CCS/DRV8301-69M-KIT: torque controll lab11e
Part Number: DRV8301-69M-KIT
hi!
I have tried lab 11-e and it works perfectly. I was able to change controlling method back and forth smoothly.
Now, i have been trying to upgrade lab 11-e such that lab starts with torque control for BLDC sensor control and whenever reaches to defined rpm to change control method to FOC sensorless i need to change from torque control to speed control.
i have read another thread about running lab 11-e fully with torque control and tried to implement steps so that i might reverse only FOC-sensorless part to speed control but either steps are somehow missing or i could not perform steps properly since motor did not spin at all with the alterations on the thread.
  • Hey,  here is my lab11e code with torque control, it should work.
    /* --COPYRIGHT--,BSD
     * Copyright (c) 2015, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     * --/COPYRIGHT--*/
    //! \file   solutions/instaspin_foc/src/proj_lab011e.c
    //! \brief Hall sensor start-up with transition to FAST for InstaSPIN-FOC
    //! (C) Copyright 2015, Texas Instruments, Inc.
    //! \defgroup PROJ_LAB11e PROJ_LAB11e
    //! \defgroup PROJ_LAB11e_OVERVIEW Project Overview
    //! Hall sensor start-up with transition to FAST for InstaSPIN-FOC
    // the includes
    // system includes
    #include <math.h>
    #include "main.h"
    #ifdef FLASH
    #pragma CODE_SECTION(mainISR,"ramfuncs");
    #pragma CODE_SECTION(runSetTrigger,"ramfuncs");
    #pragma CODE_SECTION(runFieldWeakening,"ramfuncs");
    #pragma CODE_SECTION(runCurrentReconstruction,"ramfuncs");
    #pragma CODE_SECTION(angleDelayComp,"ramfuncs");
    #pragma CODE_SECTION(HALLBLDC_State_Check,"ramfuncs");
    #pragma CODE_SECTION(HALLBLDC_Ctrl_PwmSet,"ramfuncs");
    #pragma CODE_SECTION(HALLBLDC_Ctrl_Run,"ramfuncs");
    #endif
    // Include header files used in the main function
    // the defines
    #define RTG
    //#define SWINT
    //#define POT
    #define THROTTLE
    //#define FW
    // the globals
    CLARKE_Handle   clarkeHandle_I;               //!< the handle for the current Clarke transform
    CLARKE_Obj      clarke_I;                     //!< the current Clarke transform object
    CLARKE_Handle   clarkeHandle_V;               //!< the handle for the voltage Clarke transform
    CLARKE_Obj      clarke_V;                     //!< the voltage Clarke transform object
    EST_Handle      estHandle;                    //!< the handle for the estimator
    FW_Handle       fwHandle;
    FW_Obj          fw;
    PID_Obj         pid[4];                       //!< three handles for PID controllers 0 - Speed, 1 - Id, 2 - Iq
    PID_Handle      pidHandle[4];                 //!< three objects for PID controllers 0 - Speed, 1 - Id, 2 - Iq
    uint16_t        pidCntSpeed;                  //!< count variable to decimate the execution of the speed PID controller
    IPARK_Handle    iparkHandle;                  //!< the handle for the inverse Park transform
    IPARK_Obj       ipark;                        //!< the inverse Park transform object
    FILTER_FO_Handle  filterHandle[6];            //!< the handles for the 3-current and 3-voltage filters for offset calculation
    FILTER_FO_Obj     filter[6];                  //!< the 3-current and 3-voltage filters for offset calculation
    SVGENCURRENT_Obj     svgencurrent;
