TMS320F28379D: Program_error using SCI boot - where to look
Part Number: TMS320F28379D
Other Parts Discussed in Thread: C2000WARE,
I've got the Serial Flash Programmer utility in the C2000ware to load it's example txt files and using TI generated blinky and kernel files.  I'm trying to load my own project now and getting this issue.  Should I look to the cmd file to fix this issue?  Or is there a different file I can locate the issue in such as one of my c files or another file type.
  • Philip,
    Looks like you are mapping something to RAM in your linker cmd file.
    Flash kernels are made to load or program RAM.
    Please use flash based linker cmd file where all the code sections and initialized data sections are mapped to flash.
    Uninitialized data sections (like stack) are assigned to RAM.
    Thanks and regards,
    Vamsi
  • I'm using a standard TI cmd file.  I can't seem to locate where it loads into RAM as you are saying.  I'm posting the TI cmd file text below.
    MEMORY
    PAGE 0: /* Program Memory */
    PAGE 1: /* Data Memory */
    ADCA_RESULT : origin = 0x000B00, length = 0x000020
    ADCB_RESULT : origin = 0x000B20, length = 0x000020
    ADCC_RESULT : origin = 0x000B40, length = 0x000020
    ADCD_RESULT : origin = 0x000B60, length = 0x000020
    ADCA : origin = 0x007400, length = 0x000080
    ADCB : origin = 0x007480, length = 0x000080
    ADCC : origin = 0x007500, length = 0x000080
    ADCD : origin = 0x007580, length = 0x000080
    ANALOG_SUBSYS : origin = 0x05D180, length = 0x000080
    CANA : origin = 0x048000, length = 0x000800
    CANB : origin = 0x04A000, length = 0x000800
    CLA1 : origin = 0x001400, length = 0x000040 /* CLA registers */
    CLB_XBAR : origin = 0x007A40, length = 0x000040
    CMPSS1 : origin = 0x005C80, length = 0x000020
    CMPSS2 : origin = 0x005CA0, length = 0x000020
    CMPSS3 : origin = 0x005CC0, length = 0x000020
    CMPSS4 : origin = 0x005CE0, length = 0x000020
    CMPSS5 : origin = 0x005D00, length = 0x000020
    CMPSS6 : origin = 0x005D20, length = 0x000020
    CMPSS7 : origin = 0x005D40, length = 0x000020
    CMPSS8 : origin = 0x005D60, length = 0x000020
    CPU_TIMER0 : origin = 0x000C00, length = 0x000008 /* CPU Timer0 registers */
    CPU_TIMER1 : origin = 0x000C08, length = 0x000008 /* CPU Timer1 registers */
    CPU_TIMER2 : origin = 0x000C10, length = 0x000008 /* CPU Timer2 registers */
    DACA : origin = 0x005C00, length = 0x000010
    DACB : origin = 0x005C10, length = 0x000010
    DACC : origin = 0x005C20, length = 0x000010
    DMA : origin = 0x001000, length = 0x000200
    DMACLASRCSEL : origin = 0x007980, length = 0x000040
    ECAP1 : origin = 0x005000, length = 0x000020 /* Enhanced Capture 1 registers */
    ECAP2 : origin = 0x005020, length = 0x000020 /* Enhanced Capture 2 registers */
    ECAP3 : origin = 0x005040, length = 0x000020 /* Enhanced Capture 3 registers */
    ECAP4 : origin = 0x005060, length = 0x000020 /* Enhanced Capture 4 registers */
    ECAP5 : origin = 0x005080, length = 0x000020 /* Enhanced Capture 5 registers */
    ECAP6 : origin = 0x0050A0, length = 0x000020 /* Enhanced Capture 6 registers */
    EMIF1 : origin = 0x047000, length = 0x000800
    EMIF2 : origin = 0x047800, length = 0x000800
    EQEP1 : origin = 0x005100, length = 0x000040 /* Enhanced QEP 1 registers */
    EQEP2 : origin = 0x005140, length = 0x000040 /* Enhanced QEP 2 registers */
    EQEP3 : origin = 0x005180, length = 0x000040 /* Enhanced QEP 3 registers */
    EPWM1 : origin = 0x004000, length = 0x000100 /* Enhanced PWM 1 registers */
    EPWM2 : origin = 0x004100, length = 0x000100 /* Enhanced PWM 2 registers */
    EPWM3 : origin = 0x004200, length = 0x000100 /* Enhanced PWM 3 registers */
    EPWM4 : origin = 0x004300, length = 0x000100 /* Enhanced PWM 4 registers */
    EPWM5 : origin = 0x004400, length = 0x000100 /* Enhanced PWM 5 registers */
    EPWM6 : origin = 0x004500, length = 0x000100 /* Enhanced PWM 6 registers */
    EPWM7 : origin = 0x004600, length = 0x000100 /* Enhanced PWM 7 registers */
