I have been getting this error for a while now. I have also checked the linker file and the .map file to see if there wire any discrepancies with what I was doing. I think everything seems to be ok(or maybe I might have missed something). I am also attaching my .cmd and .map file just so the forum members can get an idea of what is actually happening.
/* .cmd file */
MEMORY
PAGE 0 :
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
RAML0 : origin = 0x008000, length = 0x000800 /* on-chip RAM block L0 */
RAML1 : origin = 0x008800, length = 0x000400 /* on-chip RAM block L1 */
RAML3 : origin = 0x009000, length = 0x001000 /* on-chip RAM block L3 */
OTP : origin = 0x3D7800, length = 0x000400 /* on-chip OTP */
// FLASHH : origin = 0x3D8000, length = 0x004000 /* on-chip FLASH */
// FLASHG : origin = 0x3DC000, length = 0x004000 /* on-chip FLASH */
FLASHF : origin = 0x3D8000, length = 0x00C000 /* on-chip FLASH */
FLASHE : origin = 0x3E4000, length = 0x004000 /* on-chip FLASH */
FLASHD : origin = 0x3E8000, length = 0x004000 /* on-chip FLASH */
//FLASHC : origin = 0x3EC000, length = 0x004000 /* on-chip FLASH */
FLASHA : origin = 0x3EC000, length = 0x007F80 /* on-chip FLASH */
CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */
CSM_PWL_P0 : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */
FPUTABLES : origin = 0x3FD860, length = 0x000d40 /* FPU Tables in Boot ROM */
ROM : origin = 0x3FF3B0, length = 0x000C10 /* Boot ROM */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */
PAGE 1 : /* Data Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
/* Registers remain on PAGE1 */
BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */
RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAML2 : origin = 0x008C00, length = 0x000400 /* on-chip RAM block L2 */
RAML4 : origin = 0x00A000, length = 0x002000 /* on-chip RAM block L4 */
RAML5 : origin = 0x00C000, length = 0x002000 /* on-chip RAM block L5 */
RAML6 : origin = 0x00E000, length = 0x002000 /* on-chip RAM block L6 */
RAML7 : origin = 0x010000, length = 0x002000 /* on-chip RAM block L7 */
RAML8 : origin = 0x012000, length = 0x002000 /* on-chip RAM block L8 */
FLASHB : origin = 0x3F0000, length = 0x004000 /* on-chip FLASH */
/* Allocate sections to memory blocks.
Note:
codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
execution when booting to flash
ramfuncs user defined section to store functions that will be copied from Flash into RAM
SECTIONS
/* Allocate program areas: */
.cinit : > FLASHE, PAGE = 0
.pinit : > FLASHA, PAGE = 0
.text : > FLASHF, PAGE = 0
codestart : > BEGIN PAGE = 0
ramfuncs : LOAD = FLASHD,
RUN = RAML0,
LOAD_START(_RamfuncsLoadStart),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
PAGE = 0
csmpasswds : > CSM_PWL_P0 PAGE = 0
csm_rsvd : > CSM_RSVD PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM0 PAGE = 1
.ebss : > RAML4 PAGE = 1
.esysmem : > RAML2 PAGE = 1
/* Initalized sections to go in Flash */
/* For SDFlash to program these, they must be allocated to page 0 */
.econst : > FLASHE PAGE = 0
.switch : > FLASHE PAGE = 0
/* Allocate FPU math areas: */
FPUmathTables : LOAD = FPUTABLES
RUN = RAML3,
LOAD_START(_fputables_loadstart),
LOAD_END(_fputables_loadend),
RUN_START(_fputables_runstart),
PAGE = 0
DMARAML5 : > RAML5, PAGE = 1
DMARAML6 : > RAML6, PAGE = 1
DMARAML7 : > RAML7, PAGE = 1
DMARAML8 : > RAML8, PAGE = 1
/* DSECT */
.reset : > RESET, PAGE = 0, TYPE = DSECT
vectors : > VECTORS PAGE = 0, TYPE = DSECT
/* .map file */
TMS320C2000 Linker PC v18.1.1
>> Linked Mon Jul 9 09:33:37 2018
OUTPUT FILE NAME: <AHF_v1.35-AK PLL (solar) macro removed(5,7) - Fixed point.out>
ENTRY POINT SYMBOL: "_c_int00" address: 003db077
MEMORY CONFIGURATION
name origin length used unused attr fill
PAGE 0:
RAML0 00008000 00000800 0000001f 000007e1 RWIX
RAML1 00008800 00000400 00000000 00000400 RWIX
RAML3 00009000 00001000 000006a0 00000960 RWIX
OTP 003d7800 00000400 00000000 00000400 RWIX
FLASHF 003d8000 0000c000 000033a4 00008c5c RWIX
FLASHE 003e4000 00004000 0000042e 00003bd2 RWIX
FLASHD 003e8000 00004000 0000001f 00003fe1 RWIX
FLASHA 003ec000 00007f80 00000000 00007f80 RWIX
CSM_RSVD 003f7f80 00000076 00000000 00000076 RWIX
BEGIN 003f7ff6 00000002 00000002 00000000 RWIX
CSM_PWL_P0 003f7ff8 00000008 00000000 00000008 RWIX
FPUTABLES 003fd860 00000d40 000006a0 000006a0 RWIX
ROM 003ff3b0 00000c10 00000000 00000c10 RWIX
RESET 003fffc0 00000002 00000000 00000002 RWIX
VECTORS 003fffc2 0000003e 00000000 0000003e RWIX
PAGE 1:
BOOT_RSVD 00000000 00000050 00000000 00000050 RWIX
RAMM0 00000050 000003b0 00000300 000000b0 RWIX
RAMM1 00000400 00000400 00000000 00000400 RWIX
DEV_EMU 00000880 00000105 00000004 00000101 RWIX
SYS_PWR_CTL 00000985 00000003 00000003 00000000 RWIX
FLASH_REGS 00000a80 00000060 00000008 00000058 RWIX
CSM 00000ae0 00000020 00000010 00000010 RWIX
ADC_RESULT 00000b00 00000020 00000010 00000010 RWIX
CPU_TIMER0 00000c00 00000008 00000008 00000000 RWIX
CPU_TIMER1 00000c08 00000008 00000008 00000000 RWIX
CPU_TIMER2 00000c10 00000008 00000008 00000000 RWIX
PIE_CTRL 00000ce0 00000020 0000001a 00000006 RWIX
PIE_VECT 00000d00 00000100 00000100 00000000 RWIX
DMA 00001000 00000200 000000e0 00000120 RWIX
CLA1 00001400 00000080 00000040 00000040 RWIX
USB0 00004000 00001000 00000454 00000bac RWIX
McBSPA 00005000 00000040 00000024 0000001c RWIX
ECANA 00006000 00000040 00000034 0000000c RWIX
ECANA_LAM 00006040 00000040 00000040 00000000 RWIX
ECANA_MOTS 00006080 00000040 00000040 00000000 RWIX
ECANA_MOTO 000060c0 00000040 00000040 00000000 RWIX
ECANA_MBOX 00006100 00000100 00000100 00000000 RWIX
COMP1 00006400 00000020 00000007 00000019 RWIX
COMP2 00006420 00000020 00000007 00000019 RWIX
COMP3 00006440 00000020 00000007 00000019 RWIX
EPWM1 00006800 00000040 00000040 00000000 RWIX
EPWM2 00006840 00000040 00000040 00000000 RWIX
EPWM3 00006880 00000040 00000040 00000000 RWIX
EPWM4 000068c0 00000040 00000040 00000000 RWIX
EPWM5 00006900 00000040 00000040 00000000 RWIX
EPWM6 00006940 00000040 00000040 00000000 RWIX
EPWM7 00006980 00000040 00000040 00000000 RWIX
EPWM8 000069c0 00000040 00000040 00000000 RWIX