    SVGENCURRENT_Handle  svgencurrentHandle;
    SVGEN_Handle    svgenHandle;                  //!< the handle for the space vector generator
    SVGEN_Obj       svgen;                        //!< the space vector generator object
    TRAJ_Handle     trajHandle_Id;                //!< the handle for the id reference trajectory
    TRAJ_Obj        traj_Id;                      //!< the id reference trajectory object
    TRAJ_Handle     trajHandle_spd;               //!< the handle for the speed reference trajectory
    TRAJ_Obj        traj_spd;                     //!< the speed reference trajectory object
    #ifdef CSM_ENABLE
    #pragma DATA_SECTION(halHandle,"rom_accessed_data");
    #endif
    HAL_Handle      halHandle;                    //!< the handle for the hardware abstraction layer (HAL)
    HAL_PwmData_t   gPwmData = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};       //!< contains the three pwm values -1.0 - 0%, 1.0 - 100%
    HAL_AdcData_t   gAdcData;                     //!< contains three current values, three voltage values and one DC buss value
    MATH_vec3       gOffsets_I_pu = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};  //!< contains the offsets for the current feedback
    MATH_vec3       gOffsets_V_pu = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};  //!< contains the offsets for the voltage feedback
    MATH_vec2       gIdq_ref_pu = {_IQ(0.0), _IQ(0.0)};              //!< contains the Id and Iq references
    MATH_vec2       gVdq_out_pu = {_IQ(0.0), _IQ(0.0)};              //!< contains the output Vd and Vq from the current controllers
    MATH_vec2       gIdq_pu = {_IQ(0.0), _IQ(0.0)};                  //!< contains the Id and Iq measured values
    #ifdef CSM_ENABLE
    #pragma DATA_SECTION(gUserParams,"rom_accessed_data");
    #endif
    USER_Params     gUserParams;
    volatile MOTOR_Vars_t gMotorVars = MOTOR_Vars_INIT;   //!< the global motor variables that are defined in main.h and used for display in the debugger's watch window
    #ifdef FLASH
    // Used for running BackGround in flash, and ISR in RAM
    extern uint16_t *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart;
    #ifdef CSM_ENABLE
    extern uint16_t *econst_start, *econst_end, *econst_ram_load;
    extern uint16_t *switch_start, *switch_end, *switch_ram_load;
    #endif
    #endif
    MATH_vec3 gIavg = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};
    uint16_t gIavg_shift = 1;
    MATH_vec3 gPwmData_prev = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};
    #ifdef DRV8301_SPI
    // Watch window interface to the 8301 SPI
    DRV_SPI_8301_Vars_t gDrvSpi8301Vars;
    #endif
    #ifdef DRV8305_SPI
    // Watch window interface to the 8305 SPI
    DRV_SPI_8305_Vars_t gDrvSpi8305Vars;
    #endif
    // define CPU time
    CPU_TIME_Obj     cpu_time;
    CPU_TIME_Handle  cpu_timeHandle;
    HAL_DacData_t gDacData;
    _iq gFlux_pu_to_Wb_sf;
    _iq gFlux_pu_to_VpHz_sf;
    _iq gTorque_Ls_Id_Iq_pu_to_Nm_sf;
    _iq gTorque_Flux_Iq_pu_to_Nm_sf;
    _iq gSpeed_krpm_to_pu_sf = _IQ((float_t)USER_MOTOR_NUM_POLE_PAIRS * 1000.0 / (USER_IQ_FULL_SCALE_FREQ_Hz * 60.0));
    _iq gSpeed_hz_to_krpm_sf = _IQ(60.0 / (float_t)USER_MOTOR_NUM_POLE_PAIRS / 1000.0);
    _iq gIs_Max_squared_pu = _IQ((USER_MOTOR_MAX_CURRENT * USER_MOTOR_MAX_CURRENT) / (USER_IQ_FULL_SCALE_CURRENT_A * USER_IQ_FULL_SCALE_CURRENT_A));
