 0; // Lock CS module
// Get current power state
currentPowerState = PCM->CTL0 & PCM_CTL0_CPM_MASK;
// Transition to Low-Frequency Mode from current LDO power state properly
switch (currentPowerState)
case PCM_CTL0_CPM_0: // AM0_LDO, need to switch to AM0_Low-Frequency Mode
while ((PCM->CTL1 & PCM_CTL1_PMR_BUSY));
PCM->CTL0 = PCM_CTL0_KEY_VAL | PCM_CTL0_AMR_8;
if (PCM->IFG & PCM_IFG_AM_INVALID_TR_IFG)
error(); // Error if transition was not successful
break;
case PCM_CTL0_CPM_1: // AM1_LDO, need to switch to AM1_Low-Frequency Mode
PCM->CTL0 = PCM_CTL0_KEY_VAL | PCM_CTL0_AMR_9;
break;
case PCM_CTL0_CPM_8: // Device is already in AM0_Low-Frequency Mode
break;
case PCM_CTL0_CPM_9: // Device is already in AM1_Low-Frequency Mode
break;
default: // Device is in some other state, which is unexpected
error();
// Configure TimerA to run off SMCLK = REFO
TIMER_A0->CCTL[0] = TIMER_A_CCTLN_CCIE; // Enable capture compare interrupt
TIMER_A0->CCR[0] = 1000;
TIMER_A0->CTL = TIMER_A_CTL_SSEL__SMCLK | // SMCLK
TIMER_A_CTL_MC__CONTINUOUS; // continuous mode
// Enable TimerA3_CC0 interrupt on the NVIC
NVIC->ISER[0] = 1 << ((TA0_0_IRQn) & 31);
// Enable global interrupt
__enable_irq();
SCB->SCR |= SCB_SCR_SLEEPONEXIT_Msk; // Do not wake up on exit from ISR
// Ensures the SLEEPONEXIT mask is set.
__DSB();
// Go to LPM3
PCM_gotoLPM3();
// TimerA3_0 interrupt service routine handler
void TA0_0_IRQHandler(void)
int counter = 0;
if((P1IN & 0x02) == 0)
if(counter==0)
P2->OUT ^= BIT1; // Toggle P1.0 LED
TIMER_A0->CCTL[0] &= ~ TIMER_A_CCTLN_CCIFG;
TIMER_A0->CCR[0] +=256000;
counter=1;
else if(counter==1)
P2->OUT ^= BIT2; // Toggle P1.0 LED
TIMER_A0->CCR[0] +=128000;
counter=2;
else if(counter==2)
P2->OUT ^= BIT3; // Toggle P1.0 LED
TIMER_A0->CCR[0] +=64000;
counter=0;
void error(void)
volatile uint32_t i;
while (1)
P2->OUT ^= BIT1;
for(i = 0; i < 20000; i++); // Blink LED forever