ECAP1 00006a00 00000020 00000020 00000000 RWIX
ECAP2 00006a20 00000020 00000020 00000000 RWIX
ECAP3 00006a40 00000020 00000020 00000000 RWIX
HRCAP1 00006ac0 00000020 0000001f 00000001 RWIX
HRCAP2 00006ae0 00000020 0000001f 00000001 RWIX
EQEP1 00006b00 00000040 00000022 0000001e RWIX
EQEP2 00006b40 00000040 00000022 0000001e RWIX
HRCAP3 00006c80 00000020 0000001f 00000001 RWIX
HRCAP4 00006ca0 00000020 0000001f 00000001 RWIX
GPIOCTRL 00006f80 00000040 00000040 00000000 RWIX
GPIODAT 00006fc0 00000020 00000020 00000000 RWIX
GPIOINT 00006fe0 00000020 00000020 00000000 RWIX
SYSTEM 00007010 00000030 00000030 00000000 RWIX
SPIA 00007040 00000010 00000010 00000000 RWIX
SCIA 00007050 00000010 00000010 00000000 RWIX
NMIINTRUPT 00007060 00000010 00000010 00000000 RWIX
XINTRUPT 00007070 00000010 00000010 00000000 RWIX
ADC 00007100 00000080 00000050 00000030 RWIX
SPIB 00007740 00000010 00000010 00000000 RWIX
SCIB 00007750 00000010 00000010 00000000 RWIX
I2CA 00007900 00000040 00000022 0000001e RWIX
RAML2 00008c00 00000400 00000000 00000400 RWIX
RAML4 0000a000 00002000 00001b7d 00000483 RWIX
RAML5 0000c000 00002000 00000000 00002000 RWIX
RAML6 0000e000 00002000 00000000 00002000 RWIX
RAML7 00010000 00002000 00000000 00002000 RWIX
RAML8 00012000 00002000 00000000 00002000 RWIX
PARTID 003d7e80 00000001 00000001 00000000 RWIX
FLASHB 003f0000 00004000 00000000 00004000 RWIX
CSM_PWL 003f7ff8 00000008 00000008 00000000 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.cinit 0 003e4000 000002f4
003e4000 00000126 Timer.obj (.cinit)
003e4126 000000dc Adc.obj (.cinit)
003e4202 000000a0 Modbus_slave.obj (.cinit)
003e42a2 00000028 SPI.obj (.cinit)
003e42ca 0000000e rts2800_fpu32.lib : exit.c.obj (.cinit)
003e42d8 0000000c 3Ph_RegisterMap.obj (.cinit)
003e42e4 00000005 rts2800_fpu32.lib : _lock.c.obj (.cinit:__lock)
003e42e9 00000005 : _lock.c.obj (.cinit:__unlock)
003e42ee 00000004 Main.obj (.cinit)
003e42f2 00000002 --HOLE-- [fill = 0]
.pinit 0 003ec000 00000000 UNINITIALIZED
.text 0 003d8000 000033a4
003d8000 00001057 Timer.obj (.text)
003d9057 000008bf 3Ph_RegisterMap.obj (.text)
003d9916 0000050b Modbus_slave.obj (.text)
003d9e21 000003a5 F2806x_DefaultIsr.obj (.text:retain)
003da1c6 000001d9 hal_SysCtrl_F2806x.obj (.text)
003da39f 000001b1 Dev_Init.obj (.text)
003da550 000001a7 Adc.obj (.text)
003da6f7 00000174 SPI.obj (.text)
003da86b 0000016c Adc.obj (.text:retain)
003da9d7 0000016a Main.obj (.text)
003dab41 00000139 PID_GRANDO_F.obj (.text)
003dac7a 00000107 Pwm.obj (.text)
003dad81 000000de Timer.obj (.text:retain)
003dae5f 000000d8 hal_EPwm_F2806x.obj (.text)
003daf37 000000c4 sci_confg.obj (.text:retain)
003daffb 0000007c hal_CpuTimers_F2806x.obj (.text)
003db077 00000056 rts2800_fpu32.lib : boot28.asm.obj (.text)
003db0cd 0000004c hal_spi_F2806x.obj (.text)
003db119 00000043 sincos_f32.obj (.text)
003db15c 00000042 Park_LPF.obj (.text)
003db19e 00000034 rts2800_fpu32_fast_supplement.lib : cos_f32.obj (.text)
003db1d2 00000034 : sin_f32.obj (.text)
003db206 00000032 sci_confg.obj (.text)
003db238 00000030 hal_Sci_F2806x.obj (.text)
003db268 00000029 rts2800_fpu32.lib : exit.c.obj (.text)
003db291 00000028 hal_PieCtrl_F2806x.obj (.text)
003db2b9 00000026 hal_PieVect_F2806x.obj (.text)
003db2df 00000024 rts2800_fpu32.lib : cpy_tbl.c.obj (.text)
003db303 00000021 rts2800_fpu32_fast_supplement.lib : sqrt_f32.obj (.text)
003db324 0000001e rts2800_fpu32.lib : memcpy.c.obj (.text)
003db342 0000001c isqrt_f32.obj (.text)
003db35e 00000019 rts2800_fpu32.lib : args_main.c.obj (.text)
003db377 00000019 rts2800_fpu32_fast_supplement.lib : div_f32.obj (.text)
003db390 00000009 rts2800_fpu32.lib : _lock.c.obj (.text)
003db399 00000008 F2806x_CodeStartBranch.obj (.text)
003db3a1 00000002 rts2800_fpu32.lib : pre_init.c.obj (.text)
003db3a3 00000001 : startup.c.obj (.text)
ramfuncs 0 003e8000 0000001f RUN ADDR = 00008000
003e8000 0000001b hal_SysCtrl_F2806x.obj (ramfuncs)
003e801b 00000004 hal_usDelay_F2806x.obj (ramfuncs)
codestart
* 0 003f7ff6 00000002
003f7ff6 00000002 F2806x_CodeStartBranch.obj (codestart)
.stack 1 00000050 00000300 UNINITIALIZED
00000050 00000300 --HOLE--
.ebss 1 0000a000 00001b7d UNINITIALIZED
0000a000 000015c4 Modbus_slave.obj (.ebss)
0000b5c4 00000018 hal_CpuTimers_F2806x.obj (.ebss)
0000b5dc 0000000e SPI.obj (.ebss)
0000b5ea 00000006 rts2800_fpu32.lib : exit.c.obj (.ebss)
0000b5f0 00000002 : _lock.c.obj (.ebss:__lock)
0000b5f2 00000002 : _lock.c.obj (.ebss:__unlock)
0000b5f4 0000000c --HOLE--
0000b600 000003e8 Main.obj (.ebss)
0000b9e8 00000018 --HOLE--
0000ba00 0000008c Timer.obj (.ebss)
0000ba8c 00000034 --HOLE--
0000bac0 00000066 Adc.obj (.ebss)
0000bb26 0000001a --HOLE--
0000bb40 0000003d 3Ph_RegisterMap.obj (.ebss)
.econst 0 003e42f4 00000100
003e42f4 00000100 hal_PieVect_F2806x.obj (.econst:_PieVectTableInit)
.switch 0 003e43f4 0000003a
003e43f4 0000003a 3Ph_RegisterMap.obj (.switch:_Write_Register)
FPUmathTables
* 0 003fd860 000006a0 RUN ADDR = 00009000
003fd860 000006a0 FPUmathTables.obj (FPUmathTables)
.reset 0 003fffc0 00000002 DSECT
003fffc0 00000002 rts2800_fpu32.lib : boot28.asm.obj (.reset)
vectors 0 003fffc2 00000000 DSECT
DevEmuRegsFile
* 1 00000880 00000004 UNINITIALIZED
00000880 00000004 F2806x_GlobalVariableDefs.obj (DevEmuRegsFile)
SysPwrCtrlRegsFile
* 1 00000985 00000003 UNINITIALIZED
00000985 00000003 F2806x_GlobalVariableDefs.obj (SysPwrCtrlRegsFile)
FlashRegsFile
* 1 00000a80 00000008 UNINITIALIZED
00000a80 00000008 F2806x_GlobalVariableDefs.obj (FlashRegsFile)
CsmRegsFile
* 1 00000ae0 00000010 UNINITIALIZED
00000ae0 00000010 F2806x_GlobalVariableDefs.obj (CsmRegsFile)
AdcResultFile
* 1 00000b00 00000010 UNINITIALIZED
00000b00 00000010 F2806x_GlobalVariableDefs.obj (AdcResultFile)
CpuTimer0RegsFile
* 1 00000c00 00000008 UNINITIALIZED
00000c00 00000008 F2806x_GlobalVariableDefs.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
* 1 00000c08 00000008 UNINITIALIZED
00000c08 00000008 F2806x_GlobalVariableDefs.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
* 1 00000c10 00000008 UNINITIALIZED