    uint32_t gOffsetCalcCount = 0;
    uint16_t gTrjCnt = 0;
    volatile bool gFlag_enableRsOnLine = false;
    volatile bool gFlag_updateRs = false;
    volatile _iq gRsOnLineFreq_Hz = _IQ(0.2);
    volatile _iq gRsOnLineId_mag_A = _IQ(0.5);
    volatile _iq gRsOnLinePole_Hz = _IQ(0.2);
    //variable
    _iq speed_pid_out = _IQ(0.0);
    _iq angle_est_pu = _IQ(0.0);
    _iq speed_est_pu = _IQ(0.0);
    _iq angle_pu = _IQ(0.0);
    _iq speed_pu = _IQ(0.0);
    //BLDC current loop
    _iq gHall_BLDC_Is_fdb_pu = _IQ(0.0);
    _iq gHall_BLDC_Is_ref_pu = _IQ(0.0);
    _iq gHall_PwmDuty = _IQ(0.0);
    // Coefficient for pid regulator switch from Hall to Fast
    _iq gHall2Fast_Spd_Coef = _IQ(1.0);
    _iq gHall2Fast_Iq_coef = _IQ(0.50);
    _iq gHall2Fast_Ui_coef = _IQ(0.50);
    // Coefficient for pid regulator switch from Fast to Hall
    _iq gFast2Hall_Spd_coef = _IQ(1.0);
    _iq gFast2Hall_Iq_coef = _IQ(0.0);
    _iq gFast2Hall_Ui_coef = _IQ(2.0);
    // BLDC speed
    _iq gHall_speed_fdb_pu = _IQ(0.0);
    _iq gHall_speed_FastToBldc_low_pu  = _IQ(0.200*USER_MOTOR_NUM_POLE_PAIRS*1000.0/(USER_IQ_FULL_SCALE_FREQ_Hz * 60.0));       // 400rpm
    _iq gHall_speed_BldcToFast_high_pu = _IQ(0.300*USER_MOTOR_NUM_POLE_PAIRS*1000.0/(USER_IQ_FULL_SCALE_FREQ_Hz * 60.0));       // 750rpm
    uint16_t gHall_PwmState = 0;
    uint16_t gHall_GpioData = 0;
    int16_t gHall_State = 0;
    int16_t gHall_PrevState = 0;
    int16_t gHall_LastState = 0;
    int16_t gHall_State_delta = 0;
    uint16_t gHall_dir = 0;
    uint16_t gHall_dir_prev = 0;
    uint16_t gHall_dir_change = 0;
    uint16_t gHall_BLDC_Flag_Is_fdb = 0;
    uint16_t gHall_PwmIndex[8] = {4, 1, 5, 6, 3, 2, 4, 1};
    bool gHall_Flag_EnableBldc = true;
    bool gHall_Flag_EnableStartup = true;       // true->enable hall startup
    //bool gHall_Flag_EnableStartup = false;    // false->disable hall startup
    bool gHall_Flag_CurrentCtrl = true;
    bool gHall_Flag_State_Change = false;
    bool FS_flag_enableSpeedCtrl = false;
    //bool FS_flag_enableSpeedCtrl = true;
    _iq FS_Iq_ref_pu = _IQ(0.0);
    uint32_t gHall_timer_now= 0;
    uint32_t gHall_timer_prev = 0;
    uint32_t gHall_time_delta_now = 0;
    uint32_t gHall_time_delta_prev = 0;
    uint32_t gHall_time_delta = 0;
    uint32_t gHall_speed_scale = USER_SYSTEM_FREQ_MHz*1000000*100/6;
    uint32_t gHall_speed_fdb_0p01Hz = 0;
    _iq gHall_Speed_0p01hz_to_pu_sf = _IQ((float_t)0.01/(USER_IQ_FULL_SCALE_FREQ_Hz));
    uint16_t gHall_PwmCnt = 0;
    uint16_t gHall_PwmCntMax = 5000;
    uint32_t gHall_Bldc_Cnt = 0;
    uint32_t gHall_Fast_Cnt = 0;
    void HALLBLDC_Ctrl_Run(void);
    void HALLBLDC_State_Check(void);
    void HALLBLDC_Ctrl_Stop(void);
    void HALLBLDC_Ctrl_PwmSet(uint16_t PwmState, _iq PwmDuty);
    // the functions
    void main(void)
        // IMPORTANT NOTE: If you are not familiar with MotorWare coding guidelines
        // please refer to the following document:
        // C:/ti/motorware/motorware_1_01_00_1x/docs/motorware_coding_standards.pdf
        // Only used if running from FLASH
        // Note that the variable FLASH is defined by the project
        #ifdef FLASH
        // Copy time critical code and Flash setup code to RAM
        // The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart
        // symbols are created by the linker. Refer to the linker files.
