TMS320F2812: SO# 365397 - This relates to the locked case "TMS320F2812: Device cannot program ------ P/N: TMS320F2812PGFA"
Part Number: TMS320F2812
the customer now respondes to the Question:
Is there any timeout on the programming tool?
We commonly see customers that have a programmer that will time out after seeing a higher than typical flash erase time.
Let's check this first.
The response is as follows:
We have finally received feedback from the programming center.Regarding the programming itself, it can be said that a total of
three attempts are made to program a component.
We further assume that the timeout possibly refers to the programming device?
Our programming devices are calibrated and certified by the manufacturer once a year.
Can you help to find out why som many  parts are failing to program?
Thank you
Adnan
  • Hi Adnan, have not seen any systemic quality issue but as the above indicates some customers underestimate the erase time per sector and build a timeout in their programming tool that is not sufficient.  Please make sure the timeout is appropriate per the datasheet or provide more details about the failure.