00000c10 00000008 F2806x_GlobalVariableDefs.obj (CpuTimer2RegsFile)
PieCtrlRegsFile
* 1 00000ce0 0000001a UNINITIALIZED
00000ce0 0000001a F2806x_GlobalVariableDefs.obj (PieCtrlRegsFile)
PieVectTableFile
* 1 00000d00 00000100 UNINITIALIZED
00000d00 00000100 F2806x_GlobalVariableDefs.obj (PieVectTableFile)
EmuKeyVar
* 1 00000d00 00000001 UNINITIALIZED
00000d00 00000001 F2806x_GlobalVariableDefs.obj (EmuKeyVar)
EmuBModeVar
* 1 00000d01 00000001 UNINITIALIZED
00000d01 00000001 F2806x_GlobalVariableDefs.obj (EmuBModeVar)
FlashCallbackVar
* 1 00000d02 00000002 UNINITIALIZED
00000d02 00000002 F2806x_GlobalVariableDefs.obj (FlashCallbackVar)
FlashScalingVar
* 1 00000d04 00000002 UNINITIALIZED
00000d04 00000002 F2806x_GlobalVariableDefs.obj (FlashScalingVar)
DmaRegsFile
* 1 00001000 000000e0 UNINITIALIZED
00001000 000000e0 F2806x_GlobalVariableDefs.obj (DmaRegsFile)
Cla1RegsFile
* 1 00001400 00000040 UNINITIALIZED
00001400 00000040 F2806x_GlobalVariableDefs.obj (Cla1RegsFile)
Usb0RegsFile
* 1 00004000 00000454 UNINITIALIZED
00004000 00000454 F2806x_GlobalVariableDefs.obj (Usb0RegsFile)
McbspaRegsFile
* 1 00005000 00000024 UNINITIALIZED
00005000 00000024 F2806x_GlobalVariableDefs.obj (McbspaRegsFile)
ECanaRegsFile
* 1 00006000 00000034 UNINITIALIZED
00006000 00000034 F2806x_GlobalVariableDefs.obj (ECanaRegsFile)
ECanaLAMRegsFile
* 1 00006040 00000040 UNINITIALIZED
00006040 00000040 F2806x_GlobalVariableDefs.obj (ECanaLAMRegsFile)
ECanaMOTSRegsFile
* 1 00006080 00000040 UNINITIALIZED
00006080 00000040 F2806x_GlobalVariableDefs.obj (ECanaMOTSRegsFile)
ECanaMOTORegsFile
* 1 000060c0 00000040 UNINITIALIZED
000060c0 00000040 F2806x_GlobalVariableDefs.obj (ECanaMOTORegsFile)
ECanaMboxesFile
* 1 00006100 00000100 UNINITIALIZED
00006100 00000100 F2806x_GlobalVariableDefs.obj (ECanaMboxesFile)
Comp1RegsFile
* 1 00006400 00000007 UNINITIALIZED
00006400 00000007 F2806x_GlobalVariableDefs.obj (Comp1RegsFile)
Comp2RegsFile
* 1 00006420 00000007 UNINITIALIZED
00006420 00000007 F2806x_GlobalVariableDefs.obj (Comp2RegsFile)
Comp3RegsFile
* 1 00006440 00000007 UNINITIALIZED
00006440 00000007 F2806x_GlobalVariableDefs.obj (Comp3RegsFile)
EPwm1RegsFile
* 1 00006800 00000040 UNINITIALIZED
00006800 00000040 F2806x_GlobalVariableDefs.obj (EPwm1RegsFile)
EPwm2RegsFile
* 1 00006840 00000040 UNINITIALIZED
00006840 00000040 F2806x_GlobalVariableDefs.obj (EPwm2RegsFile)
EPwm3RegsFile
* 1 00006880 00000040 UNINITIALIZED
00006880 00000040 F2806x_GlobalVariableDefs.obj (EPwm3RegsFile)
EPwm4RegsFile
* 1 000068c0 00000040 UNINITIALIZED
000068c0 00000040 F2806x_GlobalVariableDefs.obj (EPwm4RegsFile)
EPwm5RegsFile
* 1 00006900 00000040 UNINITIALIZED
00006900 00000040 F2806x_GlobalVariableDefs.obj (EPwm5RegsFile)
EPwm6RegsFile
* 1 00006940 00000040 UNINITIALIZED
00006940 00000040 F2806x_GlobalVariableDefs.obj (EPwm6RegsFile)
EPwm7RegsFile
* 1 00006980 00000040 UNINITIALIZED
00006980 00000040 F2806x_GlobalVariableDefs.obj (EPwm7RegsFile)
EPwm8RegsFile
* 1 000069c0 00000040 UNINITIALIZED
000069c0 00000040 F2806x_GlobalVariableDefs.obj (EPwm8RegsFile)
ECap1RegsFile
* 1 00006a00 00000020 UNINITIALIZED
00006a00 00000020 F2806x_GlobalVariableDefs.obj (ECap1RegsFile)
ECap2RegsFile
* 1 00006a20 00000020 UNINITIALIZED
00006a20 00000020 F2806x_GlobalVariableDefs.obj (ECap2RegsFile)
ECap3RegsFile
* 1 00006a40 00000020 UNINITIALIZED
00006a40 00000020 F2806x_GlobalVariableDefs.obj (ECap3RegsFile)
HRCap1RegsFile
* 1 00006ac0 0000001f UNINITIALIZED
00006ac0 0000001f F2806x_GlobalVariableDefs.obj (HRCap1RegsFile)
HRCap2RegsFile
* 1 00006ae0 0000001f UNINITIALIZED
00006ae0 0000001f F2806x_GlobalVariableDefs.obj (HRCap2RegsFile)
EQep1RegsFile
* 1 00006b00 00000022 UNINITIALIZED
00006b00 00000022 F2806x_GlobalVariableDefs.obj (EQep1RegsFile)
EQep2RegsFile
* 1 00006b40 00000022 UNINITIALIZED
00006b40 00000022 F2806x_GlobalVariableDefs.obj (EQep2RegsFile)
HRCap3RegsFile
* 1 00006c80 0000001f UNINITIALIZED
00006c80 0000001f F2806x_GlobalVariableDefs.obj (HRCap3RegsFile)
HRCap4RegsFile
* 1 00006ca0 0000001f UNINITIALIZED
00006ca0 0000001f F2806x_GlobalVariableDefs.obj (HRCap4RegsFile)
GpioCtrlRegsFile
* 1 00006f80 00000040 UNINITIALIZED
00006f80 00000040 F2806x_GlobalVariableDefs.obj (GpioCtrlRegsFile)
GpioDataRegsFile
* 1 00006fc0 00000020 UNINITIALIZED
00006fc0 00000020 F2806x_GlobalVariableDefs.obj (GpioDataRegsFile)
GpioIntRegsFile
* 1 00006fe0 00000020 UNINITIALIZED
00006fe0 00000020 F2806x_GlobalVariableDefs.obj (GpioIntRegsFile)
SysCtrlRegsFile
* 1 00007010 00000030 UNINITIALIZED
00007010 00000030 F2806x_GlobalVariableDefs.obj (SysCtrlRegsFile)
SpiaRegsFile
* 1 00007040 00000010 UNINITIALIZED
00007040 00000010 F2806x_GlobalVariableDefs.obj (SpiaRegsFile)
SciaRegsFile
* 1 00007050 00000010 UNINITIALIZED
00007050 00000010 F2806x_GlobalVariableDefs.obj (SciaRegsFile)
NmiIntruptRegsFile
* 1 00007060 00000010 UNINITIALIZED
00007060 00000010 F2806x_GlobalVariableDefs.obj (NmiIntruptRegsFile)
XIntruptRegsFile
* 1 00007070 00000010 UNINITIALIZED
00007070 00000010 F2806x_GlobalVariableDefs.obj (XIntruptRegsFile)
AdcRegsFile
* 1 00007100 00000050 UNINITIALIZED
00007100 00000050 F2806x_GlobalVariableDefs.obj (AdcRegsFile)
SpibRegsFile
* 1 00007740 00000010 UNINITIALIZED
00007740 00000010 F2806x_GlobalVariableDefs.obj (SpibRegsFile)
ScibRegsFile
* 1 00007750 00000010 UNINITIALIZED
00007750 00000010 F2806x_GlobalVariableDefs.obj (ScibRegsFile)
I2caRegsFile
* 1 00007900 00000022 UNINITIALIZED
00007900 00000022 F2806x_GlobalVariableDefs.obj (I2caRegsFile)
PartIdRegsFile
* 1 003d7e80 00000001 UNINITIALIZED
003d7e80 00000001 F2806x_GlobalVariableDefs.obj (PartIdRegsFile)
CsmPwlFile
* 1 003f7ff8 00000008 UNINITIALIZED
003f7ff8 00000008 F2806x_GlobalVariableDefs.obj (CsmPwlFile)
MODULE SUMMARY
Module code initialized data uninitialized data
.\Source File\
F2806x_GlobalVariableDefs.obj 0 0 3507
F2806x_DefaultIsr.obj 933 0 0
F2806x_CodeStartBranch.obj 10 0 0
hal_usDelay_F2806x.obj 8 0 0
Total: 951 0 3507
.\Source File\APPI\
Modbus_slave.obj 1291 160 5572
Timer.obj 4405 294 140
3Ph_RegisterMap.obj 2239 70 61
Adc.obj 787 220 102