    EPWM8 : origin = 0x004700, length = 0x000100 /* Enhanced PWM 8 registers */
    EPWM9 : origin = 0x004800, length = 0x000100 /* Enhanced PWM 9 registers */
    EPWM10 : origin = 0x004900, length = 0x000100 /* Enhanced PWM 10 registers */
    EPWM11 : origin = 0x004A00, length = 0x000100 /* Enhanced PWM 11 registers */
    EPWM12 : origin = 0x004B00, length = 0x000100 /* Enhanced PWM 12 registers */
    EPWM_XBAR : origin = 0x007A00, length = 0x000040
    FLASH0_CTRL : origin = 0x05F800, length = 0x000300
    FLASH0_ECC : origin = 0x05FB00, length = 0x000040
    GPIOCTRL : origin = 0x007C00, length = 0x000180 /* GPIO control registers */
    GPIODAT : origin = 0x007F00, length = 0x000030 /* GPIO data registers */
    OUTPUT_XBAR : origin = 0x007A80, length = 0x000040
    I2CA : origin = 0x007300, length = 0x000040 /* I2C-A registers */
    I2CB : origin = 0x007340, length = 0x000040 /* I2C-B registers */
    IPC : origin = 0x050000, length = 0x000024
    FLASHPUMPSEMAPHORE : origin = 0x050024, length = 0x000002
    ROMPREFETCH : origin = 0x05E608, length = 0x000002
    MEMCFG : origin = 0x05F400, length = 0x000080 /* Mem Config registers */
    EMIF1CONFIG : origin = 0x05F480, length = 0x000020 /* Emif-1 Config registers */
    EMIF2CONFIG : origin = 0x05F4A0, length = 0x000020 /* Emif-2 Config registers */
    ACCESSPROTECTION : origin = 0x05F4C0, length = 0x000040 /* Access Protection registers */
    MEMORYERROR : origin = 0x05F500, length = 0x000040 /* Access Protection registers */
    ROMWAITSTATE : origin = 0x05F540, length = 0x000002 /* ROM Config registers */
    MCBSPA : origin = 0x006000, length = 0x000040 /* McBSP-A registers */
    MCBSPB : origin = 0x006040, length = 0x000040 /* McBSP-A registers */
    NMIINTRUPT : origin = 0x007060, length = 0x000010 /* NMI Watchdog Interrupt Registers */
    PIE_CTRL : origin = 0x000CE0, length = 0x000020 /* PIE control registers */
    PIE_VECT : origin = 0x000D00, length = 0x000200 /* PIE Vector Table */
    SCIA : origin = 0x007200, length = 0x000010 /* SCI-A registers */
    SCIB : origin = 0x007210, length = 0x000010 /* SCI-B registers */
    SCIC : origin = 0x007220, length = 0x000010 /* SCI-C registers */
    SCID : origin = 0x007230, length = 0x000010 /* SCI-D registers */
    SDFM1 : origin = 0x005E00, length = 0x000080 /* Sigma delta 1 registers */
    SDFM2 : origin = 0x005E80, length = 0x000080 /* Sigma delta 2 registers */
    SPIA : origin = 0x006100, length = 0x000010
    SPIB : origin = 0x006110, length = 0x000010
    SPIC : origin = 0x006120, length = 0x000010
    SPID : origin = 0x006130, length = 0x000010
    UPP : origin = 0x006200, length = 0x000100 /* uPP registers */
    DEV_CFG : origin = 0x05D000, length = 0x000180
    CLK_CFG : origin = 0x05D200, length = 0x000100
    CPU_SYS : origin = 0x05D300, length = 0x000100
    INPUT_XBAR : origin = 0x007900, length = 0x000020
    XBAR : origin = 0x007920, length = 0x000020
    SYNC_SOC : origin = 0x007940, length = 0x000010
    WD : origin = 0x007000, length = 0x000040
    XINT : origin = 0x007070, length = 0x000010
    DCSM_Z1 : origin = 0x05F000, length = 0x000030 /* Zone 1 Dual code security module registers */
    DCSM_Z2 : origin = 0x05F040, length = 0x000030 /* Zone 2 Dual code security module registers */
    DCSM_COMMON : origin = 0x05F070, length = 0x000010 /* Common Dual code security module registers */
    DCSM_Z1_OTP : origin = 0x078000, length = 0x000020 /* Part of Z1 OTP. LinkPointer/JTAG lock/ Boot Mode */
    DCSM_Z2_OTP : origin = 0x078200, length = 0x000020 /* Part of Z2 OTP. LinkPointer/JTAG lock */
    SECTIONS
    /*** PIE Vect Table and Boot ROM Variables Structures ***/
    UNION run = PIE_VECT, PAGE = 1
    PieVectTableFile
    GROUP
    EmuBModeVar
    EmuBootPinsVar
    AdcaResultFile : > ADCA_RESULT, PAGE = 1
    AdcbResultFile : > ADCB_RESULT, PAGE = 1
    AdccResultFile : > ADCC_RESULT, PAGE = 1
    AdcdResultFile : > ADCD_RESULT, PAGE = 1
    AdcaRegsFile : > ADCA, PAGE = 1
