Part Number: TMS320F28379D
I'm working with the TI F28379 Launcpad.
I will generate a PWM switch signal with a PI based control for the inverter. For this I need to do abc/dq0 conversion. Therefore I need to use PLL. I am using a block as shown in the figure, but it keeps giving errors. I even tried a swatooth generator instead of the wt value I will get from the PLL block. but it gives errors again. can you help?