Dev_Init.obj 433 0 0
SPI.obj 372 40 14
PID_GRANDO_F.obj 313 0 0
Pwm.obj 263 0 0
sci_confg.obj 246 0 0
Park_LPF.obj 66 0 0
Total: 10415 784 5889
.\Source File\FPU math fast rts library\source\
FPUmathTables.obj 0 3392 0
sincos_f32.obj 67 0 0
isqrt_f32.obj 28 0 0
Total: 95 3392 0
.\Source File\MAIN\
Main.obj 362 4 1000
Total: 362 4 1000
.\Source File\hal\
hal_SysCtrl_F2806x.obj 527 0 0
hal_PieVect_F2806x.obj 38 256 0
hal_EPwm_F2806x.obj 216 0 0
hal_CpuTimers_F2806x.obj 124 0 24
hal_spi_F2806x.obj 76 0 0
hal_Sci_F2806x.obj 48 0 0
hal_PieCtrl_F2806x.obj 40 0 0
Total: 1069 256 24
../Source File/FPU math fast rts library/lib/rts2800_fpu32_fast_supplement.lib
cos_f32.obj 52 0 0
sin_f32.obj 52 0 0
sqrt_f32.obj 33 0 0
div_f32.obj 25 0 0
Total: 162 0 0
C:/ti/ccsv8/tools/compiler/ti-cgt-c2000_18.1.1.LTS/lib/rts2800_fpu32.lib
boot28.asm.obj 86 0 0
exit.c.obj 41 14 6
cpy_tbl.c.obj 36 0 0
memcpy.c.obj 30 0 0
args_main.c.obj 25 0 0
_lock.c.obj 9 10 4
pre_init.c.obj 2 0 0
startup.c.obj 1 0 0
Total: 230 24 10
Stack: 0 0 768
Grand Total: 13284 4460 11198
GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
address data page name
00000050 1 (00000040) __stack
00000880 22 (00000880) _DevEmuRegs
00000985 26 (00000980) _SysPwrCtrlRegs
00000a80 2a (00000a80) _FlashRegs
00000ae0 2b (00000ac0) _CsmRegs
00000b00 2c (00000b00) _AdcResult
00000c00 30 (00000c00) _CpuTimer0Regs
00000c08 30 (00000c00) _CpuTimer1Regs
00000c10 30 (00000c00) _CpuTimer2Regs
00000ce0 33 (00000cc0) _PieCtrlRegs
00000d00 34 (00000d00) _EmuKey
00000d00 34 (00000d00) _PieVectTable
00000d01 34 (00000d00) _EmuBMode
00000d02 34 (00000d00) _Flash_CallbackPtr
00000d04 34 (00000d00) _Flash_CPUScaleFactor
00001000 40 (00001000) _DmaRegs
00001400 50 (00001400) _Cla1Regs
00004000 100 (00004000) _Usb0Regs
00005000 140 (00005000) _McbspaRegs
00006000 180 (00006000) _ECanaRegs
00006040 181 (00006040) _ECanaLAMRegs
00006080 182 (00006080) _ECanaMOTSRegs
000060c0 183 (000060c0) _ECanaMOTORegs
00006100 184 (00006100) _ECanaMboxes
00006400 190 (00006400) _Comp1Regs
00006420 190 (00006400) _Comp2Regs
00006440 191 (00006440) _Comp3Regs
00006800 1a0 (00006800) _EPwm1Regs
00006840 1a1 (00006840) _EPwm2Regs
00006880 1a2 (00006880) _EPwm3Regs
000068c0 1a3 (000068c0) _EPwm4Regs
00006900 1a4 (00006900) _EPwm5Regs
00006940 1a5 (00006940) _EPwm6Regs
00006980 1a6 (00006980) _EPwm7Regs
000069c0 1a7 (000069c0) _EPwm8Regs
00006a00 1a8 (00006a00) _ECap1Regs
00006a20 1a8 (00006a00) _ECap2Regs
00006a40 1a9 (00006a40) _ECap3Regs
00006ac0 1ab (00006ac0) _HRCap1Regs
00006ae0 1ab (00006ac0) _HRCap2Regs
00006b00 1ac (00006b00) _EQep1Regs
00006b40 1ad (00006b40) _EQep2Regs
00006c80 1b2 (00006c80) _HRCap3Regs
00006ca0 1b2 (00006c80) _HRCap4Regs
00006f80 1be (00006f80) _GpioCtrlRegs
00006fc0 1bf (00006fc0) _GpioDataRegs
00006fe0 1bf (00006fc0) _GpioIntRegs
00007010 1c0 (00007000) _SysCtrlRegs
00007040 1c1 (00007040) _SpiaRegs
00007050 1c1 (00007040) _SciaRegs
00007060 1c1 (00007040) _NmiIntruptRegs
00007070 1c1 (00007040) _XIntruptRegs
00007100 1c4 (00007100) _AdcRegs
00007740 1dd (00007740) _SpibRegs
00007750 1dd (00007740) _ScibRegs
00007900 1e4 (00007900) _I2caRegs
00009000 240 (00009000) _FPUsinTable
00009100 244 (00009100) _FPUcosTable
00009400 250 (00009400) _FPUsinTableEnd
00009502 254 (00009500) _FPUatan2HalfPITable
00009502 254 (00009500) _FPUcosTableEnd
00009506 254 (00009500) _FPUatan2Table
0000968c 25a (00009680) _FPUatan2TableEnd
0000a000 280 (0000a000) _sb
0000a001 280 (0000a000) _crc3b
0000a002 280 (0000a000) _rb
0000a003 280 (0000a000) _crc2b
0000a004 280 (0000a000) _add_modb
0000a005 280 (0000a000) _slave_id_nosb
0000a006 280 (0000a000) _slave_id_nosa
0000a007 280 (0000a000) _new_frame_get2
0000a008 280 (0000a000) _new_frame_get
0000a009 280 (0000a000) _crc1b
0000a00a 280 (0000a000) _pb
0000a00b 280 (0000a000) _fun_codeb
0000a00c 280 (0000a000) _add_mod
0000a00d 280 (0000a000) _data_bytes
0000a00e 280 (0000a000) _data_writeb
0000a00f 280 (0000a000) _data_byteb
0000a010 280 (0000a000) _start_addb
0000a011 280 (0000a000) _mod_data
0000a012 280 (0000a000) _no_of_parametera
0000a013 280 (0000a000) _rx_counterb
0000a014 280 (0000a000) _fun_code
0000a015 280 (0000a000) _tx_byteb
0000a016 280 (0000a000) _tx_bytea
0000a017 280 (0000a000) _qb
0000a018 280 (0000a000) _ib
0000a019 280 (0000a000) _data_write
0000a01a 280 (0000a000) _rx_countera
0000a01b 280 (0000a000) _data_byte
0000a01c 280 (0000a000) _start_add
0000a01d 280 (0000a000) _data_tx2_ok
0000a01e 280 (0000a000) _data_tx_ok
0000a01f 280 (0000a000) _data_bytesb
0000a020 280 (0000a000) _data_bytesa
0000a021 280 (0000a000) _txqb
0000a022 280 (0000a000) _txqa
0000a023 280 (0000a000) _timera
0000a024 280 (0000a000) _timerb
0000a040 281 (0000a040) _serial_fifo_bufb
0000a080 282 (0000a080) _serial_fifo_buf_txb
0000a0c0 283 (0000a0c0) _serial_fifo_buf_txa
0000a100 284 (0000a100) _serial_fifo_bufa
0000a140 285 (0000a140) _ahfdata_read
0000a5c0 297 (0000a5c0) _ahfdata
0000b5c4 2d7 (0000b5c0) _CpuTimer1
0000b5cc 2d7 (0000b5c0) _CpuTimer2
0000b5d4 2d7 (0000b5c0) _CpuTimer0
0000b5dc 2d7 (0000b5c0) _spi_index
0000b5dd 2d7 (0000b5c0) _spi_transmit_delay
0000b5de 2d7 (0000b5c0) _spi_rcvd_data
0000b5df 2d7 (0000b5c0) _alt_fo_counter
0000b5e0 2d7 (0000b5c0) _send_attempt
0000b5e1 2d7 (0000b5c0) _sdata
0000b5e2 2d7 (0000b5c0) _rdata
0000b5e3 2d7 (0000b5c0) _final_spi_crc
0000b5e4 2d7 (0000b5c0) _temp_delay
0000b5e5 2d7 (0000b5c0) _spi_crc
0000b5e6 2d7 (0000b5c0) _read_hbdata
0000b5e7 2d7 (0000b5c0) _read_data1
0000b5e8 2d7 (0000b5c0) _baud_rate
0000b5e9 2d7 (0000b5c0) _read_lbdata
0000b5ea 2d7 (0000b5c0) ___TI_enable_exit_profile_output
0000b5ec 2d7 (0000b5c0) ___TI_cleanup_ptr
0000b5ee 2d7 (0000b5c0) ___TI_dtors_ptr
0000b5f0 2d7 (0000b5c0) __lock
0000b5f2 2d7 (0000b5c0) __unlock
0000b600 2d8 (0000b600) _comm_toggle
0000b602 2d8 (0000b600) _l5
0000b61e 2d8 (0000b600) _l7
0000b640 2d9 (0000b640) _inv_current
0000b65c 2d9 (0000b640) _load_current
0000b680 2da (0000b680) _i11
0000b69c 2da (0000b680) _l11
0000b6c0 2db (0000b6c0) _i7
0000b6dc 2db (0000b6c0) _i13
0000b700 2dc (0000b700) _i5
