TMDSECATCNCD379D: Dual DSP incorrect variable read (cpu01 to cpu02)
Part Number: TMDSECATCNCD379D
I am using the example below. I did not make any changes in this example.
C:\ti\c2000\C2000Ware_3_04_00_00\device_support\f2837xd\examples\dual\cpu01_to_cpu02_ipcdrivers
The value (0x1234 Hex) I want to write from cpu 01 to CPU 02 looks wrong in cpu 02 (0x5A10 Hex). The variable usWWord16 must be equal to the variable usRWord16.
I couldn't solve it with the following Ti E2E thread. :(
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1004610/tmdsecatcncd379d-dsp-dual-cpu-usage/3751225?tisearch=e2e-sitesearch&keymatch=%20user%3A487101#3751225
Sinan,
Thanks and best regards.
  • Sinan,
    We have gone through this in detail last time.
    If the simpler use case, may be you should use lite version of driver. I have removed the extra code, and with this you should see what you are asking.
    Here is my modified project.ipclite.zip
  • Hi, Santosh:
    I hope you're good.
    Thank you very much for your feedbacks. I am thankful to you.
    There are no files in the project you sent. Can you send it again?
    Sinan,
    Very thanks.
  • Hi Sinan,
    Actually it was linked file, so it did not include the .c file in the zip file.
    Just replace this file and try again.
    // FILE:   cpu01_to_cpu02_ipcdrivers_lite_cpu01.c
    // TITLE:  CPU01 to CPU02 IPC Drivers (CPU01) Example
    //! \addtogroup dual_example_list
    //! <h1> CPU01 to CPU02 IPC Lite Drivers (cpu01_to_cpu2_ipcdrivers_lite)</h1>
    //! This example application demonstrates the use of the CPU01 to CPU02
    //! IPC Lite Driver Functions which allow the CPU01 to read/write to
    //! addresses on the CPU02. CPU02 to CPU01  MSG RAM is used to pass the
    //! addresses of local variables between the processors.
    //! \b Watch \b Variables on CPU01: \n
    //!   - ErrorCount - Counts # of errors
    //!   - usWWord16  - 16-bit word to write to CPU02
    //!   - ulWWord32  - 32-bit word to write to CPU02
    //!   - usRWord16  - 16-bit word to read from CPU02
    //!   - ulRWord32  - 32-bit word to read from CPU02
    //! \b Watch \b Variables on CPU02: \n
    //!  - ErrorFlag - Indicates an unrecognized command was sent from CPU01
    //!                to CPU02.
    // $TI Release: F2837xD Support Library v3.12.00.00 $
    // $Release Date: Fri Feb 12 19:03:23 IST 2021 $
    // $Copyright:
    // Copyright (C) 2013-2021 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    //   Redistributions of source code must retain the above copyright
    //   notice, this list of conditions and the following disclaimer.
    //   Redistributions in binary form must reproduce the above copyright
    //   notice, this list of conditions and the following disclaimer in the
    //   documentation and/or other materials provided with the
    //   distribution.
    //   Neither the name of Texas Instruments Incorporated nor the names of
    //   its contributors may be used to endorse or promote products derived
    //   from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Included Files
    #include "F28x_Project.h"
    #include "F2837xD_Ipc_drivers.h"
    // Defines
    #define CPU02_TO_CPU01_PASSMSG   0x0003FBF4    // CPU02 TO CPU01 MSG RAM
                                                   // offsets for passing addresses
    #define SETMASK_16BIT            0xFF00        // Mask for setting bits of
                                                   // 16-bit word
    #define CLEARMASK_16BIT          0xA5A5        // Mask for clearing bits of
                                                   // 16-bit word
    #define SETMASK_32BIT            0xFFFF0000    // Mask for setting bits of
                                                   // 32-bit word
    #define CLEARMASK_32BIT          0xA5A5A5A5    // Mask for clearing bits of
                                                   // 32-bit word
    // Globals
    uint16_t ErrorFlag;
    // Main
    void
    main(void)
        uint16_t ErrorCount = 0;
        uint16_t usWWord16;
        uint32_t ulWWord32;
        uint16_t usRWord16;
        uint32_t ulRWord32;
        uint32_t *pulMsgRam;
    // Step 1. Initialize System Control:
    // PLL, WatchDog, enable Peripheral Clocks
    // This example function is found in the F2837xD_SysCtrl.c file.
