Other Parts Discussed in Thread: UNIFLASH, TMS320F28020
While programming target flash using a Spectrum Digital XDS510LC JTAG the power supply experienced a glitch that disrupted the download. Afterwards I could no longer connect or download to the processor.
I installed UniFlash but the tool could not resurrect the device. Further research seems to indicate the part is irreversibly bricked.
Is this the most probable outcome? I will replace the CPU if necessary. I appreciate any suggestions or pointers to other options.
Nancy
Here is the console captured from UniFlash:
[05:09:04] Begin Launching session operation.
[05:09:06] Operation Launching session returned.
[05:09:06] Loaded target configuration from: C:\Users\nancy.burkholder\Documents\F28029.ccxml
[05:09:20] C28xx: Flash Programmer: Warning: The configured device (TMS320F28020), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
[05:09:20] C28xx: GEL Output:
Device Calibration not complete, check if device is unlocked and recalibrate.
[05:09:21] C28xx: Erasing Flash memory...
[05:09:21] ERROR >> C28xx: Flash Programmer: Error erasing flash memory. Device is locked or not connected. Operation cancelled
[05:09:21] Flash operation Erase failed on core Spectrum Digital C2000 XDS510LC Emulator/C28xx .
[05:09:41] C28xx: GEL Output:
[05:09:41] C28xx: Starting device unlocking...
[05:09:41] ERROR >> C28xx: Flash Programmer: Error unlocking flash memory. Device is still locked
[05:09:41] Flash operation Unlock failed on core Spectrum Digital C2000 XDS510LC Emulator/C28xx .