0000b71c 2dc (0000b700) _l13
0000b740 2dd (0000b740) _pid_iq5
0000b780 2de (0000b780) _pid_id7
0000b7c0 2df (0000b7c0) _pid_id5
0000b800 2e0 (0000b800) _pid_id
0000b840 2e1 (0000b840) _pid_iq
0000b880 2e2 (0000b880) _pid_id13
0000b8c0 2e3 (0000b8c0) _pid_iq13
0000b900 2e4 (0000b900) _pid_iq11
0000b940 2e5 (0000b940) _pid_iq7
0000b980 2e6 (0000b980) _pid_id11
0000b9c0 2e7 (0000b9c0) _pid_dcbus
0000ba00 2e8 (0000ba00) _vp_cn
0000ba01 2e8 (0000ba00) _vp_bn
0000ba02 2e8 (0000ba00) _phase_corr
0000ba03 2e8 (0000ba00) _rms_vc
0000ba04 2e8 (0000ba00) _rms_bn
0000ba05 2e8 (0000ba00) _rms_an
0000ba06 2e8 (0000ba00) _rms_count
0000ba07 2e8 (0000ba00) _dc_link_count
0000ba08 2e8 (0000ba00) _rms_vb
0000ba09 2e8 (0000ba00) _rms_va
0000ba0a 2e8 (0000ba00) _vp_b
0000ba0b 2e8 (0000ba00) _vp_a
0000ba0c 2e8 (0000ba00) _vp_an
0000ba0d 2e8 (0000ba00) _vp_c
0000ba0e 2e8 (0000ba00) _start_inverter_flag
0000ba0f 2e8 (0000ba00) _rms_cn
0000ba10 2e8 (0000ba00) _msec_timer
0000ba11 2e8 (0000ba00) _sec1timer
0000ba12 2e8 (0000ba00) _ld13_filter
0000ba14 2e8 (0000ba00) _lq11_filter
0000ba16 2e8 (0000ba00) _lq13_filter
0000ba18 2e8 (0000ba00) _iq11_filter
0000ba1a 2e8 (0000ba00) _id11_filter
0000ba1c 2e8 (0000ba00) _iq13_filter
0000ba1e 2e8 (0000ba00) _id13_filter
0000ba20 2e8 (0000ba00) _ld11_filter
0000ba22 2e8 (0000ba00) _ibeta_inj7
0000ba24 2e8 (0000ba00) _ialpha_inj11
0000ba26 2e8 (0000ba00) _ialpha_inj7
0000ba28 2e8 (0000ba00) _ialpha_inj5
0000ba2a 2e8 (0000ba00) _ibeta_inj5
0000ba2c 2e8 (0000ba00) _ibeta_inj
0000ba2e 2e8 (0000ba00) _to_deg
0000ba30 2e8 (0000ba00) _to
0000ba32 2e8 (0000ba00) _ialpha_inj13
0000ba34 2e8 (0000ba00) _ibeta_inj13
0000ba36 2e8 (0000ba00) _ibeta_inj11
0000ba38 2e8 (0000ba00) _ld1_filter
0000ba3a 2e8 (0000ba00) _lq1_filter
0000ba3c 2e8 (0000ba00) _dc_filter_old
0000ba3e 2e8 (0000ba00) _dc_filter
0000ba40 2e9 (0000ba40) _dc_link_old
0000ba42 2e9 (0000ba40) _iq7_filter
0000ba44 2e9 (0000ba40) _ld5_filter
0000ba46 2e9 (0000ba40) _id5_filter
0000ba48 2e9 (0000ba40) _id1_filter
0000ba4a 2e9 (0000ba40) _iq1_filter
0000ba4c 2e9 (0000ba40) _k6
0000ba4e 2e9 (0000ba40) _id7_filter
0000ba50 2e9 (0000ba40) _r_va
0000ba52 2e9 (0000ba40) _iq5_filter
0000ba54 2e9 (0000ba40) _ld7_filter
0000ba56 2e9 (0000ba40) _lq5_filter
0000ba58 2e9 (0000ba40) _k5
0000ba5a 2e9 (0000ba40) _Tj
0000ba5c 2e9 (0000ba40) _wc
0000ba5e 2e9 (0000ba40) _r_vb
0000ba60 2e9 (0000ba40) _r_vc
0000ba62 2e9 (0000ba40) _lq7_filter
0000ba64 2e9 (0000ba40) _c_cl5
0000ba66 2e9 (0000ba40) _s_cl7
0000ba68 2e9 (0000ba40) _pi_vd
0000ba6a 2e9 (0000ba40) _s_cl5
0000ba6c 2e9 (0000ba40) _c_cl7
0000ba6e 2e9 (0000ba40) _s_cl13
0000ba70 2e9 (0000ba40) _pi_id11
0000ba72 2e9 (0000ba40) _s_cl11
0000ba74 2e9 (0000ba40) _c_cl13
0000ba76 2e9 (0000ba40) _pi_iq13
0000ba78 2e9 (0000ba40) _ialpha_inj
0000ba7a 2e9 (0000ba40) _pi_iq11
0000ba7c 2e9 (0000ba40) _pi_id13
0000ba7e 2e9 (0000ba40) _pi_id5
0000ba80 2ea (0000ba80) _pi_iq5
0000ba82 2ea (0000ba80) _pi_id
0000ba84 2ea (0000ba80) _pi_iq
0000ba86 2ea (0000ba80) _pi_iq7
0000ba88 2ea (0000ba80) _c_cl11
0000ba8a 2ea (0000ba80) _pi_id7
0000bac0 2eb (0000bac0) _dc_link
0000bac1 2eb (0000bac0) _rl_i
0000bac2 2eb (0000bac0) _y_i
0000bac3 2eb (0000bac0) _b_i
0000bac4 2eb (0000bac0) _rl_s
0000bac5 2eb (0000bac0) _yl_s
0000bac6 2eb (0000bac0) _yl_i
0000bac7 2eb (0000bac0) _y_v
0000bac8 2eb (0000bac0) _b_v
0000bac9 2eb (0000bac0) _count_theta
0000baca 2eb (0000bac0) _r_v
0000bacb 2eb (0000bac0) _r_i
0000bacc 2eb (0000bac0) _bl_i
0000bacd 2eb (0000bac0) _theta_scaled
0000bace 2eb (0000bac0) _dc_v
0000bacf 2eb (0000bac0) _y_o_v_s
0000bad0 2eb (0000bac0) _b_o_v_s
0000bad1 2eb (0000bac0) _rms_ic
0000bad2 2eb (0000bac0) _r_o_v_s
0000bad3 2eb (0000bac0) _do_rms_flag
0000bad4 2eb (0000bac0) _dc_loop_count
0000bad5 2eb (0000bac0) _init_duty_flag
0000bad6 2eb (0000bac0) _vx
0000bad7 2eb (0000bac0) _vy
0000bad8 2eb (0000bac0) _bl_s
0000bad9 2eb (0000bac0) _car_offset
0000bada 2eb (0000bac0) _rms_ib
0000badb 2eb (0000bac0) _inv_last_flag
0000badc 2eb (0000bac0) _vz
0000badd 2eb (0000bac0) _rms_ia
0000bade 2eb (0000bac0) _start_pll
0000badf 2eb (0000bac0) _rgen_s
0000bae0 2eb (0000bac0) _THREE_V
0000bae1 2eb (0000bac0) _count_buf_dc_v
0000bae2 2eb (0000bac0) _bgen_s
0000bae3 2eb (0000bac0) _ygen_s
0000bae4 2eb (0000bac0) _ibeta_load
0000bae6 2eb (0000bac0) _bo
0000bae8 2eb (0000bac0) _b1
0000baea 2eb (0000bac0) _f
0000baec 2eb (0000bac0) _vrx
0000baee 2eb (0000bac0) _ialpha_load
0000baf0 2eb (0000bac0) _vbx
0000baf2 2eb (0000bac0) _ialpha_inv
0000baf4 2eb (0000bac0) _tv
0000baf6 2eb (0000bac0) _vyx
0000baf8 2eb (0000bac0) _vqx
0000bafa 2eb (0000bac0) _pi
0000bafc 2eb (0000bac0) _y_o_v
0000bafe 2eb (0000bac0) _r_o_v
0000bb00 2ec (0000bb00) _avg_dc_v
0000bb02 2ec (0000bb00) _buf_dc_link
0000bb04 2ec (0000bb00) _grid_freq
0000bb06 2ec (0000bb00) _buf_dc_v
0000bb08 2ec (0000bb00) _v_beta
0000bb0a 2ec (0000bb00) _vd
0000bb0c 2ec (0000bb00) _dc_link_voltage_scaled
0000bb0e 2ec (0000bb00) _v_alpha
0000bb10 2ec (0000bb00) _vdx
0000bb12 2ec (0000bb00) _b_o_v
0000bb14 2ec (0000bb00) _c_x
0000bb16 2ec (0000bb00) _s_x
0000bb18 2ec (0000bb00) _ibeta_inv
0000bb1a 2ec (0000bb00) _vq
0000bb1e 2ec (0000bb00) _theta
0000bb22 2ec (0000bb00) _lf
0000bb40 2ed (0000bb40) _write_data
0000bb41 2ed (0000bb40) _ki_id7
0000bb42 2ed (0000bb40) _ki_id11
0000bb43 2ed (0000bb40) _kp_id11
0000bb44 2ed (0000bb40) _kp_id5
0000bb45 2ed (0000bb40) _ki_vd
0000bb46 2ed (0000bb40) _kp_id7
0000bb47 2ed (0000bb40) _mul_pi_vd
0000bb48 2ed (0000bb40) _mul_pi_iq
0000bb49 2ed (0000bb40) _mul_iq
0000bb4a 2ed (0000bb40) _mul_id
0000bb4b 2ed (0000bb40) _kp_id13
0000bb4c 2ed (0000bb40) _ki_id5
0000bb4d 2ed (0000bb40) _mul_pi_id
0000bb4e 2ed (0000bb40) _lead_lag
0000bb4f 2ed (0000bb40) _graph_range
0000bb50 2ed (0000bb40) _inv_start
0000bb51 2ed (0000bb40) _inv_mi
0000bb52 2ed (0000bb40) _harmonic_comp
0000bb53 2ed (0000bb40) _harmonic_gain
0000bb54 2ed (0000bb40) _amp
0000bb55 2ed (0000bb40) _ki_id
0000bb56 2ed (0000bb40) _kp_id
0000bb57 2ed (0000bb40) _ki_id13
0000bb58 2ed (0000bb40) _kp_vd
0000bb59 2ed (0000bb40) _v_ref
