Hi, I'm new to this. I recently bought the F28379D kit, along with the BoostXL-3PHGain and the Teknic 2310P. I'm running tests with the sensorless FOC in MATLAB Simulink, and it works fine—it generates 12V AC at the driver's output.
However, when I try to set everything up again, configuring only the ePWM blocks, the driver's output is zero. In other tests, the voltage remains permanently active. I'm not sure what is going wrong. The output is enabled, but I don't fully understand what's happening.
I want to create a new Simulink model because I need to test different control strategies.
Could you please provide a step-by-step guide on how to properly configure these devices with MATLAB Simulink? It would be really helpful to understand the correct setup process and avoid potential issues.
