Hi all,
I have a problem with the cmd file for a F28335.
When compiling I get
"C28xx: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map."
I found out how to get rid of this error, but I don't understand why.
If my cmd file contains the line
RAML5 : origin = 0x010000, length = 0x000200
I get the error, but if I change it to
RAML5 : origin = 0x00f990, length = 0x000200
everything is fine.
RAML5 has a length of 200 but used is only 100;
I could not find any overlapping; Is there anything special about address 10000? I don't understand why it is ok if origin of RAML5 is set to 0x00f990;
Thank you
This is my map file when I get no error
TMS320C2000 Linker PC v6.0.2
>> Linked Tue May 15 15:20:49 2012
OUTPUT FILE NAME: <Example_2833xAdcSeqModeTest.out>
ENTRY POINT SYMBOL: "code_start" address: 00000000
MEMORY CONFIGURATION
name origin length used unused attr fill
PAGE 0:
BEGIN 00000000 00000002 00000002 00000000 RWIX
RAMM0 00000050 000003b0 00000000 000003b0 RWIX
RAML0 00008000 00000100 00000041 000000bf RWIX
RAML1 00008100 00001f00 0000114a 00000db6 RWIX
ZONE7A 00200000 0000fc00 00000000 0000fc00 RWIX
CSM_RSVD 0033ff80 00000076 00000000 00000076 RWIX
CSM_PWL 0033fff8 00000008 00000000 00000008 RWIX
ADC_CAL 00380080 00000009 00000007 00000002 RWIX
IQTABLES 003fe000 00000b50 00000b50 00000000 RWIX
IQTABLES2 003feb50 0000008c 00000000 0000008c RWIX
FPUTABLES 003febdc 000006a0 000006a0 00000000 RWIX
BOOTROM 003ff27c 00000d44 00000000 00000d44 RWIX
RESET 003fffc0 00000002 00000000 00000002 RWIX
PAGE 1:
BOOT_RSVD 00000002 0000004e 00000000 0000004e RWIX
RAMM1 00000400 00000400 00000300 00000100 RWIX
DEV_EMU 00000880 00000180 000000d0 000000b0 RWIX
FLASH_REGS 00000a80 00000060 00000008 00000058 RWIX
CSM 00000ae0 00000010 00000010 00000000 RWIX
ADC_MIRROR 00000b00 00000010 00000010 00000000 RWIX
XINTF 00000b20 00000020 0000001e 00000002 RWIX
CPU_TIMER0 00000c00 00000008 00000008 00000000 RWIX
CPU_TIMER1 00000c08 00000008 00000008 00000000 RWIX
CPU_TIMER2 00000c10 00000008 00000008 00000000 RWIX
PIE_CTRL 00000ce0 00000020 0000001a 00000006 RWIX
PIE_VECT 00000d00 00000100 00000100 00000000 RWIX
DMA 00001000 00000200 000000e0 00000120 RWIX
MCBSPA 00005000 00000040 00000025 0000001b RWIX
MCBSPB 00005040 00000040 00000025 0000001b RWIX
ECANA 00006000 00000040 00000034 0000000c RWIX
ECANA_LAM 00006040 00000040 00000040 00000000 RWIX
ECANA_MOTS 00006080 00000040 00000040 00000000 RWIX
ECANA_MOTO 000060c0 00000040 00000040 00000000 RWIX
ECANA_MBOX 00006100 00000100 00000100 00000000 RWIX
ECANB 00006200 00000040 00000034 0000000c RWIX
ECANB_LAM 00006240 00000040 00000040 00000000 RWIX
ECANB_MOTS 00006280 00000040 00000040 00000000 RWIX
ECANB_MOTO 000062c0 00000040 00000040 00000000 RWIX
