TMS320F280025C: TMS320F280025C:
Part Number: TMS320F280025C
Other Parts Discussed in Thread: C2000WARE, TMDSCNCD280025C
I am trying to use jtag for flashing as well as debugging for my project and somehow i am not able to set the proper pin configuration for both of them . so if anyone has any idea about it then do share .
  • Hello Ritesh,
    I need a few more details about your problem. Describe your setup; what specific operation are you trying to perform, and what errors do you get?
    Ibukun
  • Hi thanks for the feedback actually i am trying to use a xds 110 jtag probe as a debugger and flashing device as my microcontroller has only 1 uart that i am using for communication and for jtag i am not able to find out the correct pins to be connected with the docking station of my control card to be used for my work .
  • Hello Ritesh,
    For pin numbers and function assignments, please refer to the device data sheet. If you are using the control card, the package used there is the largest page (80-pin QFN).
    For a schematic diagram of the control card (which will also show mappings of device pins to control card pin locations), please look in the boards\controlCARDs\TMDSCNCD280025C\ subdirectory inside your C2000Ware installation directory (e.g. C:\ti\c2000\C2000Ware_x.xx.xx.xx).
    Ibukun
