TMDSCNCD28379D: TMDXCNCD28379D uses an external oscillator ?
Part Number: TMDSCNCD28379D
The question is for TMDXCNCD28379D but it did not recognize this new part number in Part Number tab.
TMDXCNCD28379D uses an external oscillator but its value is not mentioned, below link talks about TMDSCNCD28379D so is it applicable for TMDXCNCD28379D
TMS320F28379D: Does the TI evaluation control card has an External Oscillator? - C2000 microcontrollers forum - C2000Tm︎ microcontrollers - TI E2E support forums
also what is the difference between TMDXCNCD28379D & TMDSCNCD28379D.
  • TMDXCNCD28379D uses an external oscillator but its value is not mentioned, below link talks about TMDSCNCD28379D so is it applicable for TMDXCNCD28379D
    Yes, it is applicable. Please refer to the design files given in the C2000ware folder.
    <C2000ware>\boards\controlCARDs\TMDSCNCD28379D
    The TMDX version should be an earlier version of the TMDS version.
    To answer your main question, revision 1.3 of the board uses a 20MHz crystal as the main MCU clock. Check the revision number marked on your board.