ECANB_MBOX 00006300 00000100 00000100 00000000 RWIX
EPWM1 00006800 00000022 00000022 00000000 RWIX
EPWM2 00006840 00000022 00000022 00000000 RWIX
EPWM3 00006880 00000022 00000022 00000000 RWIX
EPWM4 000068c0 00000022 00000022 00000000 RWIX
EPWM5 00006900 00000022 00000022 00000000 RWIX
EPWM6 00006940 00000022 00000022 00000000 RWIX
ECAP1 00006a00 00000020 00000020 00000000 RWIX
ECAP2 00006a20 00000020 00000020 00000000 RWIX
ECAP3 00006a40 00000020 00000020 00000000 RWIX
ECAP4 00006a60 00000020 00000020 00000000 RWIX
ECAP5 00006a80 00000020 00000020 00000000 RWIX
ECAP6 00006aa0 00000020 00000020 00000000 RWIX
EQEP1 00006b00 00000040 00000040 00000000 RWIX
EQEP2 00006b40 00000040 00000040 00000000 RWIX
GPIOCTRL 00006f80 00000040 0000002e 00000012 RWIX
GPIODAT 00006fc0 00000020 00000020 00000000 RWIX
GPIOINT 00006fe0 00000020 0000000a 00000016 RWIX
SYSTEM 00007010 00000020 00000020 00000000 RWIX
SPIA 00007040 00000010 00000010 00000000 RWIX
SCIA 00007050 00000010 00000010 00000000 RWIX
XINTRUPT 00007070 00000010 00000010 00000000 RWIX
ADC 00007100 00000020 0000001e 00000002 RWIX
SCIB 00007750 00000010 00000010 00000000 RWIX
SCIC 00007770 00000010 00000010 00000000 RWIX
I2CA 00007900 00000040 00000022 0000001e RWIX
RAML4 0000a000 00005000 00004870 00000790 RWIX
RAML5 0000f990 00000200 00000100 00000100 RWIX
ZONE7B 0020fc00 00000400 00000000 00000400 RWIX
CSM_PWL 0033fff8 00000008 00000008 00000000 RWIX
PARTID 00380090 00000001 00000001 00000000 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
codestart
* 0 00000000 00000002
00000000 00000002 DSP2833x_CodeStartBranch.obj (codestart)
.pinit 0 00008000 00000000 UNINITIALIZED
.cinit 0 00008000 00000022
00008000 0000000c 40kW_60kHz_ai_RESET.obj (.cinit)
0000800c 0000000a rts2800_fpu32.lib : _lock.obj (.cinit)
00008016 0000000a : exit.obj (.cinit)
00008020 00000002 --HOLE-- [fill = 0]
ramfuncs 0 00008022 0000001f
00008022 0000001b DSP2833x_SysCtrl.obj (ramfuncs)
0000803d 00000004 DSP2833x_usDelay.obj (ramfuncs)
.text 0 00008100 00001118
00008100 000008a9 40kW_60kHz_ai_RESET.obj (.text:retain)
000089a9 00000316 DSP2833x_DefaultIsr.obj (.text:retain)
00008cbf 000001e1 40kW_60kHz_ai_RESET.obj (.text)
00008ea0 000000f5 DSP2833x_SysCtrl.obj (.text)
00008f95 000000dd DSP2833x_EPwm.obj (.text)
00009072 00000074 DSP2833x_CpuTimers.obj (.text)
000090e6 00000046 rts2800_fpu32.lib : boot.obj (.text)
0000912c 00000034 rts2800_fpu32_fast_supplement.lib : sin_f32.obj (.text)
00009160 00000028 DSP2833x_PieCtrl.obj (.text)
00009188 00000020 DSP2833x_PieVect.obj (.text)
000091a8 00000019 rts2800_fpu32.lib : args_main.obj (.text)
000091c1 00000019 : exit.obj (.text)
000091da 00000019 rts2800_fpu32_fast_supplement.lib : div_f32.obj (.text)
