Part Number: TMS320F28377S
Hello.
I'm using ePWM to generate a specific output pattern. I use ePWM with the up-down counting. The ePWM outputs A and B change state each time the counter reaches 0 (CTR = ZRO). In the same time, I need to change the setting of these registers to generate an another pattern for the next up-down counting. To do such a thing, I use the shadow load to active register function at the same time, i.e. CTR = ZRO.
Sometimes this design does not work properly. Some unexpected ePWM output patterns appear.
I found neither in TRM nor in the Silicon errata a clear avoidance of this design.
My question is:
Should this design be avoided, prohibited or, on the contrary, authorized, proven and safe?
Thank you for your help and clarification on this point.
Stephane Bonnot
