Part Number: TMS320F28379D
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
There is an issue in SysConfig that severely limits our work.
Inside the "CMD" tab under "Memory"->"RAMGS Memory Combination" I defined the following:
In addition, inside the same tab under "Sections"->"User Defined Section" I defined a section with the above memory combination:
As you can see, there is an error specifying that "The memcfg module is needed on CPU1 to assign GSRAM".
However, inside "MEMCFG" tab under "GSRAM Configuration":
I've found a similar question in E2E forum where Veena Kamath responded the following (11 months ago):
How can we address/workaround this bug?
Oren