        memCopy((uint16_t *)&RamfuncsLoadStart,(uint16_t *)&RamfuncsLoadEnd,
                (uint16_t *)&RamfuncsRunStart);
        #ifdef CSM_ENABLE
          //copy .econst to unsecure RAM
          if(*econst_end - *econst_start)
              memCopy((uint16_t *)&econst_start,(uint16_t *)&econst_end,(uint16_t *)&econst_ram_load);
          //copy .switch ot unsecure RAM
          if(*switch_end - *switch_start)
              memCopy((uint16_t *)&switch_start,(uint16_t *)&switch_end,(uint16_t *)&switch_ram_load);
        #endif
        #endif
        // initialize the Hardware Abstraction Layer  (HAL)
        // halHandle will be used throughout the code to interface with the HAL
        // (set parameters, get and set functions, etc) halHandle is required since
        // this is how all objects are interfaced, and it allows interface with
        // multiple objects by simply passing a different handle. The use of
        // handles is explained in this document:
        halHandle = HAL_init(&hal,sizeof(hal));
      // check for errors in user parameters
      USER_checkForErrors(&gUserParams);
      // store user parameter error in global variable
      gMotorVars.UserErrorCode = USER_getErrorCode(&gUserParams);
      // do not allow code execution if there is a user parameter error
      if(gMotorVars.UserErrorCode != USER_ErrorCode_NoError)
          for(;;)
              gMotorVars.Flag_enableSys = false;
      // initialize the Clarke modules
      clarkeHandle_I = CLARKE_init(&clarke_I,sizeof(clarke_I));
      clarkeHandle_V = CLARKE_init(&clarke_V,sizeof(clarke_V));
      // initialize the estimator
      estHandle = EST_init((void *)USER_EST_HANDLE_ADDRESS, 0x200);
      // initialize the user parameters
      USER_setParams(&gUserParams);
      // set the hardware abstraction layer parameters
      HAL_setParams(halHandle,&gUserParams);
    #ifdef FAST_ROM_V1p6
        CTRL_Handle ctrlHandle = CTRL_init((void *)USER_CTRL_HANDLE_ADDRESS, 0x200);
        CTRL_Obj *obj = (CTRL_Obj *)ctrlHandle;
        obj->estHandle = estHandle;
        // initialize the estimator through the controller
        CTRL_setParams(ctrlHandle,&gUserParams);
        CTRL_setUserMotorParams(ctrlHandle);
        CTRL_setupEstIdleState(ctrlHandle);
    #else
        EST_setEstParams(estHandle,&gUserParams);
        EST_setupEstIdleState(estHandle);
    #endif
      // disable Rs recalculation by default
      gMotorVars.Flag_enableRsRecalc = false;
      EST_setFlag_enableRsRecalc(estHandle,false);
      // configure RsOnLine
      EST_setFlag_enableRsOnLine(estHandle,gFlag_enableRsOnLine);
      EST_setFlag_updateRs(estHandle,gFlag_updateRs);
      EST_setRsOnLineAngleDelta_pu(estHandle,_IQmpy(gRsOnLineFreq_Hz, _IQ(1.0/USER_ISR_FREQ_Hz)));
      EST_setRsOnLineId_mag_pu(estHandle,_IQmpy(gRsOnLineId_mag_A, _IQ(1.0/USER_IQ_FULL_SCALE_CURRENT_A)));
      // Calculate coefficients for all filters
        _iq b0 = _IQmpy(gRsOnLinePole_Hz, _IQ(1.0/USER_ISR_FREQ_Hz));
        _iq a1 = b0 - _IQ(1.0);
        EST_setRsOnLineFilterParams(estHandle,EST_RsOnLineFilterType_Current,b0,a1,_IQ(0.0),b0,a1,_IQ(0.0));
        EST_setRsOnLineFilterParams(estHandle,EST_RsOnLineFilterType_Voltage,b0,a1,_IQ(0.0),b0,a1,_IQ(0.0));
      // set the number of current sensors
      setupClarke_I(clarkeHandle_I,USER_NUM_CURRENT_SENSORS);
      // set the number of voltage sensors
      setupClarke_V(clarkeHandle_V,USER_NUM_VOLTAGE_SENSORS);
      // set the pre-determined current and voltage feeback offset values
      gOffsets_I_pu.value[0] = _IQ(I_A_offset);
      gOffsets_I_pu.value[1] = _IQ(I_B_offset);