    AdcbRegsFile : > ADCB, PAGE = 1
    AdccRegsFile : > ADCC, PAGE = 1
    AdcdRegsFile : > ADCD, PAGE = 1
    AnalogSubsysRegsFile : > ANALOG_SUBSYS, PAGE = 1
    CanaRegsFile : > CANA, PAGE = 1
    CanbRegsFile : > CANB, PAGE = 1
    Cla1RegsFile : > CLA1, PAGE = 1
    Cla1SoftIntRegsFile : > PIE_CTRL, PAGE = 1, type=DSECT
    ClbXbarRegsFile : > CLB_XBAR PAGE = 1
    Cmpss1RegsFile : > CMPSS1, PAGE = 1
    Cmpss2RegsFile : > CMPSS2, PAGE = 1
    Cmpss3RegsFile : > CMPSS3, PAGE = 1
    Cmpss4RegsFile : > CMPSS4, PAGE = 1
    Cmpss5RegsFile : > CMPSS5, PAGE = 1
    Cmpss6RegsFile : > CMPSS6, PAGE = 1
    Cmpss7RegsFile : > CMPSS7, PAGE = 1
    Cmpss8RegsFile : > CMPSS8, PAGE = 1
    CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1
    CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1
    CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1
    DacaRegsFile : > DACA PAGE = 1
    DacbRegsFile : > DACB PAGE = 1
    DaccRegsFile : > DACC PAGE = 1
    DcsmZ1RegsFile : > DCSM_Z1, PAGE = 1
    DcsmZ2RegsFile : > DCSM_Z2, PAGE = 1
    DcsmCommonRegsFile : > DCSM_COMMON, PAGE = 1
    /*** Warning: Only remove "Type = NOLOAD" to program OTP Locations ***/
    DcsmZ1OtpFile : > DCSM_Z1_OTP, PAGE = 1, type = NOLOAD
    DcsmZ2OtpFile : > DCSM_Z2_OTP, PAGE = 1, type = NOLOAD
    DmaRegsFile : > DMA PAGE = 1
    DmaClaSrcSelRegsFile : > DMACLASRCSEL PAGE = 1
    ECap1RegsFile : > ECAP1, PAGE = 1
    ECap2RegsFile : > ECAP2, PAGE = 1
    ECap3RegsFile : > ECAP3, PAGE = 1
    ECap4RegsFile : > ECAP4, PAGE = 1
    ECap5RegsFile : > ECAP5, PAGE = 1
    ECap6RegsFile : > ECAP6, PAGE = 1
    Emif1RegsFile : > EMIF1 PAGE = 1
    Emif2RegsFile : > EMIF2 PAGE = 1
    EPwm1RegsFile : > EPWM1, PAGE = 1
    EPwm2RegsFile : > EPWM2, PAGE = 1
    EPwm3RegsFile : > EPWM3, PAGE = 1
    EPwm4RegsFile : > EPWM4, PAGE = 1
    EPwm5RegsFile : > EPWM5, PAGE = 1
    EPwm6RegsFile : > EPWM6, PAGE = 1
    EPwm7RegsFile : > EPWM7, PAGE = 1
    EPwm8RegsFile : > EPWM8, PAGE = 1
    EPwm9RegsFile : > EPWM9, PAGE = 1
    EPwm10RegsFile : > EPWM10, PAGE = 1
    EPwm11RegsFile : > EPWM11, PAGE = 1
    EPwm12RegsFile : > EPWM12, PAGE = 1
    EPwmXbarRegsFile : > EPWM_XBAR PAGE = 1
    EQep1RegsFile : > EQEP1, PAGE = 1
    EQep2RegsFile : > EQEP2, PAGE = 1
    EQep3RegsFile : > EQEP3, PAGE = 1
    Flash0CtrlRegsFile : > FLASH0_CTRL PAGE = 1
    Flash0EccRegsFile : > FLASH0_ECC PAGE = 1
    GpioCtrlRegsFile : > GPIOCTRL, PAGE = 1
    GpioDataRegsFile : > GPIODAT, PAGE = 1
    OutputXbarRegsFile : > OUTPUT_XBAR PAGE = 1
    I2caRegsFile : > I2CA, PAGE = 1
    I2cbRegsFile : > I2CB, PAGE = 1
    InputXbarRegsFile : > INPUT_XBAR PAGE = 1
    XbarRegsFile : > XBAR PAGE = 1
    IpcRegsFile : > IPC, PAGE = 1
    FlashPumpSemaphoreRegsFile : > FLASHPUMPSEMAPHORE, PAGE = 1
    RomPrefetchRegsFile : > ROMPREFETCH, PAGE = 1
    MemCfgRegsFile : > MEMCFG, PAGE = 1
    Emif1ConfigRegsFile : > EMIF1CONFIG, PAGE = 1
    Emif2ConfigRegsFile : > EMIF2CONFIG, PAGE = 1
    AccessProtectionRegsFile : > ACCESSPROTECTION, PAGE = 1
    MemoryErrorRegsFile : > MEMORYERROR, PAGE = 1
    RomWaitStateRegsFile : > ROMWAITSTATE, PAGE = 1
    McbspaRegsFile : > MCBSPA, PAGE = 1
    McbspbRegsFile : > MCBSPB, PAGE = 1
    UppRegsFile : > UPP, PAGE = 1
    NmiIntruptRegsFile : > NMIINTRUPT, PAGE = 1
    PieCtrlRegsFile : > PIE_CTRL, PAGE = 1
    SciaRegsFile : > SCIA, PAGE = 1
    ScibRegsFile : > SCIB, PAGE = 1
    ScicRegsFile : > SCIC, PAGE = 1
    ScidRegsFile : > SCID, PAGE = 1
    Sdfm1RegsFile : > SDFM1, PAGE = 1
    Sdfm2RegsFile : > SDFM2, PAGE = 1
    SpiaRegsFile : > SPIA, PAGE = 1
    SpibRegsFile : > SPIB, PAGE = 1
    SpicRegsFile : > SPIC, PAGE = 1
    SpidRegsFile : > SPID, PAGE = 1
    DevCfgRegsFile : > DEV_CFG, PAGE = 1
    ClkCfgRegsFile : > CLK_CFG, PAGE = 1
    CpuSysRegsFile : > CPU_SYS, PAGE = 1
    SyncSocRegsFile : > SYNC_SOC, PAGE = 1
    WdRegsFile : > WD, PAGE = 1
    XintRegsFile : > XINT PAGE = 1
    MemCfgRegs : > MEMCFG PAGE = 1
    // End of file.
