Part Number: TMS320F28075
Versions:
XDCtools - 3.61.2.27
SYS/BIOS - 6.83.0.18
Compiler - 20.12.0.STS
CCS - 10.4.0.00006
When I attempt to build the benchmark example, it fails to compile.
I was looking at this example because I would like to use pthreads in another project. When I attempt to link in the pthreads in the other project, I am getting similar build errors.
**** Clean-only build of configuration Debug for project benchmark **** "C:\\ti\\ccs1040\\ccs\\utils\\bin\\gmake" -k -j 12 clean -O cleaning ../src/sysbios ... DEL /F "benchmark.hex" "configPkg\linker.cmd" "configPkg\compiler.opt" "benchmark.out" DEL /F "benchloop.obj" DEL /F "benchloop.d" RMDIR /S/Q "configPkg\" Could Not Find C:\Work\Test\workspace\benchmark\Debug\benchmark.hex Could Not Find C:\Work\Test\workspace\benchmark\Debug\benchmark.out Could Not Find C:\Work\Test\workspace\benchmark\Debug\benchloop.obj Could Not Find C:\Work\Test\workspace\benchmark\Debug\benchloop.d Finished clean **** Build Finished **** **** Build of configuration Debug for project benchmark **** "C:\\ti\\ccs1040\\ccs\\utils\\bin\\gmake" -k -j 12 all -O Building file: "../benchloop.cfg" Invoking: XDCtools "C:/ti/ccs1040/xdctools_3_61_02_27_core_win32/xdctools_3_61_02_27_core/xs" --xdcpath="C:/ti/bios_6_83_00_18/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C28_float -p ti.platforms.tms320x28:TMS320F28075 -r release -c "C:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.12.0.STS" --compileOptions "-g" "../benchloop.cfg" making package.mak (because of package.bld) ... generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ... configuring benchloop.xe28FP from package/cfg/benchloop_pe28FP.cfg ... -v28 -DLARGE_MODEL=1 -ml --float_support=fpu32 --diag_suppress=3195 --abi=eabi -q -mo --program_level_compile -o3 generating custom ti.sysbios library makefile ... Starting build of library sources ... making C:/Work/Test/workspace/benchmark/src/sysbios/sysbios.ae28FP ... cle28FP C:/ti/bios_6_83_00_18/packages/ti/sysbios/BIOS.c ... >> Compilation failure Build of libraries failed. subdir_rules.mk:19: recipe for target 'build-616432575-inproc' failed "C:/ti/bios_6_83_00_18/packages/ti/posix/ccs/time.h", line 103: error: "timespec" has already been declared in the current scope "C:/ti/bios_6_83_00_18/packages/ti/posix/ccs/time.h", line 108: error: "itimerspec" has already been declared in the current scope 2 errors detected in the compilation of "C:/ti/bios_6_83_00_18/packages/ti/posix/tirtos/clock.c". gmake[1]: *** [makefile:61: BIOS.obj] Error 1 gmake: *** [C:/Work/Test/workspace/benchmark/src/makefile.libs:57: C:/Work/Test/workspace/benchmark/src/sysbios/sysbios.ae28FP] Error 2 error: xdc.cfg.SourceDir: "C:/ti/ccs1040/xdctools_3_61_02_27_core_win32/xdctools_3_61_02_27_core/packages/xdc/cfg/SourceDir.xs", line 209: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2: js: "C:/ti/ccs1040/xdctools_3_61_02_27_core_win32/xdctools_3_61_02_27_core/packages/xdc/cfg/Main.xs", line 160: Error: Configuration failed! gmake.exe: *** [package.mak:206: package/cfg/benchloop_pe28FP.xdl] Error 1 gmake.exe: *** Deleting file 'package/cfg/benchloop_pe28FP.xdl' gmake.exe: *** [package/cfg/benchloop_pe28FP.xdl] Deleting file 'package/cfg/benchloop_pe28FP.h' gmake.exe: *** [package/cfg/benchloop_pe28FP.xdl] Deleting file 'package/cfg/benchloop_pe28FP.c' js: "C:/ti/ccs1040/xdctools_3_61_02_27_core_win32/xdctools_3_61_02_27_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. gmake[1]: *** [build-616432575-inproc] Error 1 gmake: *** No rule to make target 'build-616432575', needed by 'configPkg/compiler.opt'. gmake: *** No rule to make target 'build-616432575', needed by 'configPkg/linker.cmd'. gmake: Target 'all' not remade because of errors. **** Build Finished ****