000091f3 00000014 DSP2833x_Adc.obj (.text)
00009207 00000009 rts2800_fpu32.lib : _lock.obj (.text)
00009210 00000008 DSP2833x_CodeStartBranch.obj (.text)
IQmath 0 00009218 00000032
00009218 00000032 IQmath_fpu32.lib : IQ29sin.obj (IQmath)
csm_rsvd 0 0033ff80 00000000 DSECT
csmpasswds
* 0 0033fff8 00000000 DSECT
.adc_cal 0 00380080 00000007 NOLOAD SECTION
00380080 00000007 DSP2833x_ADC_cal.obj (.adc_cal)
IQmathTables
* 0 003fe000 00000b50 NOLOAD SECTION
003fe000 00000b50 IQmath_fpu32.lib : IQmathTables.obj (IQmathTables)
FPUmathTables
* 0 003febdc 000006a0 NOLOAD SECTION
003febdc 000006a0 rts2800_fpu32_fast_supplement.lib : FPUmathTables.obj (FPUmathTables)
.reset 0 003fffc0 00000002 DSECT
003fffc0 00000002 rts2800_fpu32.lib : boot.obj (.reset)
.stack 1 00000400 00000300 UNINITIALIZED
00000400 00000300 --HOLE--
DevEmuRegsFile
* 1 00000880 000000d0 UNINITIALIZED
00000880 000000d0 DSP2833x_GlobalVariableDefs.obj (DevEmuRegsFile)
FlashRegsFile
* 1 00000a80 00000008 UNINITIALIZED
00000a80 00000008 DSP2833x_GlobalVariableDefs.obj (FlashRegsFile)
CsmRegsFile
* 1 00000ae0 00000010 UNINITIALIZED
00000ae0 00000010 DSP2833x_GlobalVariableDefs.obj (CsmRegsFile)
AdcMirrorFile
* 1 00000b00 00000010 UNINITIALIZED
00000b00 00000010 DSP2833x_GlobalVariableDefs.obj (AdcMirrorFile)
XintfRegsFile
* 1 00000b20 0000001e UNINITIALIZED
00000b20 0000001e DSP2833x_GlobalVariableDefs.obj (XintfRegsFile)
CpuTimer0RegsFile
* 1 00000c00 00000008 UNINITIALIZED
00000c00 00000008 DSP2833x_GlobalVariableDefs.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
* 1 00000c08 00000008 UNINITIALIZED
00000c08 00000008 DSP2833x_GlobalVariableDefs.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
* 1 00000c10 00000008 UNINITIALIZED
00000c10 00000008 DSP2833x_GlobalVariableDefs.obj (CpuTimer2RegsFile)
PieCtrlRegsFile
* 1 00000ce0 0000001a UNINITIALIZED
00000ce0 0000001a DSP2833x_GlobalVariableDefs.obj (PieCtrlRegsFile)
PieVectTableFile
* 1 00000d00 00000100 UNINITIALIZED
00000d00 00000100 DSP2833x_GlobalVariableDefs.obj (PieVectTableFile)
DmaRegsFile
* 1 00001000 000000e0 UNINITIALIZED
00001000 000000e0 DSP2833x_GlobalVariableDefs.obj (DmaRegsFile)
McbspaRegsFile
* 1 00005000 00000025 UNINITIALIZED
00005000 00000025 DSP2833x_GlobalVariableDefs.obj (McbspaRegsFile)
McbspbRegsFile
* 1 00005040 00000025 UNINITIALIZED
00005040 00000025 DSP2833x_GlobalVariableDefs.obj (McbspbRegsFile)
ECanaRegsFile
* 1 00006000 00000034 UNINITIALIZED
00006000 00000034 DSP2833x_GlobalVariableDefs.obj (ECanaRegsFile)
ECanaLAMRegsFile
* 1 00006040 00000040 UNINITIALIZED
00006040 00000040 DSP2833x_GlobalVariableDefs.obj (ECanaLAMRegsFile)
ECanaMOTSRegsFile
* 1 00006080 00000040 UNINITIALIZED
00006080 00000040 DSP2833x_GlobalVariableDefs.obj (ECanaMOTSRegsFile)
