Other Parts Discussed in Thread: CONTROLSUITE
I am using F28M35xx ISO controlCARD (release 1.0)
I installed Control suite and usde these files as instructions.
C:\ti\controlSUITE\development_kits\HV_SOLAR_DC_AC_v1.1\Solar_HV_DCAC_Concerto_SCI_Rev_0\c28
I uploaded the program using Code Composer Studio.
I used the GUI program and it shows DC bus voltages and information correctly.
Problem: I followed the quick guide, and make all settings correctly. But controller card LD3 bulb flash at about 1 second rate and LD2 does not flash. when I turned ON system two IGBT burned and DC side fuse gone.(I added fuse)
I checked the IGBT drivers and they work fine. why LD3 flash always and why LD2 do not flash? actaully they have mentioned that LD2 should flash if system works fine. I replaced IGBT and I asked your help before do the same steps and burn IGBT again.
I have added information sheet i followed. here.
Quick Start Guide for Solar HV DC-AC Board_Rev1.3.pdf
Thank you!
