Other Parts Discussed in Thread: TMS320F2810, CONTROLSUITE
Hi
This is sampath, I am using a TMS320F2810 DSP for an application which drives servo-motor in loopback control-system mode. The gain parameters for the loop are initially saved in the flash memory ( the gain values are around 3.879, 4.894 etc.,) at some locations. The responce is testing using a sine wave with finite amplitude, initially servo is running but after some time servo is not running, when we debug this we found that the gain values which must be copied from flash are copied as (0.000000000000000000000000000000000001) for all the gain values, thats why the motor is not running, so kindly tell me the reason behind that.
sampath
