Part Number: TMS320F28379D
Dear all, please help me as I am again facing the similar issue as mentioned earlier. Again, new DSP is giving the same error and not able to debug the program.
I will have to get back to you towards the end of the week. I apologize for the delay.
Ben Collier
Sir, Thank you very much for the response. I will be waiting for your suggestions.
Dear Sir, Good Evening
Is it possible for you to share your mail contact with me. Mine is satya.firststep@gmail.com. In total my 3DSPs stop working in same manner and I am unable to figure out the problem. I am in dire need of help. Please!
Where did you order these launchpads from?
Do they still not show up in device manager? That is a strong sign that the board has been damaged.
Its from a local supplier here at New Delhi, India. Issue is that my other lab mates working on same supplied DSPs are working fine. One thought in my mind is that USB port of my desktop is giving higher or lower voltage to the DSP. Can that be a possibility? Pen drive etc are working ok on those USB ports.
Device Manager shows as in attached screenshot. (Same as in earlier cases).
I don't know if this is possible, but it would certainly cause a problem.
To me it sounds like these boards are being damaged somehow. Please make sure to follow ESD guidelines, and make sure that the correct voltages are being applied.
