Other Parts Discussed in Thread: TMS320F280021
I Use TMS320F280021 for LLC charging process, ePWM3 and ePwm4 are used to drive H-bridge LLC, with PWM operating frequency ranging from 80K to 150K, which is the upper and lower limits set by the software, and resonant operating frequency of 90KHZ. When the frequency of LLC is adjusted from 85K to close to 80K during the working process, there is an occasional possibility of the MOS transistor driving at the same height on the half bridge, which is not 100%. The MOS transistor is directly short circuited and the tube is burned out. May I ask if there are any issues with the configuration? Thank you!
The waveform is as follows:
Drive waveform and frequency at the moment before short circuit:
PWM setting code:
void UserSetEPWM()
EALLOW;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0;
EDIS;
EALLOW;
GpioCtrlRegs.GPHAMSEL.bit.GPIO242 = 0;
GpioCtrlRegs.GPHQSEL2.bit.GPIO242 = 3;
InputXbarRegs.INPUT1SELECT = 242;
GpioCtrlRegs.GPHLOCK.bit.GPIO242 = 1;
GpioCtrlRegs.GPHCR.bit.GPIO242 = 1;
InputXbarRegs.INPUTSELECTLOCK.bit.INPUT1SELECT = 1;
EPwm1Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
EPwm2Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
EPwm3Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
EPwm4Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
EPwm1Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
EPwm2Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
EPwm3Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
EPwm4Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
EPwm1Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
EPwm2Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
EPwm3Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
EPwm4Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
EPwm4Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
EPwm4Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
EPwm1Regs.TZFRC.bit.OST = 1;
EPwm2Regs.TZFRC.bit.OST = 1;
EPwm3Regs.TZFRC.bit.OST = 1;
EPwm4Regs.TZFRC.bit.OST = 1;
EPwm1Regs.GLDCFG.all = 0x07FF;
EPwm1Regs.GLDCTL.bit.GLDMODE = 6;
EPwm1Regs.GLDCTL.bit.OSHTMODE = 1;
EPwm1Regs.GLDCTL.bit.GLD = 1;
EPwm1Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
EPwm2Regs.GLDCFG.all = 0x07FF;
EPwm2Regs.GLDCTL.bit.GLDMODE = 6;
EPwm2Regs.GLDCTL.bit.OSHTMODE = 1;
EPwm2Regs.GLDCTL.bit.GLD = 1;
EPwm2Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
EPwm3Regs.GLDCFG.all = 0x07FF;
EPwm3Regs.GLDCTL.bit.GLDMODE = 6;
EPwm3Regs.GLDCTL.bit.OSHTMODE = 1;
EPwm3Regs.GLDCTL.bit.GLD = 1;
EPwm3Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
EPwm4Regs.GLDCFG.all = 0x07FF;
EPwm4Regs.GLDCTL.bit.GLDMODE = 6;
EPwm4Regs.GLDCTL.bit.OSHTMODE = 1;
EPwm4Regs.GLDCTL.bit.GLD = 1;
EPwm4Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
EDIS;
EPwm1Regs.TBPRD = EPWMPeriod;
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm1Regs.TBCTL.bit.PHSDIR = TB_UP;
EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE; //
EPwm1Regs.TBPHS.bit.TBPHS = 0;
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown
EPwm1Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_DISABLE_ALL;
EPwm1Regs.EPWMSYNCOUTEN.bit.ZEROEN = SYNC_OUT_SRC_ENABLE;
EPwm2Regs.TBPRD = EPWMPeriod;
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm2Regs.TBCTL.bit.PHSDIR = TB_UP;
EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE;
EPwm2Regs.TBPHS.bit.TBPHS = 2;
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown
EPwm2Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1;
EPwm3Regs.TBPRD = EPWMPeriod;
EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm3Regs.TBCTL.bit.PHSDIR = TB_UP;
EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE;
EPwm3Regs.TBPHS.bit.TBPHS = 3; //10ns dalay
EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown
EPwm3Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1;
EPwm4Regs.TBPRD = EPWMPeriod;
EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm4Regs.TBCTL.bit.PHSDIR = TB_UP;
EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm4Regs.TBCTL.bit.PHSEN = TB_ENABLE;