      gOffsets_I_pu.value[2] = _IQ(I_C_offset);
      gOffsets_V_pu.value[0] = _IQ(V_A_offset);
      gOffsets_V_pu.value[1] = _IQ(V_B_offset);
      gOffsets_V_pu.value[2] = _IQ(V_C_offset);
      // initialize the PID controllers
        _iq maxCurrent_pu = _IQ(USER_MOTOR_MAX_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A);
        _iq maxVoltage_pu = _IQ(USER_MAX_VS_MAG_PU * USER_VD_SF);
        float_t fullScaleCurrent = USER_IQ_FULL_SCALE_CURRENT_A;
        float_t fullScaleVoltage = USER_IQ_FULL_SCALE_VOLTAGE_V;
        float_t IsrPeriod_sec = 1.0 / USER_ISR_FREQ_Hz;
        float_t Ls_d = USER_MOTOR_Ls_d;
        float_t Ls_q = USER_MOTOR_Ls_q;
        float_t Rs = USER_MOTOR_Rs;
        float_t RoverLs_d = Rs/Ls_d;
        float_t RoverLs_q = Rs/Ls_q;
        _iq Kp_Id = _IQ((0.25*Ls_d*fullScaleCurrent)/(IsrPeriod_sec*fullScaleVoltage));
        _iq Ki_Id = _IQ(RoverLs_d*IsrPeriod_sec);
        _iq Kp_Iq = _IQ((0.25*Ls_q*fullScaleCurrent)/(IsrPeriod_sec*fullScaleVoltage));
        _iq Ki_Iq = _IQ(RoverLs_q*IsrPeriod_sec);
        pidHandle[0] = PID_init(&pid[0],sizeof(pid[0]));
        pidHandle[1] = PID_init(&pid[1],sizeof(pid[1]));
        pidHandle[2] = PID_init(&pid[2],sizeof(pid[2]));
        pidHandle[3] = PID_init(&pid[3],sizeof(pid[3]));
        PID_setGains(pidHandle[0],_IQ(0.2),_IQ(0.005),_IQ(0.0));
        PID_setMinMax(pidHandle[0],-maxCurrent_pu,maxCurrent_pu);
        PID_setUi(pidHandle[0],_IQ(0.0));
        pidCntSpeed = 0;
        PID_setGains(pidHandle[1],Kp_Id,Ki_Id,_IQ(0.0));
        PID_setMinMax(pidHandle[1],-maxVoltage_pu,maxVoltage_pu);
        PID_setUi(pidHandle[1],_IQ(0.0));
        PID_setGains(pidHandle[2],Kp_Iq,Ki_Iq,_IQ(0.0));
        PID_setMinMax(pidHandle[2],_IQ(0.0),_IQ(0.0));
        PID_setUi(pidHandle[2],_IQ(0.0));
        PID_setGains(pidHandle[3],Kp_Iq,Ki_Iq,_IQ(0.0));
        PID_setMinMax(pidHandle[3],-maxVoltage_pu,maxVoltage_pu);
        PID_setUi(pidHandle[3],_IQ(0.0));
      // initialize the speed reference in kilo RPM where base speed is USER_IQ_FULL_SCALE_FREQ_Hz
      gMotorVars.SpeedRef_krpm = _IQmpy(_IQ(30.0), gSpeed_hz_to_krpm_sf);
      // initialize the inverse Park module
      iparkHandle = IPARK_init(&ipark,sizeof(ipark));
      // initialize and configure offsets using filters
        uint16_t cnt = 0;
        _iq b0 = _IQ(gUserParams.offsetPole_rps/(float_t)gUserParams.ctrlFreq_Hz);
        _iq a1 = (b0 - _IQ(1.0));
        _iq b1 = _IQ(0.0);
        for(cnt=0;cnt<6;cnt++)
            filterHandle[cnt] = FILTER_FO_init(&filter[cnt],sizeof(filter[0]));
            FILTER_FO_setDenCoeffs(filterHandle[cnt],a1);
            FILTER_FO_setNumCoeffs(filterHandle[cnt],b0,b1);
            FILTER_FO_setInitialConditions(filterHandle[cnt],_IQ(0.0),_IQ(0.0));
        gMotorVars.Flag_enableOffsetcalc = false;
      // initialize the space vector generator module
      svgenHandle = SVGEN_init(&svgen,sizeof(svgen));
      // Initialize and setup the 100% SVM generator
      svgencurrentHandle = SVGENCURRENT_init(&svgencurrent,sizeof(svgencurrent));
      // setup svgen current
        float_t minWidth_microseconds = 2.0;
        uint16_t minWidth_counts = (uint16_t)(minWidth_microseconds * USER_SYSTEM_FREQ_MHz);
        float_t fdutyLimit = 0.5-(2.0*minWidth_microseconds*USER_PWM_FREQ_kHz*0.001);
        _iq dutyLimit = _IQ(fdutyLimit);
        SVGENCURRENT_setMinWidth(svgencurrentHandle, minWidth_counts);
        SVGENCURRENT_setIgnoreShunt(svgencurrentHandle, use_all);
        SVGENCURRENT_setMode(svgencurrentHandle,all_phase_measurable);
        SVGENCURRENT_setVlimit(svgencurrentHandle,dutyLimit);
      // initialize the speed reference trajectory
