Other Parts Discussed in Thread: BQ76PL455EVM
Hi Team,
Could you help our customer. I have post their concern below.
I am programming my launchpad using the simulink C2000 embedded coder. I am able to send and receive serial messages with the connected TI bq76pl455evm. This EVM needs its RX line pulled low for a certain amount of time to perform a communications reset. When I use the SCI transmit and GPIO digital output block in the same model, I receive the error that the GPIO pin is already used by SCI transmit. Are there any recommendations regarding how I can achieve this?.I alread read and check the MathWorks Solutions for C2000 MCU’s
I am specifically wanting to pull the TX pin of the microcontroller's SCIB module to trigger a comms reset on the connected evm.
Jonathan
