Highly appreciate if anybody can educate me how to access the SYSCLKOUT data or similar which is synchronised with time so that I can generate a sinusoidal signal which is syncronised with the clock. My ultimate target is to take a sinusoidal signal in through an A2D pin and compare it with the realtime sine wave generated inside.
Thanking you in advance,
RPSC.
Hi Ruwan,
You can make use of Signal Library SGEN_HPx. Also, go through this post as it seems your application is similar:
http://e2e.ti.com/support/microcontrollers/c2000/f/171/t/317542.aspx
Gautam