  • If my project appears to use multiple cmd files, would a second cmd file cause the issue?  I'm new to this sort of programming
  • Philip,
    What you posted is for the register mapping (F2837xD_Headers_nonBIOS_cpu1.cmd).  That is default - no changes should be done in that.
    There should be another cmd file.  That maps different sections to memories.  This has two flavors:
    • Flash linker cmd - one maps all code/initialized-data to flash.
    • RAM linker cmd - Maps everything to RAM.
    Take a look here: C2000Ware_3_04_00_00\device_support\f2837xd\common\cmd
    You can start with 2837xD_FLASH_lnk_cpu1.cmd - This is the basic generic flash linker cmd file.
    Thanks and regards,
    Vamsi
  • Maybe this is what you mean?  I'm still unfamiliar with was sections would be mapping to flash and to ram.  Can't all the titles in this cmd file be made up?  How can I determine which addresses are RAM and which are FLASH memory sectors?
    * Devices: TMS320F28379D
    * Author: Modifed from Texas Instruments Files
    MEMORY
       BEGIN_M0            : origin = 0x000000, length = 0x000002     /* Part of M0 RAM - used for "Boot to M0" bootloader mode */
       RAMLS3              : origin = 0x009000, length = 0x001800     /* L3 RAM, DCSM secure, CLA Data RAM */
       //RAMLS4              : origin = 0x00A000, length = 0x000800     /* L4 RAM, DCSM secure, CLA Program RAM */
       RAMLS5              : origin = 0x00A800, length = 0x000800     /* L5 RAM, DCSM secure, CLA Program RAM */
       RAMGS0123           : origin = 0x00C000, length = 0x004000     /* GS0- 3 Parity, DMA */
       BEGIN_FLASH         : origin = 0x080000, length = 0x000002     /* Part of FLASH Sector A - used for "Jump to flash" bootloader mode */
       FLASH_A             : origin = 0x080002, length = 0x001FFE     /* Part of FLASH Sector A - DCSM secure */
       FLASH_BCDEFGHIJKLMN : origin = 0x082000, length = 0x03E000     /* FLASH Sectors B,C,D,E,F,G,H,I,J,K,L,M,N combined - DCSM secure */
       RESET           (R) : origin = 0x3FFFC0, length = 0x000002     /* Part of Boot ROM */
       RAMGS89ABCDEF       : origin = 0x014000, length = 0x008000     /* GS8-15 RAM, Parity, DMA */
       BOOT_RSVD           : origin = 0x000002, length = 0x00004E     /* Part of M0 RAM, BOOT rom will use this for stack */
       RAMM0               : origin = 0x000050, length = 0x0003B0     /* M0 RAM */
       RAMM1               : origin = 0x000400, length = 0x000400     /* M1 RAM */
       CLA1_MSGRAMLOW      : origin = 0x001480, length = 0x000080     /* CLA to CPU Message RAM, DCSM secure */
       CLA1_MSGRAMHIGH     : origin = 0x001500, length = 0x000080     /* CPU to CLA Message RAM, DCSM secure */
       RAMLS0              : origin = 0x008000, length = 0x000800     /* L0 RAM, DCSM secure, CLA Data RAM */
       RAMLS1              : origin = 0x008800, length = 0x000800     /* L1 RAM, DCSM secure, CLA Data RAM */
       //Removing to expand RAMLS3 //RAMLS2              : origin = 0x009000, length = 0x000800     /* L2 RAM, DCSM secure, CLA Data RAM */
       RAMD0               : origin = 0x00B000, length = 0x000800     /* D0 RAM, DCSM secure, ECC */
       RAMD1               : origin = 0x00B800, length = 0x000800     /* D1 RAM, DCSM secure, ECC */
       RAMGS4              : origin = 0x010000, length = 0x001000     /* GS4 RAM, Parity, DMA */
       RAMGS5              : origin = 0x011000, length = 0x001000     /* GS5 RAM, Parity, DMA */
       RAMGS6              : origin = 0x012000, length = 0x001000     /* GS6 RAM, Parity, DMA */
       RAMGS7              : origin = 0x013000, length = 0x001000     /* GS7 RAM, Parity, DMA */
       FLASHL            : origin = 0x0BA000, length = 0x002000   /* on-chip Flash */
    SECTIONS
    /*** Compiler Required Sections ***/
      /* Program memory (PAGE 0) sections */
      // .text               : > RAMGS0123,             PAGE = 0
      // .cinit              : > RAMGS0123,             PAGE = 0
      // .const              : > RAMGS0123,             PAGE = 0
      // .econst             : > RAMGS0123,             PAGE = 0
      // .pinit              : > RAMGS0123,             PAGE = 0
      // .reset              : > RESET,                 PAGE = 0, TYPE = DSECT  /* Not using the .reset section */
      // .switch             : > RAMGS0123,             PAGE = 0
       .text               : > FLASH_BCDEFGHIJKLMN,             PAGE = 0
       .cinit              : > FLASH_BCDEFGHIJKLMN,             PAGE = 0
       .const              : > FLASH_BCDEFGHIJKLMN,             PAGE = 0
       .econst             : > FLASH_BCDEFGHIJKLMN,             PAGE = 0
       .pinit              : > FLASH_BCDEFGHIJKLMN,             PAGE = 0
       .switch             : > FLASH_BCDEFGHIJKLMN,             PAGE = 0
       //Load tables to Flash and copy over to RAM
       CLA1mathTables    :  LOAD = FLASHL,
                            RUN = RAMLS0,