        InitSysCtrl();
    // Step 2. Initialize GPIO:
    // InitGpio();  // Skipped for this example
    // Step 3. Clear all interrupts and initialize PIE vector table:
    // Disable CPU interrupts
        DINT;
    // Initialize PIE control registers to their default state.
    // The default state is all PIE interrupts disabled and flags
    // are cleared.
    // This function is found in the F2837xD_PieCtrl.c file.
        InitPieCtrl();
    #ifdef _STANDALONE
    #ifdef _FLASH
        //  Send boot command to allow the CPU02 application to begin execution
        IPCBootCPU2(C1C2_BROM_BOOTMODE_BOOT_FROM_FLASH);
    #else
        IPCBootCPU2(C1C2_BROM_BOOTMODE_BOOT_FROM_RAM);
    #endif
    #endif
    // Initialize all variables used in example.
        ErrorFlag = 0;
        usWWord16 = 0x1234;
        ulWWord32 = 0xABCD5678;
        usRWord16 = 0;
        ulRWord32 = 0;
        pulMsgRam = (void *)CPU02_TO_CPU01_PASSMSG;
    // Spin here until CPU02 is ready
        while(!IPCRtoLFlagBusy(IPC_FLAG17));
        IPCRtoLFlagAcknowledge(IPC_FLAG17);
    // 16 and 32-bit Data Writes
    // Write 16-bit word to CPU02 16-bit write word variable.
        IPCLiteLtoRDataWrite(IPC_FLAG0, pulMsgRam[0],(uint32_t)usWWord16,
                             IPC_LENGTH_16_BITS,
                             IPC_FLAG31);
    // Optionally Get result of the Write (i.e. read word that was written at
    // address) without
    // performing a separate read command. IPCLiteLtoRGetResult() will return
    // STATUS_FAIL if
    // the CPU02 did not recognize the command being sent, and therefore did not
    // process the
    // command. Otherwise it will return STATUS_PASS and the appropriate read
    // value.
        while(IPCLiteLtoRGetResult(&usRWord16,IPC_LENGTH_16_BITS,
                                   IPC_FLAG31) != STATUS_PASS)
        if(usWWord16 != usRWord16)
            ErrorCount++;
        usRWord16 = 0;
    // OR Read 16-bit word from CPU02 16-bit write word variable. Use IPC Flag 32
    // to check status of command.
    // Notice that the command function is in a while-loop. All command
    // functions will return STATUS_FAIL if
    // the IPC interrupt ulFlag is still busy, and subsequently, will not send
    // the command to the CPU02.  If
    // the IPC interrupt ulFlag is available, the command will be sent, and the
    // function will return STATUS_PASS.
        while(IPCLiteLtoRDataRead(IPC_FLAG0, pulMsgRam[0], IPC_LENGTH_16_BITS,
    // Result of Read will be read into usRWord16 variable.
            ErrorCount++;
    // Write 32-bit word to CPU02 32-bit write word variable.
        while(IPCLiteLtoRDataWrite(IPC_FLAG0, pulMsgRam[1],ulWWord32,
                                   IPC_LENGTH_32_BITS,  IPC_FLAG31) != STATUS_PASS)
    // address) without
        while(IPCLiteLtoRGetResult(&ulRWord32,IPC_LENGTH_32_BITS,
        if(ulWWord32 != ulRWord32)
            ErrorCount++;
        ulRWord32 = 0;
        IPCLiteLtoRDataRead(IPC_FLAG0, pulMsgRam[1], IPC_LENGTH_32_BITS,
                            IPC_FLAG31);
    // Result of Read will be read into ulRWord32 variable.
            ErrorCount++;
        for(;;)
            //infinite loop
    // End of file
  • Hi, Santosh:
    My problem is solved. I am thankful to you.
    Sinan,
  • Sinan,
    I am glad your issue is resolved.
