Part Number: TMS320F28377D
Dears
TMS320F28377D
The fault occurs after programming the serial test program,
The phenomenon can not be programmed for the program,
After testing, found that the DSP core voltage from 1.2V to 1.8V, through the analysis, to confirm the 1.8V voltage DSP problem, remove the DSP after the voltage back to normal.
A total of 40, 4 have a problem, replace the new normal afterdsp28377.pdf
