Other Parts Discussed in Thread: CONTROLSUITE
Howdy,
A colleague and I are trying to implement sensorless FOC using TI's High Voltage Motor Control+PFC kit. We are driving a permanent-magnet synchronous motor with the kit. Originally most of the motor parameters were unknown and we were unable to close the speed loop per the incremental build system outlined in the documentation. We experienced lots of vibration and high current draw during open-loop operation and when we closed the speed loop the motor would pull out and overcurrent the power supply.
We've recently determined the parameters of the machine we are working with. While driving the motor in open-loop we still have lots of vibration and audible noise. We can now close the speed loop but the motor stops very quickly then restarts. The current is lower than in open-loop mode but the vibration is still there. We also noticed that the speed is higher in closed-loop than in open loop by about 200 RPM. Furthermore, we are not always able to close the speed loop successfully.
If anyone could give any insight on how to get rid of the vibration and how to properly tune the PID gains it will be much appreciated. Thank you very much beforehand! :)
