Part Number: C2000WARE
Hi team,
My customer can't post on the forum. I help him ask questions。
Thank you very much for your help.
Hi team,
You may need to double check if the input pin(signal generator signal) you used is correct. if it is correct, then you need to check if the current ref value is too large. In your case, PSFB_gui_icommand_Set_Amps should be the peak reference if the slope compensation is 0. In the code, it is the slope is 30, so you need to consider that as well.
Chen
