Part Number: TMS320F28332
Other Parts Discussed in Thread: ADS127L01EVM
Hi.
Here I will need the technical support for SPI protocol set up where ADS127L01EVM (slave) and Delfino F2833x board (master).
I have done the testing for Master send data to slave. BUT, currently I face issue with the Master read data which sent by slave.
I notice that there are no SCLK pulse from Master and slave select pin did not change to low for activate the CS once the code reach the code for master to receive data from slave.
May I know is there any other setting/configuration the needed for set up the Master to receive the data from slave.
Hope you could provide support on this.
Looking forward to your support.