0000bb5a 2ed (0000bb40) _inject_type
0000bb5b 2ed (0000bb40) _id_ref
0000bb5c 2ed (0000bb40) _mul_ld11
0000bb5d 2ed (0000bb40) _mul_pi_iq13
0000bb5e 2ed (0000bb40) _mul_ld13
0000bb5f 2ed (0000bb40) _mul_lq11
0000bb60 2ed (0000bb40) _mul_pi_id11
0000bb61 2ed (0000bb40) _mul_pi_iq7
0000bb62 2ed (0000bb40) _mul_pi_id13
0000bb63 2ed (0000bb40) _mul_iq13
0000bb64 2ed (0000bb40) _mul_id13
0000bb65 2ed (0000bb40) _mul_lq13
0000bb66 2ed (0000bb40) _mul_pi_iq11
0000bb67 2ed (0000bb40) _mul_iq11
0000bb68 2ed (0000bb40) _mul_ld5
0000bb69 2ed (0000bb40) _mul_iq7
0000bb6a 2ed (0000bb40) _mul_ld7
0000bb6b 2ed (0000bb40) _mul_lq5
0000bb6c 2ed (0000bb40) _mul_id5
0000bb6d 2ed (0000bb40) _dc_voltage_gain
0000bb6e 2ed (0000bb40) _mul_id7
0000bb6f 2ed (0000bb40) _mul_pi_iq5
0000bb70 2ed (0000bb40) _mul_pi_id5
0000bb71 2ed (0000bb40) _mul_id11
0000bb72 2ed (0000bb40) _mul_pi_id7
0000bb73 2ed (0000bb40) _mul_lq7
0000bb74 2ed (0000bb40) _mul_iq5
0000bb75 2ed (0000bb40) _mul_lq1
0000bb76 2ed (0000bb40) _mul_ld1
0000bb77 2ed (0000bb40) _current_gain
0000bb78 2ed (0000bb40) _prog_ver_no
0000bb79 2ed (0000bb40) _voltage_gain
0000bb7a 2ed (0000bb40) _fx
0000bb7b 2ed (0000bb40) _fc
0000bb7c 2ed (0000bb40) _three_four_wire_sel
003d7e80 f5fa (003d7e80) _PartIdRegs
003e42f4 f90b (003e42c0) _PieVectTableInit
003f7ff8 fdff (003f7fc0) _CsmPwl
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
page address name
0 003d8000 .text
0 003db268 C$$EXIT
0 003db377 FS$$DIV
0 003d9edf _ADCINT1_ISR
0 003d9eec _ADCINT2_ISR
0 003da0f4 _ADCINT3_ISR
0 003da0fe _ADCINT4_ISR
0 003da108 _ADCINT5_ISR
0 003da112 _ADCINT6_ISR
0 003da11c _ADCINT7_ISR
0 003da126 _ADCINT8_ISR
0 003d9f0a _ADCINT9_ISR
0 003d9695 _AHF_data_clear
0 003da86b _AdcInt1Isr
1 00007100 _AdcRegs
1 00000b00 _AdcResult
0 003da130 _CLA1_INT1_ISR
0 003da141 _CLA1_INT2_ISR
0 003da14b _CLA1_INT3_ISR
0 003da155 _CLA1_INT4_ISR
0 003da15f _CLA1_INT5_ISR
0 003da169 _CLA1_INT6_ISR
0 003da173 _CLA1_INT7_ISR
0 003da17d _CLA1_INT8_ISR
1 00001400 _Cla1Regs
1 00006400 _Comp1Regs
1 00006420 _Comp2Regs
1 00006440 _Comp3Regs
0 003dac91 _ConfgEpwm1
0 003db206 _ConfgSci
0 003db21f _ConfgScib
0 003db036 _ConfigCpuTimer
1 0000b5d4 _CpuTimer0
1 00000c00 _CpuTimer0Regs
1 0000b5c4 _CpuTimer1
1 00000c08 _CpuTimer1Regs
1 0000b5cc _CpuTimer2
1 00000c10 _CpuTimer2Regs
1 003f7ff8 _CsmPwl
1 00000ae0 _CsmRegs
0 003da302 _CsmUnlock
0 003d9e35 _DATALOG_ISR
0 003da068 _DINTCH1_ISR
0 003da072 _DINTCH2_ISR
0 003da07c _DINTCH3_ISR
0 003da086 _DINTCH4_ISR
0 003da090 _DINTCH5_ISR
0 003da09a _DINTCH6_ISR
0 0000801b _DSP28x_usDelay
1 00000880 _DevEmuRegs
0 003da39f _Device_Init
0 003da223 _DisableDog
0 003d9a57 _DisableRS485Xmit
0 003d9a61 _DisableRS485Xmitb
1 00001000 _DmaRegs
0 003da0e0 _ECAN0INTA_ISR
0 003da0ea _ECAN1INTA_ISR
0 003d9fc8 _ECAP1_INT_ISR
0 003d9fd2 _ECAP2_INT_ISR
0 003d9fdc _ECAP3_INT_ISR
1 00006040 _ECanaLAMRegs
1 000060c0 _ECanaMOTORegs
1 00006080 _ECanaMOTSRegs
1 00006100 _ECanaMboxes
1 00006000 _ECanaRegs
1 00006a00 _ECap1Regs
1 00006a20 _ECap2Regs
1 00006a40 _ECap3Regs
0 003da1a5 _EMPTY_ISR
0 003d9e49 _EMUINT_ISR
0 003d9f78 _EPWM1_INT_ISR
0 003d9f28 _EPWM1_TZINT_ISR
0 003d9f82 _EPWM2_INT_ISR
0 003d9f32 _EPWM2_TZINT_ISR
0 003d9f8c _EPWM3_INT_ISR
0 003d9f3c _EPWM3_TZINT_ISR
0 003d9f96 _EPWM4_INT_ISR
0 003d9f46 _EPWM4_TZINT_ISR
0 003d9fa0 _EPWM5_INT_ISR
0 003d9f50 _EPWM5_TZINT_ISR
0 003d9faa _EPWM6_INT_ISR
0 003d9f5a _EPWM6_TZINT_ISR
0 003d9fb4 _EPWM7_INT_ISR
0 003d9f64 _EPWM7_TZINT_ISR
0 003d9fbe _EPWM8_INT_ISR
0 003d9f6e _EPWM8_TZINT_ISR
1 00006800 _EPwm1Regs
1 00006840 _EPwm2Regs
1 00006880 _EPwm3Regs
1 000068c0 _EPwm4Regs
1 00006900 _EPwm5Regs
1 00006940 _EPwm6Regs
1 00006980 _EPwm7Regs
1 000069c0 _EPwm8Regs
0 003d9ffa _EQEP1_INT_ISR
0 003da004 _EQEP2_INT_ISR
1 00006b00 _EQep1Regs
1 00006b40 _EQep2Regs
1 00000d01 _EmuBMode
1 00000d00 _EmuKey
0 003db2b0 _EnableInterrupts
0 003d9a52 _EnableRS485Xmit
0 003d9a5c _EnableRS485Xmitb
0 003d9a66 _Execute_serial_command
0 003d9c3b _Execute_serial_commandb
0 003da36b _ExtOscSel
0 00009502 _FPUatan2HalfPITable
0 00009506 _FPUatan2Table
0 0000968c _FPUatan2TableEnd
0 00009100 _FPUcosTable
0 00009502 _FPUcosTableEnd
0 00009000 _FPUsinTable
0 00009400 _FPUsinTableEnd
1 00000a80 _FlashRegs
1 00000d04 _Flash_CPUScaleFactor
1 00000d02 _Flash_CallbackPtr
0 003da3a8 _Flash_Init
1 00006f80 _GpioCtrlRegs
1 00006fc0 _GpioDataRegs
1 00006fe0 _GpioIntRegs
0 003da3ca _Gpio_Init
0 003d9fe6 _HRCAP1_INT_ISR
0 003d9ff0 _HRCAP2_INT_ISR
0 003da00e _HRCAP3_INT_ISR
0 003da018 _HRCAP4_INT_ISR
1 00006ac0 _HRCap1Regs
1 00006ae0 _HRCap2Regs
1 00006c80 _HRCap3Regs
1 00006ca0 _HRCap4Regs
0 003da0a4 _I2CINT1A_ISR
0 003da0ae _I2CINT2A_ISR
1 00007900 _I2caRegs
0 003d9e5d _ILLEGAL_ISR
0 003d9e21 _INT13_ISR
0 003d9e2b _INT14_ISR
0 003da550 _InitADC
0 003daffb _InitCpuTimers
0 003dae5f _InitEPwm
0 003dae71 _InitEPwm1Gpio
0 003dae83 _InitEPwm2Gpio
0 003dae95 _InitEPwm3Gpio
0 003daea9 _InitEPwm4Gpio
0 003daebd _InitEPwm5Gpio
0 003daecf _InitEPwm6Gpio
0 003daee1 _InitEPwm7Gpio
0 003daef3 _InitEPwm8Gpio
0 003dae60 _InitEPwmGpio
0 003daf05 _InitEPwmSyncGpio
0 00008000 _InitFlash
0 003dac7a _InitPWM
0 003da2ae _InitPeripheralClocks
0 003db291 _InitPieCtrl
0 003db2b9 _InitPieVectTable
0 003da22b _InitPll
0 003da280 _InitPll2
0 003db238 _InitSci
0 003db239 _InitSciGpio
0 003db23e _InitSciaGpio
0 003db254 _InitScibGpio
0 003db0cd _InitSpi
0 003db0ce _InitSpiGpio
0 003db0d3 _InitSpiaGpio
0 003db0f9 _InitSpibGpio
0 003da1c6 _InitSysCtrl
0 003daf16 _InitTzGpio
0 003da70c _Init_Spi_Dac
0 003da6f7 _Init_Spi_E2Prom
0 003dace6 _Init_inverter_pwm
0 003da333 _IntOsc1Sel
0 003da343 _IntOsc2Sel
0 003da3bf _Interrupt_Init
0 003da19b _LUF_ISR
0 003da191 _LVF_ISR
0 003da054 _MRINTA_ISR
0 003da05e _MXINTA_ISR
1 00005000 _McbspaRegs
0 003da381 _MemCopy
0 003d9e53 _NMI_ISR
1 00007060 _NmiIntruptRegs
0 003db15c _PARK_LPF_init
0 003dabaf _PID_GRANDO_F_FUNC
0 003dab41 _PID_GRANDO_F_init
0 003da1b2 _PIE_RESERVED
1 003d7e80 _PartIdRegs
1 00000ce0 _PieCtrlRegs
1 00000d00 _PieVectTable
0 003e42f4 _PieVectTableInit
0 003d986d _Power_On_Read_EEPROM
0 003d9e3f _RTOSINT_ISR