ECanaMOTORegsFile
* 1 000060c0 00000040 UNINITIALIZED
000060c0 00000040 DSP2833x_GlobalVariableDefs.obj (ECanaMOTORegsFile)
ECanaMboxesFile
* 1 00006100 00000100 UNINITIALIZED
00006100 00000100 DSP2833x_GlobalVariableDefs.obj (ECanaMboxesFile)
ECanbRegsFile
* 1 00006200 00000034 UNINITIALIZED
00006200 00000034 DSP2833x_GlobalVariableDefs.obj (ECanbRegsFile)
ECanbLAMRegsFile
* 1 00006240 00000040 UNINITIALIZED
00006240 00000040 DSP2833x_GlobalVariableDefs.obj (ECanbLAMRegsFile)
ECanbMOTSRegsFile
* 1 00006280 00000040 UNINITIALIZED
00006280 00000040 DSP2833x_GlobalVariableDefs.obj (ECanbMOTSRegsFile)
ECanbMOTORegsFile
* 1 000062c0 00000040 UNINITIALIZED
000062c0 00000040 DSP2833x_GlobalVariableDefs.obj (ECanbMOTORegsFile)
ECanbMboxesFile
* 1 00006300 00000100 UNINITIALIZED
00006300 00000100 DSP2833x_GlobalVariableDefs.obj (ECanbMboxesFile)
EPwm1RegsFile
* 1 00006800 00000022 UNINITIALIZED
00006800 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm1RegsFile)
EPwm2RegsFile
* 1 00006840 00000022 UNINITIALIZED
00006840 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm2RegsFile)
EPwm3RegsFile
* 1 00006880 00000022 UNINITIALIZED
00006880 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm3RegsFile)
EPwm4RegsFile
* 1 000068c0 00000022 UNINITIALIZED
000068c0 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm4RegsFile)
EPwm5RegsFile
* 1 00006900 00000022 UNINITIALIZED
00006900 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm5RegsFile)
EPwm6RegsFile
* 1 00006940 00000022 UNINITIALIZED
00006940 00000022 DSP2833x_GlobalVariableDefs.obj (EPwm6RegsFile)
ECap1RegsFile
* 1 00006a00 00000020 UNINITIALIZED
00006a00 00000020 DSP2833x_GlobalVariableDefs.obj (ECap1RegsFile)
ECap2RegsFile
* 1 00006a20 00000020 UNINITIALIZED
00006a20 00000020 DSP2833x_GlobalVariableDefs.obj (ECap2RegsFile)
ECap3RegsFile
* 1 00006a40 00000020 UNINITIALIZED
00006a40 00000020 DSP2833x_GlobalVariableDefs.obj (ECap3RegsFile)
ECap4RegsFile
* 1 00006a60 00000020 UNINITIALIZED
00006a60 00000020 DSP2833x_GlobalVariableDefs.obj (ECap4RegsFile)
ECap5RegsFile
* 1 00006a80 00000020 UNINITIALIZED
00006a80 00000020 DSP2833x_GlobalVariableDefs.obj (ECap5RegsFile)
ECap6RegsFile
* 1 00006aa0 00000020 UNINITIALIZED
00006aa0 00000020 DSP2833x_GlobalVariableDefs.obj (ECap6RegsFile)
EQep1RegsFile
* 1 00006b00 00000040 UNINITIALIZED
00006b00 00000040 DSP2833x_GlobalVariableDefs.obj (EQep1RegsFile)
EQep2RegsFile
* 1 00006b40 00000040 UNINITIALIZED
00006b40 00000040 DSP2833x_GlobalVariableDefs.obj (EQep2RegsFile)
GpioCtrlRegsFile
* 1 00006f80 0000002e UNINITIALIZED
00006f80 0000002e DSP2833x_GlobalVariableDefs.obj (GpioCtrlRegsFile)
GpioDataRegsFile
* 1 00006fc0 00000020 UNINITIALIZED
