Part Number: TMS320F28379D
We are using TMS320F28379D in one of our applications. EMIF1 module of TMS320F28379D to be interfaced to multiple Memory / Digital transceiver IC's as mentioned below:
1. With external 1M x 16 SRAM: EM1CS[2] + 16 bit data + EM1A[19]/EM1BA[1] (SRAM-A0) + EM1A[0:18] (SRAM[A1 : A19])
2. With external 16 bit Ethernet controller LAN91C111 (MAC + PHY) - EM1CS[3] + 16 bit data + EM1BA[1] (LAN-A0) + EM1A[0:14] (SRAM[A1 : A15]) + nWE
3. With external 8 bit Octal UART interface chip: EM1CS[4] + 8 bit data + EM1BA[1:0] (UART-A[1:0]) + EM1A[0] (UART[A2]) + nWE
Query 1: Please confirm whether the above hardware requirement is possible because this circuit requires switching of EMIF mode from 16 bit to 8 bit and vice versa.
Query 2: As per datasheet Table 6-4, EMIF1_CSxn is defined with fixed start address & end address. For memory devices this seems ok. For other asynchronous devices such as Ethernet controller & UART transceiver will there be any issues? Because CPU should be able to access registers / read or write data from or to these Digital transceivers.
Hafiz Haja