                            RUN_START(_CLA1mathTablesRunStart),
                            LOAD_START(_CLA1mathTablesLoadStart),
                            LOAD_SIZE(_CLA1mathTablesLoadSize),
                            PAGE = 1
      /* Data Memory (PAGE 1) sections */
       .bss                : > RAMM0,                 PAGE = 1
     //  .ebss               : > RAMM0,                 PAGE = 1
       .ebss               : > RAMGS4,                  PAGE = 1
       .cio                : > RAMM0,                 PAGE = 1
       .stack              : > RAMM1,                 PAGE = 1
       .sysmem             : > RAMM1,                 PAGE = 1
       .esysmem            : > RAMM1,                 PAGE = 1
    /*** CLA Compiler Required Sections ***/
       .scratchpad         : > RAMLS0,                PAGE = 1                /* Scratchpad memory for the CLA C Compiler */
    /*** User Defined Sections ***/
       //codestart           : > BEGIN_M0,           PAGE = 0
       codestart           : > BEGIN_FLASH,           PAGE = 0                /* Used by file CodeStartBranch.asm */
       dmaMemBufs          : > RAMGS4,                PAGE = 1                /* Link to DMA accessible memory */
       Cla1ToCpuMsgRAM     : > CLA1_MSGRAMLOW,        PAGE = 1                /* Link to CLA Message RAM */
       CpuToCla1MsgRAM     : > CLA1_MSGRAMHIGH,       PAGE = 1                /* Link to CLA Message RAM */
       Cla1Data1           : > RAMLS1,                PAGE = 1                /* Link to CLA Data RAM */
       // Removed to expand program data space //Cla1Data2           : > RAMLS2,                PAGE = 1                /* Link to CLA Data RAM */
       /* Section secureRamFuncs used by file Flash.c. */
       secureRamFuncs      :  LOAD = FLASH_BCDEFGHIJKLMN, PAGE = 0            /* Load to flash, run from DCSM secure RAM */
                              RUN = RAMLS5,               PAGE = 0
                              LOAD_START(_secureRamFuncs_loadstart),
                              LOAD_SIZE(_secureRamFuncs_loadsize),
                              RUN_START(_secureRamFuncs_runstart)
       /* Section Cla1Prog used by file Cla.c */
       Cla1Prog            :  LOAD = FLASH_BCDEFGHIJKLMN, PAGE = 0            /* Load to flash, run from CLA Program RAM */
                              RUN_START(_Cla1Prog_Start)
                              RUN = RAMLS3,               PAGE = 0
                              LOAD_START(_cla1Funcs_loadstart),
                              LOAD_SIZE(_cla1Funcs_loadsize),
                              RUN_START(_cla1Funcs_runstart)
      /* Section RamFuncs */
       RamFuncs            :  LOAD = FLASH_BCDEFGHIJKLMN, PAGE = 0            /* Load to flash, run from CLA Program RAM */
                              RUN_START(_RamFunc_Start)
                              RUN = RAMGS89ABCDEF,        PAGE = 0
                              LOAD_START(_RamFuncs_loadstart),
                              LOAD_SIZE(_RamFuncs_loadsize),
                              RUN_START(_RamFuncs_runstart)
    /******************* end of file ************************/
  • Is the issue in the "Memory" part of the cmd file or the "Sections" part of the cmd file?  In addition, how will I know if it's loading to RAM or FLASH.  Is there a document that describes which addresses belong to either?
  • Philip,
    Datasheet should have a memory map table - that gives the address ranges for Flash and RAM.  Please review it.
    Did you take a look at the linker cmd file that I suggested?  In that you can see that "sections" are mapped to flash address ranges that are defined in the "Memory".
    Also, please take a look at this:  software-dl.ti.com/.../c2000_c28x-compiler-understanding-linking.html
    Thanks and regards,
    Vamsi
  • I've compared what I just posted as my linker file to your example and tried to look at the documents you've sent.  It's still not clear.  What sections in my linker am I assigning to RAM?  I don't understand
  • Philip,
    The error address from your snapshot is 0x7C88.  It is GPIO control register space as per the F2837xD_Headers_nonBIOS_cpu1.cmd.
    Below is the corresponding snap for memory range (GPIOCTRL) declaration:
    And you can see below that the corresponding register structure is assigned to that address range.  As you can see it is configured as type=NOINT - Non initialized.
    What is the C2000Ware version that you are using?  Please use the latest one.  That should have "type=NOINT".
    Another link that can help understand the linker: https://software-dl.ti.com/ccs/esd/documents/sdto_cgt_Linker-Command-File-Primer.html
    Thanks and regards,
    Vamsi
  • I'm using C2000Ware 3_03_00_00.  Changing the F2837xd_headers_nonBios_cpu1.cmd did not change the issue.  I've attached F2837xD_headers_nonBios_cpu1.cmd that I used and the error I still receive when loading.