00006fc0 00000020 DSP2833x_GlobalVariableDefs.obj (GpioDataRegsFile)
GpioIntRegsFile
* 1 00006fe0 0000000a UNINITIALIZED
00006fe0 0000000a DSP2833x_GlobalVariableDefs.obj (GpioIntRegsFile)
SysCtrlRegsFile
* 1 00007010 00000020 UNINITIALIZED
00007010 00000020 DSP2833x_GlobalVariableDefs.obj (SysCtrlRegsFile)
SpiaRegsFile
* 1 00007040 00000010 UNINITIALIZED
00007040 00000010 DSP2833x_GlobalVariableDefs.obj (SpiaRegsFile)
SciaRegsFile
* 1 00007050 00000010 UNINITIALIZED
00007050 00000010 DSP2833x_GlobalVariableDefs.obj (SciaRegsFile)
XIntruptRegsFile
* 1 00007070 00000010 UNINITIALIZED
00007070 00000010 DSP2833x_GlobalVariableDefs.obj (XIntruptRegsFile)
AdcRegsFile
* 1 00007100 0000001e UNINITIALIZED
00007100 0000001e DSP2833x_GlobalVariableDefs.obj (AdcRegsFile)
ScibRegsFile
* 1 00007750 00000010 UNINITIALIZED
00007750 00000010 DSP2833x_GlobalVariableDefs.obj (ScibRegsFile)
ScicRegsFile
* 1 00007770 00000010 UNINITIALIZED
00007770 00000010 DSP2833x_GlobalVariableDefs.obj (ScicRegsFile)
I2caRegsFile
* 1 00007900 00000022 UNINITIALIZED
00007900 00000022 DSP2833x_GlobalVariableDefs.obj (I2caRegsFile)
.ebss 1 0000a000 00004870 UNINITIALIZED
0000a000 00004850 40kW_60kHz_ai_RESET.obj (.ebss)
0000e850 00000018 DSP2833x_CpuTimers.obj (.ebss)
0000e868 00000004 rts2800_fpu32.lib : _lock.obj (.ebss)
0000e86c 00000004 : exit.obj (.ebss)
.econst 1 0000f990 00000100
0000f990 00000100 DSP2833x_PieVect.obj (.econst)
CsmPwlFile
* 1 0033fff8 00000008 UNINITIALIZED
0033fff8 00000008 DSP2833x_GlobalVariableDefs.obj (CsmPwlFile)
PartIdRegsFile
* 1 00380090 00000001 UNINITIALIZED
00380090 00000001 DSP2833x_GlobalVariableDefs.obj (PartIdRegsFile)
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address name
00008100 .text
000091c1 C$$EXIT
000091da FS$$DIV
00008a8f _ADCINT_ISR
00380080 _ADC_cal
00000b00 _AdcMirror
00007100 _AdcRegs
000090ab _ConfigCpuTimer
0000e860 _CpuTimer0
00000c00 _CpuTimer0Regs
0000e850 _CpuTimer1
00000c08 _CpuTimer1Regs
0000e858 _CpuTimer2
00000c10 _CpuTimer2Regs
0033fff8 _CsmPwl
00000ae0 _CsmRegs
00008f64 _CsmUnlock
000089bd _DATALOG_ISR
00008bb1 _DINTCH1_ISR
00008bbb _DINTCH2_ISR
00008bc5 _DINTCH3_ISR
00008bcf _DINTCH4_ISR
00008bd9 _DINTCH5_ISR
00008be3 _DINTCH6_ISR
0000803d _DSP28x_usDelay
00000880 _DevEmuRegs
00008eb3 _DisableDog
00001000 _DmaRegs
00008c3d _ECAN0INTA_ISR
00008c51 _ECAN0INTB_ISR
00008c47 _ECAN1INTA_ISR
00008c5b _ECAN1INTB_ISR
00008b25 _ECAP1_INT_ISR
00008b2f _ECAP2_INT_ISR
00008b39 _ECAP3_INT_ISR
00008b43 _ECAP4_INT_ISR
00008b4d _ECAP5_INT_ISR
00008b57 _ECAP6_INT_ISR
00006040 _ECanaLAMRegs
000060c0 _ECanaMOTORegs
00006080 _ECanaMOTSRegs
00006100 _ECanaMboxes
00006000 _ECanaRegs
00006240 _ECanbLAMRegs
000062c0 _ECanbMOTORegs
00006280 _ECanbMOTSRegs
