TMS320F280039C: Watchdog Interrupt Not Occuring
Part Number: TMS320F280039C
Hello There,
I'm configuring the Watchdog timer but I'm unable to achieve the interrupt even after the counter is reaching the maximum value.
Can you Please help.
  • Hi Tejas,
    Have you had a chance to reference the watchdog example provided in C2000Ware? From your configuration files, it appears that you've mapped the ISR routine to a funciton named INT_WAKE_ISR(). However, you are showing a different ISR named MCAL_WATCHDOG_ISR() that has your ISR counter.
    Which interrupt routine is targeted for the watchdog? Currently it is INT_WAKE_ISR(), this means that your code tied to the watchdog needs to defined in this function.
    Ozino
