Part Number: TMS320F28379D
In the formula below, could you clarify whether the "BEMF constant in mV/Hz" refers to the phase-to-phase peak or the phase-to-neutral peak
Could you please clarify which document/chapter this formula can be found so I can direct this question to the correct expert?
Allison
or can help to calculate the BEMF constant if:
1 measured phase to phase rms voltage is 10v/Krpm
2. Motor is 4 pole pairs
So how to calculate BEMF constant in mV/Hz?
Hello Steven,
The equation you provided refers to a phase to neutral BEMF constant.
Please refer to the calculation explication in the following e2e thread: https://e2e.ti.com/support/motor-drivers-group/motor-drivers/f/motor-drivers-forum/1397018/mcf8315a-unit-clarification-of-the-back-emf-constant-used-in-the-formula
Joshua
