I am not able to close the speed loop in PMSM FOC both sensored and sensorless projects. Either the motor vibrates and stops or it produces an alarm sound.
While I change from lsw=1 to lsw=2 the angle provided to park and Inverse park blocks should change from rg1.out to qep1.ElecTheta/ eSMO.Theta, but they are having a slight phase difference. I assume that is causing the problem.
I followed all build levels correctly as per mentioned in the application note but didn't succed. What is the correct way closing the speed loop ?
Dijo