00006300 _ECanbMboxes
00006200 _ECanbRegs
00006a00 _ECap1Regs
00006a20 _ECap2Regs
00006a40 _ECap3Regs
00006a60 _ECap4Regs
00006a80 _ECap5Regs
00006aa0 _ECap6Regs
000089d1 _EMUINT_ISR
00008ae9 _EPWM1_INT_ISR
00008aad _EPWM1_TZINT_ISR
00008af3 _EPWM2_INT_ISR
00008ab7 _EPWM2_TZINT_ISR
00008afd _EPWM3_INT_ISR
00008ac1 _EPWM3_TZINT_ISR
00008b07 _EPWM4_INT_ISR
00008acb _EPWM4_TZINT_ISR
00008b11 _EPWM5_INT_ISR
00008ad5 _EPWM5_TZINT_ISR
00008b1b _EPWM6_INT_ISR
00008adf _EPWM6_TZINT_ISR
00006800 _EPwm1Regs
00006840 _EPwm2Regs
00006880 _EPwm3Regs
000068c0 _EPwm4Regs
00006900 _EPwm5Regs
00006940 _EPwm6Regs
00008b61 _EQEP1_INT_ISR
00008b6b _EQEP2_INT_ISR
00006b00 _EQep1Regs
00006b40 _EQep2Regs
0000917f _EnableInterrupts
003ff0de _FPUatan2HalfPITable
003ff0e2 _FPUatan2Table
003ff268 _FPUatan2TableEnd
003fecdc _FPUcosTable
003ff0de _FPUcosTableEnd
003febdc _FPUsinTable
003fefdc _FPUsinTableEnd
00000a80 _FlashRegs
00006f80 _GpioCtrlRegs
00006fc0 _GpioDataRegs
00006fe0 _GpioIntRegs
00008bed _I2CINT1A_ISR
00008bf7 _I2CINT2A_ISR
00007900 _I2caRegs
000089e5 _ILLEGAL_ISR
000089a9 _INT13_ISR
000089b3 _INT14_ISR
003fead8 _IQ10mpyRndSatTable
003feacc _IQ11mpyRndSatTable
003feac0 _IQ12mpyRndSatTable
003feab4 _IQ13mpyRndSatTable
003feaa8 _IQ14mpyRndSatTable
003fea9c _IQ15mpyRndSatTable
003fea90 _IQ16mpyRndSatTable
003fea84 _IQ17mpyRndSatTable
003fea78 _IQ18mpyRndSatTable
003fea6c _IQ19mpyRndSatTable
003feb44 _IQ1mpyRndSatTable
003fea60 _IQ20mpyRndSatTable
003fea54 _IQ21mpyRndSatTable
003fea48 _IQ22mpyRndSatTable
003fea3c _IQ23mpyRndSatTable
003fea30 _IQ24mpyRndSatTable
003fea24 _IQ25mpyRndSatTable
003fea18 _IQ26mpyRndSatTable
003fea0c _IQ27mpyRndSatTable
003fea00 _IQ28mpyRndSatTable
003fe9f4 _IQ29mpyRndSatTable
003feb38 _IQ2mpyRndSatTable
003fe9e8 _IQ30mpyRndSatTable
003feb2c _IQ3mpyRndSatTable
003feb20 _IQ4mpyRndSatTable
003feb14 _IQ5mpyRndSatTable
003feb08 _IQ6mpyRndSatTable
003feafc _IQ7mpyRndSatTable
003feaf0 _IQ8mpyRndSatTable
003feae4 _IQ9mpyRndSatTable
003fe824 _IQatan2HalfPITable
003fe862 _IQatan2Table
003fe9e8 _IQatan2TableEnd
003fe100 _IQcosTable
003fe502 _IQcosTableEnd
003fe502 _IQdivRoundSatTable
003fe510 _IQdivTable
003fe712 _IQdivTableEnd
003fe712 _IQisqrtRoundSatTable
003fe722 _IQisqrtTable
003fe824 _IQisqrtTableEnd
003fe9e8 _IQmpyRndSatTable
003feb50 _IQmpyRndSatTableEnd
003fe000 _IQsinTable
003fe400 _IQsinTableEnd
003fe712 _IQsqrtRoundSatTable
003fe722 _IQsqrtTable
003fe824 _IQsqrtTableEnd
000091f3 _InitAdc
00009072 _InitCpuTimers
00008f95 _InitEPwm
00008d48 _InitEPwm1Example
00008fa3 _InitEPwm1Gpio
00008d85 _InitEPwm2
00008fcf _InitEPwm2Gpio
00008db9 _InitEPwm3
00008fdf _InitEPwm3Gpio
00008ff0 _InitEPwm4Gpio
00009004 _InitEPwm5Gpio
00009016 _InitEPwm6Gpio
00008f96 _InitEPwmGpio
