LAUNCHXL-F28069M: F28069M - Low Speed Algorithms - Torque control
Part Number: LAUNCHXL-F28069M
Other Parts Discussed in Thread: MOTORWARE, TMDSHVMTRINSPIN
Hello friend , i am very much new to F28069M. Now i am working on HVLS Fans project. BIG fans but with 55 RPM to 90RPM.
Just some tips from experienced forum team to minimize the time.  Our solution will be F28069M + IPM with 600v IGBT.
  • Hi Sir,
    You made a very good choice! You may download motorware as below link which has many example projects to support different kits, and you could follow the lab user's guide to understanding these lab projects.
    www.ti.com/.../motorware
    Btw, you may use the TMDSHVMTRINSPIN as a starter kit if yourself board is not ready. More details about this kit can be found in the link below.
    www.ti.com/.../tmdshvmtrinspin
  • To add to what Yanming said, if you are using custom hardware, please make sure you have proper voltage and current feedback by using labs 1b and 1c before moving on, as the feedback paths are critical
    Sean