      trajHandle_spd = TRAJ_init(&traj_spd,sizeof(traj_spd));
      // configure the speed reference trajectory
      TRAJ_setTargetValue(trajHandle_spd,_IQ(0.0));
      TRAJ_setIntValue(trajHandle_spd,_IQ(0.0));
      TRAJ_setMinValue(trajHandle_spd,_IQ(-1.0));
      TRAJ_setMaxValue(trajHandle_spd,_IQ(1.0));
      TRAJ_setMaxDelta(trajHandle_spd,_IQ(USER_MAX_ACCEL_Hzps / USER_IQ_FULL_SCALE_FREQ_Hz / USER_ISR_FREQ_Hz));
      // initialize the Id reference trajectory
      trajHandle_Id = TRAJ_init(&traj_Id,sizeof(traj_Id));
      if(USER_MOTOR_TYPE == MOTOR_Type_Pm)
          // configure the Id reference trajectory
          TRAJ_setTargetValue(trajHandle_Id,_IQ(0.0));
          TRAJ_setIntValue(trajHandle_Id,_IQ(0.0));
          TRAJ_setMinValue(trajHandle_Id,_IQ(-USER_MOTOR_MAX_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A));
          TRAJ_setMaxValue(trajHandle_Id,_IQ(USER_MOTOR_MAX_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A));
          TRAJ_setMaxDelta(trajHandle_Id,_IQ(USER_MOTOR_RES_EST_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A / USER_ISR_FREQ_Hz));
          // Initialize field weakening
          fwHandle = FW_init(&fw,sizeof(fw));
          FW_setFlag_enableFw(fwHandle, false); // Disable field weakening
          FW_clearCounter(fwHandle); // Clear field weakening counter
          FW_setNumIsrTicksPerFwTick(fwHandle, FW_NUM_ISR_TICKS_PER_CTRL_TICK); // Set the number of ISR per field weakening ticks
          FW_setDeltas(fwHandle, FW_INC_DELTA, FW_DEC_DELTA); // Set the deltas of field weakening
          FW_setOutput(fwHandle, _IQ(0.0)); // Set initial output of field weakening to zero
          FW_setMinMax(fwHandle,_IQ(USER_MAX_NEGATIVE_ID_REF_CURRENT_A/USER_IQ_FULL_SCALE_CURRENT_A),_IQ(0.0)); // Set the field weakening controller limits
      else
          TRAJ_setMinValue(trajHandle_Id,_IQ(0.0));
          TRAJ_setMaxValue(trajHandle_Id,_IQ(USER_MOTOR_MAGNETIZING_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A));
          TRAJ_setMaxDelta(trajHandle_Id,_IQ(USER_MOTOR_MAGNETIZING_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A / USER_ISR_FREQ_Hz));
        // initialize the CPU usage module
        cpu_timeHandle = CPU_TIME_init(&cpu_time,sizeof(cpu_time));
        CPU_TIME_setParams(cpu_timeHandle, PWM_getPeriod(halHandle->pwmHandle[0]));
      // setup faults
      HAL_setupFaults(halHandle);
      // initialize the interrupt vector table
      HAL_initIntVectorTable(halHandle);
      // enable the ADC interrupts
      HAL_enableAdcInts(halHandle);
      // enable global interrupts
      HAL_enableGlobalInts(halHandle);
      // enable debug interrupts
      HAL_enableDebugInt(halHandle);
      // disable the PWM
      HAL_disablePwm(halHandle);
      // compute scaling factors for flux and torque calculations
      gFlux_pu_to_Wb_sf = USER_computeFlux_pu_to_Wb_sf();
      gFlux_pu_to_VpHz_sf = USER_computeFlux_pu_to_VpHz_sf();
      gTorque_Ls_Id_Iq_pu_to_Nm_sf = USER_computeTorque_Ls_Id_Iq_pu_to_Nm_sf();
      gTorque_Flux_Iq_pu_to_Nm_sf = USER_computeTorque_Flux_Iq_pu_to_Nm_sf();
      // enable the system by default
      gMotorVars.Flag_enableSys = true;
    #ifdef DRV8301_SPI
      // turn on the DRV8301 if present
      HAL_enableDrv(halHandle);
      // initialize the DRV8301 interface
      HAL_setupDrvSpi(halHandle,&gDrvSpi8301Vars);
    #endif
    #ifdef DRV8305_SPI
      // turn on the DRV8305 if present
      // initialize the DRV8305 interface
      HAL_setupDrvSpi(halHandle,&gDrvSpi8305Vars);
    #endif
      gMotorVars.Flag_enableOffsetcalc = true;