    MEMORY
       ACCESSPROTECTION           : origin = 0x0005F4C0, length = 0x00000040
       ADCA                       : origin = 0x00007400, length = 0x00000080
       ADCB                       : origin = 0x00007480, length = 0x00000080
       ADCC                       : origin = 0x00007500, length = 0x00000080
       ADCD                       : origin = 0x00007580, length = 0x00000080
       ADCARESULT                 : origin = 0x00000B00, length = 0x00000018
       ADCBRESULT                 : origin = 0x00000B20, length = 0x00000018
       ADCCRESULT                 : origin = 0x00000B40, length = 0x00000018
       ADCDRESULT                 : origin = 0x00000B60, length = 0x00000018
       ANALOGSUBSYS               : origin = 0x0005D180, length = 0x00000048
       CANA                       : origin = 0x00048000, length = 0x00000200
       CANB                       : origin = 0x0004A000, length = 0x00000200
       CLA1                       : origin = 0x00001400, length = 0x00000080
       CLB1DATAEXCH               : origin = 0x00003200, length = 0x00000200
       CLB2DATAEXCH               : origin = 0x00003600, length = 0x00000200
       CLB3DATAEXCH               : origin = 0x00003A00, length = 0x00000200
       CLB4DATAEXCH               : origin = 0x00003E00, length = 0x00000200
       CLB1LOGICCFG               : origin = 0x00003000, length = 0x00000052
       CLB2LOGICCFG               : origin = 0x00003400, length = 0x00000052
       CLB3LOGICCFG               : origin = 0x00003800, length = 0x00000052
       CLB4LOGICCFG               : origin = 0x00003C00, length = 0x00000052
       CLB1LOGICCTRL              : origin = 0x00003100, length = 0x00000040
       CLB2LOGICCTRL              : origin = 0x00003500, length = 0x00000040
       CLB3LOGICCTRL              : origin = 0x00003900, length = 0x00000040
       CLB4LOGICCTRL              : origin = 0x00003D00, length = 0x00000040
       CLBXBAR                    : origin = 0x00007A40, length = 0x00000040
       CLKCFG                     : origin = 0x0005D200, length = 0x00000032
       CMPSS1                     : origin = 0x00005C80, length = 0x00000020
       CMPSS2                     : origin = 0x00005CA0, length = 0x00000020
       CMPSS3                     : origin = 0x00005CC0, length = 0x00000020
       CMPSS4                     : origin = 0x00005CE0, length = 0x00000020
       CMPSS5                     : origin = 0x00005D00, length = 0x00000020
       CMPSS6                     : origin = 0x00005D20, length = 0x00000020
       CMPSS7                     : origin = 0x00005D40, length = 0x00000020
       CMPSS8                     : origin = 0x00005D60, length = 0x00000020
       CPUTIMER0                  : origin = 0x00000C00, length = 0x00000008
       CPUTIMER1                  : origin = 0x00000C08, length = 0x00000008
       CPUTIMER2                  : origin = 0x00000C10, length = 0x00000008
       CPUSYS                     : origin = 0x0005D300, length = 0x00000082
       DACA                       : origin = 0x00005C00, length = 0x00000008
       DACB                       : origin = 0x00005C10, length = 0x00000008
       DACC                       : origin = 0x00005C20, length = 0x00000008
       DCSMCOMMON                 : origin = 0x0005F070, length = 0x00000008
       DCSMZ1                     : origin = 0x0005F000, length = 0x00000030
       DCSMZ2                     : origin = 0x0005F040, length = 0x00000030
       DEVCFG                     : origin = 0x0005D000, length = 0x0000012E
       DMACLASRCSEL               : origin = 0x00007980, length = 0x0000001A
       DMA                        : origin = 0x00001000, length = 0x00000200
       ECAP1                      : origin = 0x00005000, length = 0x00000020
       ECAP2                      : origin = 0x00005020, length = 0x00000020
       ECAP3                      : origin = 0x00005040, length = 0x00000020
       ECAP4                      : origin = 0x00005060, length = 0x00000020
       ECAP5                      : origin = 0x00005080, length = 0x00000020
       ECAP6                      : origin = 0x000050A0, length = 0x00000020
       EMIF1CONFIG                : origin = 0x0005F480, length = 0x00000020
       EMIF2CONFIG                : origin = 0x0005F4A0, length = 0x00000020
       EMIF1                      : origin = 0x00047000, length = 0x00000070
       EMIF2                      : origin = 0x00047800, length = 0x00000070
       EPWM1                      : origin = 0x00004000, length = 0x00000100
       EPWM2                      : origin = 0x00004100, length = 0x00000100
       EPWM3                      : origin = 0x00004200, length = 0x00000100
       EPWM4                      : origin = 0x00004300, length = 0x00000100
       EPWM5                      : origin = 0x00004400, length = 0x00000100
       EPWM6                      : origin = 0x00004500, length = 0x00000100
       EPWM7                      : origin = 0x00004600, length = 0x00000100
       EPWM8                      : origin = 0x00004700, length = 0x00000100
       EPWM9                      : origin = 0x00004800, length = 0x00000100