0 003e801f _RamfuncsLoadEnd
0 003e8000 _RamfuncsLoadStart
0 00008000 _RamfuncsRunStart
0 003d9057 _Read_holding_register
0 003d9100 _Read_input_register
0 003d995b _ReceiveSciaData
0 003d99e7 _ReceiveScibData
0 003da0b8 _SCIRXINTA_ISR
0 003da0cc _SCIRXINTB_ISR
0 003da0c2 _SCITXINTA_ISR
0 003da0d6 _SCITXINTB_ISR
0 003da02c _SPIRXINTA_ISR
0 003da040 _SPIRXINTB_ISR
0 003da036 _SPITXINTA_ISR
0 003da04a _SPITXINTB_ISR
1 00007050 _SciaRegs
0 003daf68 _SciaRxIsr
0 003daf37 _SciaTxIsr
1 00007750 _ScibRegs
0 003dafca _ScibRxIsr
0 003daf99 _ScibTxIsr
0 003da219 _ServiceDog
0 003da7ea _SpiFifoInit
0 003da7d8 _SpiInitGpio
0 003da805 _SpiSend
1 00007040 _SpiaRegs
0 003da854 _SpiaSend
1 00007740 _SpibRegs
1 00007010 _SysCtrlRegs
1 00000985 _SysPwrCtrlRegs
1 0000bae0 _THREE_V
0 003d9f14 _TINT0_ISR
1 0000ba5a _Tj
0 003da022 _USB0_INT_ISR
0 003d9ec1 _USER10_ISR
0 003d9ecb _USER11_ISR
0 003d9ed5 _USER12_ISR
0 003d9e67 _USER1_ISR
0 003d9e71 _USER2_ISR
0 003d9e7b _USER3_ISR
0 003d9e85 _USER4_ISR
0 003d9e8f _USER5_ISR
0 003d9e99 _USER6_ISR
0 003d9ea3 _USER7_ISR
0 003d9ead _USER8_ISR
0 003d9eb7 _USER9_ISR
1 00004000 _Usb0Regs
0 003d9f1e _WAKEINT_ISR
0 003da394 _WDogEnable
0 003d96b5 _Write_Register
0 003d9ef6 _XINT1_ISR
0 003d9f00 _XINT2_ISR
0 003da187 _XINT3_ISR
1 00007070 _XIntruptRegs
0 003d9939 _XmitSciaData
0 003d99c6 _XmitScibData
0 003da357 _XtalOscSel
1 00000350 __STACK_END
abs 00000300 __STACK_SIZE
1 0000b5ec ___TI_cleanup_ptr
1 0000b5ee ___TI_dtors_ptr
1 0000b5ea ___TI_enable_exit_profile_output
abs ffffffff ___TI_pprof_out_hndl
abs ffffffff ___TI_prof_data_size
abs ffffffff ___TI_prof_data_start
abs ffffffff ___binit__
abs ffffffff ___c_args__
0 003e4000 ___cinit__
0 003db3a4 ___etext__
abs ffffffff ___pinit__
0 003d8000 ___text__
0 003db35e __args_main
1 0000b5f0 __lock
0 003db398 __nop
0 003db394 __register_lock
0 003db390 __register_unlock
1 00000050 __stack
0 003db3a3 __system_post_cinit
0 003db3a1 __system_pre_init
1 0000b5f2 __unlock
0 003db268 _abort
1 0000a00c _add_mod
1 0000a004 _add_modb
1 0000a5c0 _ahfdata
1 0000a140 _ahfdata_read
1 0000b5df _alt_fo_counter
1 0000bb54 _amp
1 0000bb00 _avg_dc_v
1 0000bae8 _b1
1 0000bac3 _b_i
1 0000bb12 _b_o_v
1 0000bad0 _b_o_v_s
1 0000bac8 _b_v
1 0000b5e8 _baud_rate
1 0000bae2 _bgen_s
1 0000bacc _bl_i
1 0000bad8 _bl_s
1 0000bae6 _bo
1 0000bb02 _buf_dc_link
1 0000bb06 _buf_dc_v
1 0000ba88 _c_cl11
1 0000ba74 _c_cl13
1 0000ba64 _c_cl5
1 0000ba6c _c_cl7
0 003db077 _c_int00
1 0000bb14 _c_x
1 0000bad9 _car_offset
1 0000b600 _comm_toggle
0 003db2df _copy_in
0 003db19e _cos
1 0000bae1 _count_buf_dc_v
1 0000bac9 _count_theta
0 003dad81 _cpu_timer0_isr
0 003dae27 _cpu_timer1_isr
1 0000a009 _crc1b
1 0000a003 _crc2b
1 0000a001 _crc3b
1 0000bb77 _current_gain
1 0000a01b _data_byte
1 0000a00f _data_byteb
1 0000a00d _data_bytes
1 0000a020 _data_bytesa
1 0000a01f _data_bytesb
1 0000a01d _data_tx2_ok
1 0000a01e _data_tx_ok
1 0000a019 _data_write
1 0000a00e _data_writeb
1 0000ba3e _dc_filter
1 0000ba3c _dc_filter_old
1 0000bac0 _dc_link
1 0000ba07 _dc_link_count
1 0000ba40 _dc_link_old
1 0000bb0c _dc_link_voltage_scaled
1 0000bad4 _dc_loop_count
1 0000bace _dc_v
1 0000bb6d _dc_voltage_gain
0 003da625 _do_pll
0 003d8ef0 _do_rms
1 0000bad3 _do_rms_flag
0 003d8032 _do_v_i_control
0 003db26a _exit
1 0000baea _f
1 0000bb7b _fc
1 0000b5e3 _final_spi_crc
0 003fdf00 _fputables_loadend
0 003fd860 _fputables_loadstart
0 00009000 _fputables_runstart
1 0000a014 _fun_code
1 0000a00b _fun_codeb
1 0000bb7a _fx
1 0000bb4f _graph_range
1 0000bb04 _grid_freq
1 0000bb52 _harmonic_comp
1 0000bb53 _harmonic_gain
1 0000b680 _i11
1 0000b6dc _i13
1 0000b700 _i5
1 0000b6c0 _i7
1 0000ba78 _ialpha_inj
1 0000ba24 _ialpha_inj11
1 0000ba32 _ialpha_inj13
1 0000ba28 _ialpha_inj5
1 0000ba26 _ialpha_inj7
1 0000baf2 _ialpha_inv
1 0000baee _ialpha_load
1 0000a018 _ib
1 0000ba2c _ibeta_inj
1 0000ba36 _ibeta_inj11
1 0000ba34 _ibeta_inj13
1 0000ba2a _ibeta_inj5
1 0000ba22 _ibeta_inj7
1 0000bb18 _ibeta_inv
1 0000bae4 _ibeta_load
1 0000ba1a _id11_filter
1 0000ba1e _id13_filter
1 0000ba48 _id1_filter
1 0000ba46 _id5_filter
1 0000ba4e _id7_filter
1 0000bb5b _id_ref
1 0000bad5 _init_duty_flag
1 0000bb5a _inject_type
1 0000b640 _inv_current
1 0000badb _inv_last_flag
1 0000bb51 _inv_mi
1 0000bb50 _inv_start
1 0000ba18 _iq11_filter
1 0000ba1c _iq13_filter
1 0000ba4a _iq1_filter
1 0000ba52 _iq5_filter
1 0000ba42 _iq7_filter
0 003db342 _isqrt
1 0000ba58 _k5
1 0000ba4c _k6
1 0000bb55 _ki_id
1 0000bb42 _ki_id11
1 0000bb57 _ki_id13
1 0000bb4c _ki_id5
1 0000bb41 _ki_id7
1 0000bb45 _ki_vd
1 0000bb56 _kp_id
1 0000bb43 _kp_id11
1 0000bb4b _kp_id13
1 0000bb44 _kp_id5
1 0000bb46 _kp_id7
1 0000bb58 _kp_vd
1 0000b69c _l11
1 0000b71c _l13
1 0000b602 _l5
1 0000b61e _l7
1 0000ba20 _ld11_filter
1 0000ba12 _ld13_filter
1 0000ba38 _ld1_filter
1 0000ba44 _ld5_filter
1 0000ba54 _ld7_filter
1 0000bb4e _lead_lag
1 0000bb22 _lf
1 0000b65c _load_current
1 0000ba14 _lq11_filter
1 0000ba16 _lq13_filter
1 0000ba3a _lq1_filter
1 0000ba56 _lq5_filter
1 0000ba62 _lq7_filter
0 003da9d7 _main
0 003db324 _memcpy
1 0000a011 _mod_data
1 0000ba10 _msec_timer
1 0000bb4a _mul_id
1 0000bb71 _mul_id11
1 0000bb64 _mul_id13
1 0000bb6c _mul_id5
1 0000bb6e _mul_id7
1 0000bb49 _mul_iq
1 0000bb67 _mul_iq11
1 0000bb63 _mul_iq13
1 0000bb74 _mul_iq5
1 0000bb69 _mul_iq7
1 0000bb76 _mul_ld1
1 0000bb5c _mul_ld11
1 0000bb5e _mul_ld13
1 0000bb68 _mul_ld5
1 0000bb6a _mul_ld7
1 0000bb75 _mul_lq1
1 0000bb5f _mul_lq11
1 0000bb65 _mul_lq13
1 0000bb6b _mul_lq5
1 0000bb73 _mul_lq7
1 0000bb4d _mul_pi_id
1 0000bb60 _mul_pi_id11
1 0000bb62 _mul_pi_id13
1 0000bb70 _mul_pi_id5
1 0000bb72 _mul_pi_id7
1 0000bb48 _mul_pi_iq
1 0000bb66 _mul_pi_iq11
1 0000bb5d _mul_pi_iq13
1 0000bb6f _mul_pi_iq5
1 0000bb61 _mul_pi_iq7
1 0000bb47 _mul_pi_vd
1 0000a008 _new_frame_get
1 0000a007 _new_frame_get2
1 0000a012 _no_of_parametera
1 0000a00a _pb
1 0000ba02 _phase_corr
1 0000bafa _pi
1 0000ba82 _pi_id
1 0000ba70 _pi_id11
1 0000ba7c _pi_id13
1 0000ba7e _pi_id5
1 0000ba8a _pi_id7
1 0000ba84 _pi_iq
1 0000ba7a _pi_iq11
1 0000ba76 _pi_iq13
1 0000ba80 _pi_iq5