      while(gMotorVars.Flag_enableOffsetcalc == true) gMotorVars.Flag_Run_Identify = 0;
      // Below two lines code for Flash Testing, need to be commented
    #ifdef RTG
      gMotorVars.Flag_Run_Identify = true;
    #endif
      // Begin the background loop
      for(;;)
        // Waiting for enable system flag to be set
        while(!(gMotorVars.Flag_enableSys));
        // loop while the enable system flag is true
        while(gMotorVars.Flag_enableSys)
            if(gMotorVars.Flag_Run_Identify)
                // update estimator state
                EST_updateState(estHandle,0);
                  // call this function to fix 1p6
                  softwareUpdate1p6(estHandle);
                #endif
               // enable the PWM
    //           HAL_enablePwm(halHandle);
               if(gHall_Flag_EnableStartup == false)
                   // enable the PWM
                // set trajectory target for speed reference
                TRAJ_setTargetValue(trajHandle_spd,_IQmpy(gMotorVars.SpeedRef_krpm, gSpeed_krpm_to_pu_sf));
                    // set trajectory target for Id reference
                    TRAJ_setTargetValue(trajHandle_Id,gIdq_ref_pu.value[0]);
                else
                    if(gMotorVars.Flag_enablePowerWarp)
                        _iq Id_target_pw_pu = EST_runPowerWarp(estHandle,TRAJ_getIntValue(trajHandle_Id),gIdq_pu.value[1]);
                        TRAJ_setTargetValue(trajHandle_Id,Id_target_pw_pu);
                        TRAJ_setMinValue(trajHandle_Id,_IQ(USER_MOTOR_MAGNETIZING_CURRENT * 0.3 / USER_IQ_FULL_SCALE_CURRENT_A));
                        TRAJ_setMaxDelta(trajHandle_Id,_IQ(USER_MOTOR_MAGNETIZING_CURRENT * 0.3 / USER_IQ_FULL_SCALE_CURRENT_A / USER_ISR_FREQ_Hz));
                    else
                        TRAJ_setTargetValue(trajHandle_Id,_IQ(USER_MOTOR_MAGNETIZING_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A));
            else if(gMotorVars.Flag_enableRsRecalc)
                // set angle to zero
                EST_setAngle_pu(estHandle,_IQ(0.0));
                // enable or disable Rs recalculation
                EST_setFlag_enableRsRecalc(estHandle,true);
                #endif
                // enable the PWM
                TRAJ_setTargetValue(trajHandle_Id,_IQ(USER_MOTOR_RES_EST_CURRENT / USER_IQ_FULL_SCALE_CURRENT_A));
                // if done with Rs recalculation, disable flag
                if(EST_getState(estHandle) == EST_State_OnLine) gMotorVars.Flag_enableRsRecalc = false;
            else
                // set estimator to Idle
                EST_setIdle(estHandle);
                // disable the PWM
                if(!gMotorVars.Flag_enableOffsetcalc) HAL_disablePwm(halHandle);
                // clear the speed reference trajectory
                // clear the Id reference trajectory
                // configure trajectory Id defaults depending on motor type
                else
                // clear integral outputs
                // clear Id and Iq references
                gIdq_ref_pu.value[0] = _IQ(0.0);
                gIdq_ref_pu.value[1] = _IQ(0.0);
                // disable RsOnLine flags
                // disable PowerWarp flag
                gMotorVars.Flag_enablePowerWarp = false;
            //read the pot value
    #ifdef POT
        gPotentiometer =_IQmpy(HAL_readPotentiometerData(halHandle),_IQ(USER_MOTOR_MAX_CURRENT));//  read potentiometer and set range for max
        gMotorVars.IqRef_A=gMotorVars.gPotentiometer;
        if (gPotentiometer < _IQ(0.1)) // set a dead min range
           gPotentiometer=_IQ(0.0);
    #endif
    #ifdef THROTTLE
        //pot in Ampere