       EPWM10                     : origin = 0x00004900, length = 0x00000100
       EPWM11                     : origin = 0x00004A00, length = 0x00000100
       EPWM12                     : origin = 0x00004B00, length = 0x00000100
       EPWMXBAR                   : origin = 0x00007A00, length = 0x00000040
       EQEP1                      : origin = 0x00005100, length = 0x00000022
       EQEP2                      : origin = 0x00005140, length = 0x00000022
       EQEP3                      : origin = 0x00005180, length = 0x00000022
       FLASH0CTRL                 : origin = 0x0005F800, length = 0x00000182
       FLASH0ECC                  : origin = 0x0005FB00, length = 0x00000028
       FLASHPUMPSEMAPHORE         : origin = 0x00050024, length = 0x00000002
       GPIOCTRL                   : origin = 0x00007C00, length = 0x00000180
       GPIODATA                   : origin = 0x00007F00, length = 0x00000030
       I2CA                       : origin = 0x00007300, length = 0x00000022
       I2CB                       : origin = 0x00007340, length = 0x00000022
       INPUTXBAR                  : origin = 0x00007900, length = 0x00000020
       IPC                        : origin = 0x00050000, length = 0x00000024
       MEMORYERROR                : origin = 0x0005F500, length = 0x00000040
       MEMCFG                     : origin = 0x0005F400, length = 0x00000080
       MCBSPA                     : origin = 0x00006000, length = 0x00000024
       MCBSPB                     : origin = 0x00006040, length = 0x00000024
       NMIINTRUPT                 : origin = 0x00007060, length = 0x00000007
       OUTPUTXBAR                 : origin = 0x00007A80, length = 0x00000040
       PIECTRL                    : origin = 0x00000CE0, length = 0x0000001A
       PIEVECTTABLE               : origin = 0x00000D00, length = 0x00000200
       ROMPREFETCH                : origin = 0x0005E608, length = 0x00000002
       ROMWAITSTATE               : origin = 0x0005F540, length = 0x00000002
       SCIA                       : origin = 0x00007200, length = 0x00000010
       SCIB                       : origin = 0x00007210, length = 0x00000010
       SCIC                       : origin = 0x00007220, length = 0x00000010
       SCID                       : origin = 0x00007230, length = 0x00000010
       SDFM1                      : origin = 0x00005E00, length = 0x00000080
       SDFM2                      : origin = 0x00005E80, length = 0x00000080
       SPIA                       : origin = 0x00006100, length = 0x00000010
       SPIB                       : origin = 0x00006110, length = 0x00000010
       SPIC                       : origin = 0x00006120, length = 0x00000010
       SYNCSOC                    : origin = 0x00007940, length = 0x00000006
       UPP                        : origin = 0x00006200, length = 0x00000048
       WD                         : origin = 0x00007000, length = 0x0000002B
       XBAR                       : origin = 0x00007920, length = 0x00000020
       XINT                       : origin = 0x00007070, length = 0x0000000B
    SECTIONS
    UNION run = PIEVECTTABLE
        PieVectTableFile      : TYPE=DSECT
        GROUP
            EmuKeyVar         : TYPE=DSECT
            EmuBModeVar       : TYPE=DSECT
            EmuBootPinsVar    : TYPE=DSECT
            FlashCallbackVar  : TYPE=DSECT
            FlashScalingVar   : TYPE=DSECT
       AccessProtectionRegsFile   : > ACCESSPROTECTION, type=NOINIT
       AdcaRegsFile               : > ADCA, type=NOINIT
       AdcbRegsFile               : > ADCB, type=NOINIT
       AdccRegsFile               : > ADCC, type=NOINIT
       AdcdRegsFile               : > ADCD, type=NOINIT
       AdcaResultRegsFile         : > ADCARESULT, type=NOINIT
       AdcbResultRegsFile         : > ADCBRESULT, type=NOINIT
       AdccResultRegsFile         : > ADCCRESULT, type=NOINIT
       AdcdResultRegsFile         : > ADCDRESULT, type=NOINIT
       AnalogSubsysRegsFile       : > ANALOGSUBSYS, type=NOINIT
       CanaRegsFile               : > CANA, type=NOINIT
       CanbRegsFile               : > CANB, type=NOINIT
       Cla1RegsFile               : > CLA1, type=NOINIT
       Clb1DataExchRegsFile       : > CLB1DATAEXCH, type=NOINIT
       Clb2DataExchRegsFile       : > CLB2DATAEXCH, type=NOINIT
       Clb3DataExchRegsFile       : > CLB3DATAEXCH, type=NOINIT
       Clb4DataExchRegsFile       : > CLB4DATAEXCH, type=NOINIT
       Clb1LogicCfgRegsFile       : > CLB1LOGICCFG, type=NOINIT
       Clb2LogicCfgRegsFile       : > CLB2LOGICCFG, type=NOINIT
       Clb3LogicCfgRegsFile       : > CLB3LOGICCFG, type=NOINIT
       Clb4LogicCfgRegsFile       : > CLB4LOGICCFG, type=NOINIT
       Clb1LogicCtrlRegsFile      : > CLB1LOGICCTRL, type=NOINIT
       Clb2LogicCtrlRegsFile      : > CLB2LOGICCTRL, type=NOINIT
       Clb3LogicCtrlRegsFile      : > CLB3LOGICCTRL, type=NOINIT
       Clb4LogicCtrlRegsFile      : > CLB4LOGICCTRL, type=NOINIT
       ClbXbarRegsFile            : > CLBXBAR, type=NOINIT
       ClkCfgRegsFile             : > CLKCFG, type=NOINIT
       Cmpss1RegsFile             : > CMPSS1, type=NOINIT
       Cmpss2RegsFile             : > CMPSS2, type=NOINIT
