Other Parts Discussed in Thread: SYSCONFIG, TMDSCNCD28379D, C2000WARE
I AM USING F283798D BOARD I am not able to identify the epwm7 t epwm 12 on board...kindly what are the pin no's associated with these epwm on board
Are you using the F28379D LaunchPad or ControlCARD evaluation board?
Kevin
I'm not sure if epwm7 to epwm 12 are brought out to pins on the PCB.
You can find the pin definition of the LaunchPad here, https://www.ti.com/lit/pdf/sprui73. The 'P#' labels denote the F2837x device pin that's connected to the respective LaunchPad pin. You can then check the F2837x datasheet to see what signals are on each device pin, or use Sysconfig tool for this.
Kevin
The TMDSCNCD28379D definitely brings out more device pins than the LaunchPad and I think it probably does bring all ePWM signals out to the connector.
You can check what device GPIOs it brings out by viewing the 'TMDSCNCD28377D_180cCARD_pinout_R1_3.pdf' file in C2000WARE directory below:
C:\ti\c2000\C2000Ware_4_00_00_00\boards\controlCARDs\TMDSCNCD28379D\R1_3
Kevin