00009028 _InitEPwmSyncGpio
00008022 _InitFlash
00008f09 _InitPeripheralClocks
00009160 _InitPieCtrl
00009188 _InitPieVectTable
00008ebb _InitPll
00008ea0 _InitSysCtrl
0000903c _InitTzGpio
00008e01 _InitVars
00008ca1 _LUF_ISR
00008c97 _LVF_ISR
00008b9d _MRINTA_ISR
00008b89 _MRINTB_ISR
00008ba7 _MXINTA_ISR
00008b93 _MXINTB_ISR
00008deb _Max_Min
00005000 _McbspaRegs
00005040 _McbspbRegs
000089db _NMI_ISR
0000a014 _NOT_pwm_enable
00008cab _PIE_RESERVED
00380090 _PartIdRegs
00000ce0 _PieCtrlRegs
00000d00 _PieVectTable
0000f990 _PieVectTableInit
000089c7 _RTOSINT_ISR
00008c15 _SCIRXINTA_ISR
00008c29 _SCIRXINTB_ISR
00008c01 _SCIRXINTC_ISR
00008c1f _SCITXINTA_ISR
00008c33 _SCITXINTB_ISR
00008c0b _SCITXINTC_ISR
00008a67 _SEQ1INT_ISR
00008a71 _SEQ2INT_ISR
00008b75 _SPIRXINTA_ISR
00008b7f _SPITXINTA_ISR
00007050 _SciaRegs
00007750 _ScibRegs
00007770 _ScicRegs
00008ea9 _ServiceDog
0000a048 _Sin45
0000a006 _SinAI_DC_in_ptr
00007040 _SpiaRegs
00007010 _SysCtrlRegs
00008a99 _TINT0_ISR
00008a49 _USER10_ISR
00008a53 _USER11_ISR
00008a5d _USER12_ISR
000089ef _USER1_ISR
000089f9 _USER2_ISR
00008a03 _USER3_ISR
00008a0d _USER4_ISR
00008a17 _USER5_ISR
00008a21 _USER6_ISR
00008a2b _USER7_ISR
00008a35 _USER8_ISR
00008a3f _USER9_ISR
00008aa3 _WAKEINT_ISR
00008a7b _XINT1_ISR
00008a85 _XINT2_ISR
00008c65 _XINT3_ISR
00008c6f _XINT4_ISR
00008c79 _XINT5_ISR
00008c83 _XINT6_ISR
00008c8d _XINT7_ISR
00007070 _XIntruptRegs
00000b20 _XintfRegs
00009218 __IQ29sin
00000700 __STACK_END
00000300 __STACK_SIZE
00000001 __TI_args_main
ffffffff ___binit__
ffffffff ___c_args__
00008000 ___cinit__
00009218 ___etext__
ffffffff ___pinit__
00008100 ___text__
000091a8 __args_main
0000e86c __cleanup_ptr
0000e86e __dtors_ptr
0000e86a __lock
0000920f __nop
0000920b __register_lock
00009207 __register_unlock
00000400 __stack
0000e868 __unlock
0000d880 _a
0000a00c _a_avg
0000b080 _ab
000091c1 _abort
0000a021 _activateAI
0000a01d _activateAI_noReset
0000a013 _adjust_sin_AI_dC
0000a026 _ai_Threshold
0000a028 _ai_wait
0000b880 _b
0000a00d _b_avg
0000a080 _bc
0000c880 _c
0000a016 _c_avg
000090e6 _c_int00
0000a880 _ca
0000a017 _cnt2
0000a005 _delay
0000a02e _epwm1_info
00008100 _epwm1_timer_isr
0000a032 _epwm2_info
0000a036 _epwm3_info
000091c3 _exit
0000a020 _flagAI
0000a019 _flag_out
0000a01f _gPioPossibleIsland
0000a002 _gainDC
0000a009 _hyster
0000a007 _in_dex
0000a001 _index_back1
0000a003 _index_back10
0000a00a _index_back2
0000a004 _index_frw1
0000a008 _j
00008cbf _main
0000a00f _max
0000a010 _min
0000a01a _offset45
0000a00b _out_dex
0000a01c _pwmOffInactive
0000a01b _reduce2
0000a018 _reduceDC
0000a01e _resetAIcode
0000a015 _resize
0000a012 _resize15Hz
0000a00e _resize_lut
00008cb5 _rsvd_ISR
0000a011 _select
0000912c _sin
