Hi there!,
I'm new to the PID controller for the DSP and i tried to figure it out using the SLUA416 but i'm stuck. I'm trying to go through the first example but i'm stuck at the calculation for the Wk. Could someone explain me that calculation? Maybe someone could explain me more about designing a PID controller for the TMS?
Thnx a lot!
Mike vd Heuvel
I got the values calculated. I wonder how i can use the values i calculate in this document for my tms320f2806. How do i change the values so the mcu can use it? where can i find the digital blocks for the mcu?
Please help
Mike
My first recommendation would be to install both of the F28x DMC Libraries from here:
http://focus.ti.com/mcu/docs/mcuorphan.tsp?contentId=51397
This includes the module for our 32-bit IQMath enabled PID controller. Once installed you will find the documentation for this module here:
C:\tidcs\DMC\c28\v32x\lib\doc
and then the source here
C:\tidcs\DMC\c28\v32x\lib\dmclib\cIQmath\src (IQMath)
or
C:\tidcs\DMC\c28\v32x\lib\dmclib\cfloat\src (float)
There is also a streamlined PI ASM based macro in our DPS Library (install SPRC311):
http://focus.ti.com/mcu/docs/mcuorphan.tsp?contentId=50550&DCMP=DSP_C2000&HQS=Other+OT+dpslib
Documentation will then be: C:\tidcs\DPS_C280x\v210\dplib280x\doc
The main system documentation shows how the macros are initialized and called, and how to use the coefficient sets.
How do i translate the values for CLA that i calculated for the PID controller coefficient? like the example b0=193 b1=-354 b2=165 ??
Finally somebody can clarify the Mysteries of TI. Thanks a lot, Your post is Terrific Chirs.
-------TI your MCU documentation is horrible!!!!!!-------
