Hi Sirs,
About TMS320F28335 errata issue: Memory Possible Incorrect Operation of XINTF Module After PowerUp.
We had two questions as below
1> Why this problem only happen in some chip?
2> Why we change the setting of XCLKOUT will improve the problem?
Thank you so much for your support.
Hi Tommy,
Thank you so much for your reply.
Now, we used TPS3806I33-Q1 reset IC connect to TMS320F28335 XRS pin. we measured the reset time around 1.2ms and that time match below spec.
We follow below link to modifies code to test. the issue was solved.
Could you more detail information?we need it to confirmed end customer.
