I'm having a problem with Flash28335_API_V210.lib. Occasionally the call to Flash_Erase does not return. The toggle test shows the API is configured for 9.998KHZ, I'm trying to erase sectors A-F (0x3f), interrupts are turned off and watch dog is turned off. I have not tried debugging in to the API yet. Code snippet is below wSectors is 0x3f.
// disable interupts
unsigned int local = _disable_interrupts();
// status registers
FLASH_ST FlashStatus;
wError = Flash_Erase(wSectors,&FlashStatus);
// re-enable interupts
_restore_interrupts(local);
Any suggestions would be greatly appreciated.