       Cmpss3RegsFile             : > CMPSS3, type=NOINIT
       Cmpss4RegsFile             : > CMPSS4, type=NOINIT
       Cmpss5RegsFile             : > CMPSS5, type=NOINIT
       Cmpss6RegsFile             : > CMPSS6, type=NOINIT
       Cmpss7RegsFile             : > CMPSS7, type=NOINIT
       Cmpss8RegsFile             : > CMPSS8, type=NOINIT
       CpuTimer0RegsFile          : > CPUTIMER0, type=NOINIT
       CpuTimer1RegsFile          : > CPUTIMER1, type=NOINIT
       CpuTimer2RegsFile          : > CPUTIMER2, type=NOINIT
       CpuSysRegsFile             : > CPUSYS, type=NOINIT
       DacaRegsFile               : > DACA, type=NOINIT
       DacbRegsFile               : > DACB, type=NOINIT
       DaccRegsFile               : > DACC, type=NOINIT
       DcsmCommonRegsFile         : > DCSMCOMMON, type=NOINIT
       DcsmZ1RegsFile             : > DCSMZ1, type=NOINIT
       DcsmZ2RegsFile             : > DCSMZ2, type=NOINIT
       DevCfgRegsFile             : > DEVCFG, type=NOINIT
       DmaClaSrcSelRegsFile       : > DMACLASRCSEL, type=NOINIT
       DmaRegsFile                : > DMA, type=NOINIT
       ECap1RegsFile              : > ECAP1, type=NOINIT
       ECap2RegsFile              : > ECAP2, type=NOINIT
       ECap3RegsFile              : > ECAP3, type=NOINIT
       ECap4RegsFile              : > ECAP4, type=NOINIT
       ECap5RegsFile              : > ECAP5, type=NOINIT
       ECap6RegsFile              : > ECAP6, type=NOINIT
       Emif1ConfigRegsFile        : > EMIF1CONFIG, type=NOINIT
       Emif2ConfigRegsFile        : > EMIF2CONFIG, type=NOINIT
       Emif1RegsFile              : > EMIF1, type=NOINIT
       Emif2RegsFile              : > EMIF2, type=NOINIT
       EPwm1RegsFile              : > EPWM1, type=NOINIT
       EPwm2RegsFile              : > EPWM2, type=NOINIT
       EPwm3RegsFile              : > EPWM3, type=NOINIT
       EPwm4RegsFile              : > EPWM4, type=NOINIT
       EPwm5RegsFile              : > EPWM5, type=NOINIT
       EPwm6RegsFile              : > EPWM6, type=NOINIT
       EPwm7RegsFile              : > EPWM7, type=NOINIT
       EPwm8RegsFile              : > EPWM8, type=NOINIT
       EPwm9RegsFile              : > EPWM9, type=NOINIT
       EPwm10RegsFile             : > EPWM10, type=NOINIT
       EPwm11RegsFile             : > EPWM11, type=NOINIT
       EPwm12RegsFile             : > EPWM12, type=NOINIT
       EPwmXbarRegsFile           : > EPWMXBAR, type=NOINIT
       EQep1RegsFile              : > EQEP1, type=NOINIT
       EQep2RegsFile              : > EQEP2, type=NOINIT
       EQep3RegsFile              : > EQEP3, type=NOINIT
       Flash0CtrlRegsFile         : > FLASH0CTRL, type=NOINIT
       Flash0EccRegsFile          : > FLASH0ECC, type=NOINIT
       FlashPumpSemaphoreRegsFile : > FLASHPUMPSEMAPHORE, type=NOINIT
       GpioCtrlRegsFile           : > GPIOCTRL, type=NOINIT
       GpioDataRegsFile           : > GPIODATA, type=NOINIT
       I2caRegsFile               : > I2CA, type=NOINIT
       I2cbRegsFile               : > I2CB, type=NOINIT
       InputXbarRegsFile          : > INPUTXBAR, type=NOINIT
       IpcRegsFile                : > IPC, type=NOINIT
       MemoryErrorRegsFile        : > MEMORYERROR, type=NOINIT
       MemCfgRegsFile             : > MEMCFG, type=NOINIT
       McbspaRegsFile             : > MCBSPA, type=NOINIT
       McbspbRegsFile             : > MCBSPB, type=NOINIT
       NmiIntruptRegsFile         : > NMIINTRUPT, type=NOINIT
       OutputXbarRegsFile         : > OUTPUTXBAR, type=NOINIT
       PieCtrlRegsFile            : > PIECTRL, type=NOINIT
       PieVectTableFile           : > PIEVECTTABLE, type=NOINIT
       RomPrefetchRegsFile        : > ROMPREFETCH, type=NOINIT
       RomWaitStateRegsFile       : > ROMWAITSTATE, type=NOINIT
       SciaRegsFile               : > SCIA, type=NOINIT
       ScibRegsFile               : > SCIB, type=NOINIT
       ScicRegsFile               : > SCIC, type=NOINIT
       ScidRegsFile               : > SCID, type=NOINIT
       Sdfm1RegsFile              : > SDFM1, type=NOINIT
       Sdfm2RegsFile              : > SDFM2, type=NOINIT
       SpiaRegsFile               : > SPIA, type=NOINIT
       SpibRegsFile               : > SPIB, type=NOINIT
       SpicRegsFile               : > SPIC, type=NOINIT
       SyncSocRegsFile            : > SYNCSOC, type=NOINIT
       UppRegsFile                : > UPP, type=NOINIT
       WdRegsFile                 : > WD, type=NOINIT
       XbarRegsFile               : > XBAR, type=NOINIT
       XintRegsFile               : > XINT, type=NOINIT
    // End of file.
  • Philip,
    If you want to show any file's content, please attach it instead of copying the contents in to the post.  It helps to concentrate on the actual discussion.  Thank you.
    In your application's linker cmd file that you shared previously (not the F2837xd_headers_nonBios_cpu1.cmd), I noticed that the sections mapped to flash are not aligned on 128-bit boundary.  Please use ALIGN(8) as shown in the linker cmd file that I referred previously from C2000Ware.  That may fix this issue.
    Let me know how it goes.
    Thanks and regards,
    Vamsi