1 0000ba86 _pi_iq7
1 0000ba68 _pi_vd
1 0000b9c0 _pid_dcbus
1 0000b800 _pid_id
1 0000b980 _pid_id11
1 0000b880 _pid_id13
1 0000b7c0 _pid_id5
1 0000b780 _pid_id7
1 0000b840 _pid_iq
1 0000b900 _pid_iq11
1 0000b8c0 _pid_iq13
1 0000b740 _pid_iq5
1 0000b940 _pid_iq7
1 0000bb78 _prog_ver_no
1 0000a017 _qb
1 0000bacb _r_i
1 0000bafe _r_o_v
1 0000bad2 _r_o_v_s
1 0000baca _r_v
1 0000ba50 _r_va
1 0000ba5e _r_vb
1 0000ba60 _r_vc
1 0000a002 _rb
1 0000b5e2 _rdata
0 003da7c4 _read_data
1 0000b5e7 _read_data1
0 003da721 _read_ee
1 0000b5e6 _read_hbdata
1 0000b5e9 _read_lbdata
0 003da840 _receiveSPI
0 003d8019 _reset_scia
1 0000badf _rgen_s
1 0000bac1 _rl_i
1 0000bac4 _rl_s
1 0000ba05 _rms_an
1 0000ba04 _rms_bn
1 0000ba0f _rms_cn
1 0000ba06 _rms_count
1 0000badd _rms_ia
1 0000bada _rms_ib
1 0000bad1 _rms_ic
1 0000ba09 _rms_va
1 0000ba08 _rms_vb
1 0000ba03 _rms_vc
0 003da1bc _rsvd_ISR
1 0000a01a _rx_countera
1 0000a013 _rx_counterb
1 0000ba72 _s_cl11
1 0000ba6e _s_cl13
1 0000ba6a _s_cl5
1 0000ba66 _s_cl7
1 0000bb16 _s_x
1 0000a000 _sb
1 0000b5e1 _sdata
1 0000ba11 _sec1timer
1 0000b5e0 _send_attempt
1 0000a0c0 _serial_fifo_buf_txa
1 0000a080 _serial_fifo_buf_txb
1 0000a100 _serial_fifo_bufa
1 0000a040 _serial_fifo_bufb
0 003db1d2 _sin
0 003db119 _sincos
1 0000a006 _slave_id_nosa
1 0000a005 _slave_id_nosb
1 0000b5e5 _spi_crc
0 003da719 _spi_fifo_init
1 0000b5dc _spi_index
1 0000b5de _spi_rcvd_data
1 0000b5dd _spi_transmit_delay
0 003db303 _sqrt
1 0000a01c _start_add
1 0000a010 _start_addb
1 0000ba0e _start_inverter_flag
1 0000bade _start_pll
1 0000b5e4 _temp_delay
1 0000bb1e _theta
1 0000bacd _theta_scaled
1 0000bb7c _three_four_wire_sel
1 0000a023 _timera
1 0000a024 _timerb
1 0000ba30 _to
1 0000ba2e _to_deg
1 0000baf4 _tv
1 0000a016 _tx_bytea
1 0000a015 _tx_byteb
1 0000a022 _txqa
1 0000a021 _txqb
1 0000bb0e _v_alpha
1 0000bb08 _v_beta
1 0000bb59 _v_ref
1 0000baf0 _vbx
1 0000bb0a _vd
1 0000bb10 _vdx
1 0000bb79 _voltage_gain
1 0000ba0b _vp_a
1 0000ba0c _vp_an
1 0000ba0a _vp_b
1 0000ba01 _vp_bn
1 0000ba0d _vp_c
1 0000ba00 _vp_cn
1 0000bb1a _vq
1 0000baf8 _vqx
1 0000baec _vrx
1 0000bad6 _vx
1 0000bad7 _vy
1 0000baf6 _vyx
1 0000badc _vz
1 0000ba5c _wc
1 0000bb40 _write_data
0 003da75a _write_ee
0 003da7b4 _write_read_data
1 0000bac2 _y_i
1 0000bafc _y_o_v
1 0000bacf _y_o_v_s
1 0000bac7 _y_v
1 0000bae3 _ygen_s
1 0000bac6 _yl_i
1 0000bac5 _yl_s
abs ffffffff binit
0 003e4000 cinit
0 003f7ff6 code_start
0 003db3a4 etext
abs ffffffff pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
page address name
0 003d8000 .text
0 003d8ef0 _do_rms
0 003d9e53 _NMI_ISR
0 003da191 _LVF_ISR
0 003da19b _LUF_ISR
0 003da22b _InitPll
0 003da381 _MemCopy
0 003da550 _InitADC
0 003da625 _do_pll
0 003da721 _read_ee
0 003da805 _SpiSend
0 003da9d7 _main
0 003dac7a _InitPWM
0 003db077 _c_int00
0 003db0cd _InitSpi
0 003db119 _sincos
0 003db19e _cos
0 003db1d2 _sin
0 003db238 _InitSci
0 003db268 C$$EXIT
0 003db268 _abort
0 003db26a _exit
0 003db2df _copy_in
0 003db303 _sqrt
0 003db324 _memcpy
0 003db342 _isqrt
0 003db377 FS$$DIV
0 003db398 __nop
0 003db3a4 etext
0 003e4000 cinit
1 00000050 __stack
1 00000ae0 _CsmRegs
1 00000d00 _EmuKey
1 00001000 _DmaRegs
1 00007100 _AdcRegs
1 0000a000 _sb
1 0000a001 _crc3b
1 0000a002 _rb
1 0000a003 _crc2b
1 0000a009 _crc1b
1 0000a00a _pb
1 0000a00c _add_mod
1 0000a017 _qb
1 0000a018 _ib
1 0000a021 _txqb
1 0000a022 _txqa
1 0000a023 _timera
1 0000a024 _timerb
1 0000a5c0 _ahfdata
1 0000b5e1 _sdata
1 0000b5e2 _rdata
1 0000b5e5 _spi_crc
1 0000b5f0 __lock
1 0000b5f2 __unlock
1 0000b602 _l5
1 0000b61e _l7
1 0000b680 _i11
1 0000b69c _l11
1 0000b6c0 _i7
1 0000b6dc _i13
1 0000b700 _i5
1 0000b71c _l13
1 0000b740 _pid_iq5
1 0000b780 _pid_id7
1 0000b7c0 _pid_id5
1 0000b800 _pid_id
1 0000b840 _pid_iq
1 0000b940 _pid_iq7
1 0000ba00 _vp_cn
1 0000ba01 _vp_bn
1 0000ba03 _rms_vc
1 0000ba04 _rms_bn
1 0000ba05 _rms_an
1 0000ba08 _rms_vb
1 0000ba09 _rms_va
1 0000ba0a _vp_b
1 0000ba0b _vp_a
1 0000ba0c _vp_an
1 0000ba0d _vp_c
1 0000ba0f _rms_cn
1 0000ba2e _to_deg
1 0000ba30 _to
1 0000ba4c _k6
1 0000ba50 _r_va
1 0000ba58 _k5
1 0000ba5a _Tj
1 0000ba5c _wc
1 0000ba5e _r_vb
1 0000ba60 _r_vc
1 0000ba64 _c_cl5
1 0000ba66 _s_cl7
1 0000ba68 _pi_vd
1 0000ba6a _s_cl5
1 0000ba6c _c_cl7
1 0000ba6e _s_cl13
1 0000ba70 _pi_id11
1 0000ba72 _s_cl11
1 0000ba74 _c_cl13
1 0000ba76 _pi_iq13
1 0000ba7a _pi_iq11
1 0000ba7c _pi_id13
1 0000ba7e _pi_id5
1 0000ba80 _pi_iq5
1 0000ba82 _pi_id
1 0000ba84 _pi_iq
1 0000ba86 _pi_iq7
1 0000ba88 _c_cl11
1 0000ba8a _pi_id7
1 0000bac0 _dc_link
1 0000bac1 _rl_i
1 0000bac2 _y_i
1 0000bac3 _b_i
1 0000bac4 _rl_s
1 0000bac5 _yl_s
1 0000bac6 _yl_i
1 0000bac7 _y_v
1 0000bac8 _b_v
1 0000baca _r_v
1 0000bacb _r_i
1 0000bacc _bl_i
1 0000bace _dc_v
1 0000bacf _y_o_v_s
1 0000bad0 _b_o_v_s
1 0000bad1 _rms_ic
1 0000bad2 _r_o_v_s
1 0000bad6 _vx
1 0000bad7 _vy
1 0000bad8 _bl_s
1 0000bada _rms_ib
1 0000badc _vz
1 0000badd _rms_ia
1 0000badf _rgen_s
1 0000bae0 _THREE_V
1 0000bae2 _bgen_s
1 0000bae3 _ygen_s
1 0000bae6 _bo
1 0000bae8 _b1
1 0000baea _f
1 0000baec _vrx
1 0000baf0 _vbx
1 0000baf4 _tv
1 0000baf6 _vyx
1 0000baf8 _vqx
1 0000bafa _pi
1 0000bafc _y_o_v
1 0000bafe _r_o_v
1 0000bb08 _v_beta
1 0000bb0a _vd
1 0000bb0e _v_alpha
1 0000bb10 _vdx
1 0000bb12 _b_o_v
1 0000bb14 _c_x
1 0000bb16 _s_x
1 0000bb1a _vq
1 0000bb1e _theta
1 0000bb22 _lf
1 0000bb41 _ki_id7
1 0000bb42 _ki_id11
1 0000bb43 _kp_id11
1 0000bb44 _kp_id5
1 0000bb45 _ki_vd
1 0000bb46 _kp_id7
1 0000bb49 _mul_iq
1 0000bb4a _mul_id
1 0000bb4b _kp_id13
1 0000bb4c _ki_id5
1 0000bb51 _inv_mi
1 0000bb54 _amp
1 0000bb55 _ki_id
1 0000bb56 _kp_id
1 0000bb57 _ki_id13
1 0000bb58 _kp_vd
1 0000bb59 _v_ref
1 0000bb5b _id_ref
1 0000bb68 _mul_ld5
1 0000bb69 _mul_iq7
1 0000bb6a _mul_ld7
1 0000bb6b _mul_lq5
1 0000bb6c _mul_id5
1 0000bb6e _mul_id7
1 0000bb73 _mul_lq7
1 0000bb74 _mul_iq5
1 0000bb75 _mul_lq1
1 0000bb76 _mul_ld1
1 0000bb7a _fx
1 0000bb7b _fc
1 003f7ff8 _CsmPwl
abs ffffffff binit
abs ffffffff pinit
[584 symbols]
Thank you so much. Now I am able to run the fast supplement library functions through ram during run condition.
