Hello: When I run code from shared memory on the c28 side I am having problems with the DMA transfering data from the A/D to memory. The M3 is not accessing the shared memory. Any body encountered a similar problem or any body has an explanation for it?
Hi Arye,
Please let us know the name of device you are using and it's silicon revision number.
Vivek Singh
Hello Vivek:
I'm using F28M35H22C Rev 0. Concerto Device.
Regards Arye Perlmutter
Hi Arye,
We are not aware of any issue with C28 DMA standalone access to Shared RAMs. Is it possible for you to provide little more detail on this issue?
Also we have RevA Si available for this device. If possible, I would suggest to run the same code on RevA device and see if it behave same way.
Vivek Singh
