Error while executing OnTargetConnect(): Could not read register ST1: target is not connected
Other Parts Discussed in Thread: TMS320F28335, UNIFLASH
I am using TMS320F28335. I am getting following error, when I try to download program.
C28xx: Unable to determine target status after 20 attempts
C28xx: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
C28xx: GEL: Error while executing OnTargetConnect(): Could not read register ST1: target is not connected
at (ST1&~(0x0100)) [f28335.gel:312]
at C28x_Mode() [f28335.gel:82]
at OnTargetConnect()
If I use Test Conection, it looks like it has valid connection.
following is message with Test Connection Message.
The JTAG DR Integrity scan-test has succeeded.
This morning, my power supply reset during programming. I suspect this is device lock issue. Is there any way to unlock device ? Is there anyway, I can avoid to replace chip.
Is there anyway to stop device lock, even if device reset during programming ?
Jigar
