Part Number: TMS320F28069M
Hi! I am not sure if I am doing it correctly. I am using lab05a as reference for my project. At the default state when I set IqRef_A to negative value the motor spins slowly and max rpms I get when the IqRef_A is positive. In order to change spin direction I have to set SpeedRef_krpm to negative value. But now the IqRef_A responds backwards - positive value for low speed, max krpm for negative speed. Is this correct? Am I doing it correctly or there is another approach in changing motor spin direction and rpm control respectively?
thanks!