EPwm4Regs.TBPHS.bit.TBPHS = 3; //10ns delay
EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown
EPwm4Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1;
EPwm5Regs.TBPRD = 1000;
EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm5Regs.TBCTL.bit.PHSDIR = TB_UP;
EPwm5Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm5Regs.TBCTL.bit.PHSEN = TB_DISABLE;
// EPwm5Regs.TBPHS.bit.TBPHS = 2; //10ns delay
EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count updown
EPwm5Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_DISABLE_ALL;
//计数比较模块设定
EPwm1Regs.TBCTR = 0; //0
EPwm1Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
EPwm1Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm2Regs.TBCTR = 0; //0
EPwm2Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
EPwm2Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm3Regs.TBCTR = 0; //0
EPwm3Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
EPwm3Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm4Regs.TBCTR = 0; //计数初值为0
EPwm4Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
EPwm4Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm5Regs.TBCTR = 0; //0
// EPwm5Regs.CMPA.bit.CMPA = 0;
// EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
// EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// AQ模块设定
EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;
EPwm1Regs.AQCTLA.bit.CBU = AQ_CLEAR;
EPwm1Regs.AQCTLB.bit.CBD = AQ_SET;
EPwm1Regs.AQCTLB.bit.CAD = AQ_CLEAR;
EPwm1Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
EPwm1Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
EPwm2Regs.AQCTLB.bit.CAU = AQ_SET;
EPwm2Regs.AQCTLB.bit.CBU = AQ_CLEAR;
EPwm2Regs.AQCTLA.bit.CBD = AQ_SET;
EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR;
EPwm2Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
EPwm2Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
EPwm3Regs.AQCTLA.bit.CAU = AQ_SET;
EPwm3Regs.AQCTLA.bit.CBU = AQ_CLEAR;
EPwm3Regs.AQCTLB.bit.CBD = AQ_SET;
EPwm3Regs.AQCTLB.bit.CAD = AQ_CLEAR;
EPwm3Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
EPwm3Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
EPwm4Regs.AQCTLB.bit.CAU = AQ_SET;
EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR;
EPwm4Regs.AQCTLA.bit.CBD = AQ_SET;
EPwm4Regs.AQCTLA.bit.CAD = AQ_CLEAR;
EPwm4Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
EPwm4Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
//DB
EPwm1Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EPwm2Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EPwm3Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EPwm4Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EPwm1Regs.GLDCTL2.bit.GFRCLD = 1;
EPwm5Regs.ETSEL.bit.SOCAEN = 1; // 1 Enable the ADC Start of Conversion B (EPWMxSOCB) Pulse, Enable EPWMxSOCB pulse.
EPwm5Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO; //PRD ADC_B
EPwm5Regs.ETPS.bit.SOCAPRD = ET_1ST;
// EPwm1Regs.ETSEL.bit.INTEN = 1; // 1 Enable the ADC Start of Conversion B (EPWMxSOCB) Pulse, Enable EPWMxSOCB pulse.
// EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; //PRD ADC_B
// EPwm1Regs.ETPS.bit.INTPRD = ET_1ST;
EALLOW;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
EDIS;
PWM LOAD Code:
void loadpwm()
F_SW = CC_PID.PIDU; //PID return value is freq value
F_SW = __fmin(150,F_SW);
F_SW = __fmax(80,F_SW);
EPWMPeriod = 50000 / F_SW;
EPWMPeriod_DIV2 = EPWMPeriod / 2;
LLC_Hduty_EPWM = LLC_duty * EPWMPeriod_DIV2;
if( LLC_Hduty_EPWM > EPWMPeriod_DIV2 - 25 )
LLC_Hduty_EPWM = EPWMPeriod_DIV2 - 25;
EPWMPeriod = EPWM_Cal_SW / F_SW;
EPWMPeriod = EPWMPeriod_DIV2 * 2;
F_Int = 50;
T_Ctrl = 0.001f/F_Int;
EPwm3Regs.TBPRD = EPWMPeriod; //Period of TB = 10kHz
EPwm4Regs.TBPRD = EPWMPeriod; //Period of TB = 10kHz
EPwm3Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LLC_Hduty_EPWM;
EPwm3Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LLC_Hduty_EPWM;
EPwm4Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LLC_Hduty_EPWM;
EPwm4Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LLC_Hduty_EPWM;
EPwm1Regs.GLDCTL2.bit.OSHTLD = 1;
