Part Number: TMS320F280039C
- Previous thread
Dear TI expert,
I found the reason why I can't check SCI_RXSTATUS_BREAK flag in my code.
If I make SCI Break (keep SCI data line low over 82.5us), FE(Framing Error) and PE(Parity Error) bits(sometimes FE & OE & PE bits) are setted faster than BRKDT bit.
That's why DSSI_Break_Flag is not incresed in my code.
if((SCI_getRxStatus(SCIA_BASE) & SCI_RXSTATUS_BREAK)) // DSSI Break -> Configuration Phase
DSSI_Break_Flag++;
SCI_clearInterruptStatus(SCIA_BASE, SCI_INT_RXRDY_BRKDT);
SCI_performSoftwareReset(SCIA_BASE);
return;
else if((SCI_getRxStatus(SCIA_BASE) & (SCI_RXSTATUS_ERROR | SCI_RXSTATUS_PARITY | SCI_RXSTATUS_OVERRUN | SCI_RXSTATUS_FRAMING)))
SCI_resetChannels(SCIA_BASE);
return;
Is it normal for the FE&PE&OE error to occur together if I make SCI Break?
If I want to use BRKDT error only in SCI Break, is there any method that I can avoid FE&PE&OE error?
In TI library, there is no function that disable FE, PE and OE error.
Please check and advice,
Thanks.
From. Jaehoon