0000a024 _sin45Out
0000a022 _sin45Out_lut
0000a040 _sin45_lut
0000a02c _start_AI
0000a000 _testgpio
0000a02a _timer_value2
ffffffff binit
00008000 cinit
00000000 code_start
00009218 etext
ffffffff pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
address name
00000000 code_start
00000400 __stack
00000a80 _FlashRegs
00000ae0 _CsmRegs
00000b00 _AdcMirror
00000b20 _XintfRegs
00001000 _DmaRegs
00006000 _ECanaRegs
00006200 _ECanbRegs
00006800 _EPwm1Regs
00006840 _EPwm2Regs
00006880 _EPwm3Regs
000068c0 _EPwm4Regs
00006900 _EPwm5Regs
00006940 _EPwm6Regs
00006a00 _ECap1Regs
00006a20 _ECap2Regs
00006a40 _ECap3Regs
00006a60 _ECap4Regs
00006a80 _ECap5Regs
00006aa0 _ECap6Regs
00006b00 _EQep1Regs
00006b40 _EQep2Regs
00007040 _SpiaRegs
00007050 _SciaRegs
00007100 _AdcRegs
00007750 _ScibRegs
00007770 _ScicRegs
00007900 _I2caRegs
00008000 ___cinit__
00008000 cinit
00008022 _InitFlash
00008100 .text
00008100 ___text__
000089a9 _INT13_ISR
000089b3 _INT14_ISR
000089db _NMI_ISR
000089ef _USER1_ISR
000089f9 _USER2_ISR
00008a03 _USER3_ISR
00008a0d _USER4_ISR
00008a17 _USER5_ISR
00008a21 _USER6_ISR
00008a2b _USER7_ISR
00008a35 _USER8_ISR
00008a3f _USER9_ISR
00008a7b _XINT1_ISR
00008a85 _XINT2_ISR
00008a99 _TINT0_ISR
00008c65 _XINT3_ISR
00008c6f _XINT4_ISR
00008c79 _XINT5_ISR
00008c83 _XINT6_ISR
00008c8d _XINT7_ISR
00008c97 _LVF_ISR
00008ca1 _LUF_ISR
00008cb5 _rsvd_ISR
00008cbf _main
00008d85 _InitEPwm2
00008db9 _InitEPwm3
00008deb _Max_Min
00008e01 _InitVars
00008ebb _InitPll
00008f64 _CsmUnlock
00008f95 _InitEPwm
000090e6 _c_int00
0000912c _sin
000091c1 C$$EXIT
000091c1 _abort
000091c3 _exit
000091da FS$$DIV
000091f3 _InitAdc
0000920f __nop
00009218 __IQ29sin
00009218 ___etext__
00009218 etext
0000a000 _testgpio
0000a002 _gainDC
0000a005 _delay
0000a007 _in_dex
0000a008 _j
0000a009 _hyster
0000a00b _out_dex
0000a00c _a_avg
0000a00d _b_avg
0000a00f _max
0000a010 _min
0000a011 _select
0000a015 _resize
0000a016 _c_avg
0000a017 _cnt2
0000a018 _reduceDC
0000a019 _flag_out
0000a01a _offset45
0000a01b _reduce2
0000a020 _flagAI
0000a024 _sin45Out
0000a028 _ai_wait
0000a02c _start_AI
0000a040 _sin45_lut
0000a048 _Sin45
0000a080 _bc
0000a880 _ca
0000b080 _ab
0000b880 _b
0000c880 _c
0000d880 _a
0000e850 _CpuTimer1
0000e858 _CpuTimer2
0000e860 _CpuTimer0
0000e868 __unlock
0000e86a __lock
0033fff8 _CsmPwl
00380080 _ADC_cal
ffffffff ___binit__
ffffffff ___pinit__
ffffffff binit
ffffffff pinit
[302 symbols]
Marco,
I would recommend taking a look at page 35 in the F28335 datasheet. It defines the memory map of the F28335.
http://www.ti.com/lit/ds/symlink/tms320f28335.pdf
Note that the range from 0x010000 to 0x010200 is Rsvd memory. The range from 0x00f990 to 0x00fb90 is fully in L7 SARAM.
Thank you,
Brett