        gMotorVars.gPotentiometer =_IQmpy(HAL_readPotentiometerData(halHandle),_IQ(USER_MOTOR_MAX_CURRENT));// read potentiometer and set range for max
        gMotorVars.IqRef_A=gMotorVars.gPotentiometer*1.97-_IQ(52.0);
        if (gMotorVars.IqRef_A < _IQ(3.0)) // set a dead min range
            gMotorVars.IqRef_A=_IQ(0.0);
    #endif
            // update IqRef_A
            FS_Iq_ref_pu =_IQmpy(gMotorVars.IqRef_A,_IQ(1.0/USER_IQ_FULL_SCALE_CURRENT_A));
            // update the global variables
            updateGlobalVariables(estHandle);
            // set field weakening enable flag depending on user's input
            FW_setFlag_enableFw(fwHandle,gMotorVars.Flag_enableFieldWeakening);
            // set the speed acceleration
            TRAJ_setMaxDelta(trajHandle_spd,_IQmpy(MAX_ACCEL_KRPMPS_SF,gMotorVars.MaxAccel_krpmps));
            // enable/disable the forced angle
            EST_setFlag_enableForceAngle(estHandle,false);
            // enable or disable RsOnLine
            // set slow rotating frequency for RsOnLine
            // set current amplitude for RsOnLine
            // set flag that updates Rs from RsOnLine value
            // clear Id for RsOnLine if disabled
            if(!gFlag_enableRsOnLine) EST_setRsOnLineId_pu(estHandle,_IQ(0.0));
            //stall detect
            if(gMotorVars.Iq_A > _IQ(80.0)){
               //if (gMotorVars.speed_est_pu < _IQ(0.00001))//gMotorVars.Speed_krpm
                  // gMotorVars.Flag_enableSys=false;
            if(gMotorVars.Id_A > _IQ(50.0)){
                       //if (gMotorVars.speed_est_pu < _IQ(0.005))//gMotorVars.Speed_krpm
            if (gMotorVars.Iq_A < _IQ(10.0)){
              //if (gMotorVars.speed_est_pu > _IQ(0.80))
                //  gMotorVars.Flag_Run_Identify=false;
              //add delay and enable it after that
            if (gMotorVars.Iq_A > _IQ(40.0)){
              //if (gMotorVars.IqRef_A <= _IQ(0.0))
                   //gMotorVars.Flag_enableSys=false;
    #ifdef DRV8301_SPI
            HAL_writeDrvData(halHandle,&gDrvSpi8301Vars);
            HAL_readDrvData(halHandle,&gDrvSpi8301Vars);
    #endif
    #ifdef DRV8305_SPI
            HAL_writeDrvData(halHandle,&gDrvSpi8305Vars);
            HAL_readDrvData(halHandle,&gDrvSpi8305Vars);
    #endif
          } // end of while(gFlag_enableSys) loop
        // disable the PWM
        gMotorVars.Flag_Run_Identify = false;
      } // end of for(;;) loop
    } // end of main() function
    //! \brief     The main ISR that implements the motor control.
    interrupt void mainISR(void)
      // read the timer 1 value and update the CPU usage module
      uint32_t timer1Cnt = HAL_readTimerCnt(halHandle,2);
      CPU_TIME_updateCnts(cpu_timeHandle,timer1Cnt);
      _iq oneOverDcBus;
      MATH_vec2 Iab_pu;
      MATH_vec2 Vab_pu;
      MATH_vec2 phasor;
      // acknowledge the ADC interrupt
      HAL_acqAdcInt(halHandle,ADC_IntNumber_1);
      // convert the ADC data
      HAL_readAdcDataWithOffsets(halHandle,&gAdcData);
      // remove offsets
      gAdcData.I.value[0] = gAdcData.I.value[0] - gOffsets_I_pu.value[0];
      gAdcData.I.value[1] = gAdcData.I.value[1] - gOffsets_I_pu.value[1];
      gAdcData.I.value[2] = gAdcData.I.value[2] - gOffsets_I_pu.value[2];
      gAdcData.V.value[0] = gAdcData.V.value[0] - gOffsets_V_pu.value[0];
      gAdcData.V.value[1] = gAdcData.V.value[1] - gOffsets_V_pu.value[1];
      gAdcData.V.value[2] = gAdcData.V.value[2] - gOffsets_V_pu.value[2];
      // run the current reconstruction algorithm
      runCurrentReconstruction();
      // run Hall state check for startup and running
      HALLBLDC_State_Check();
      // run Clarke transform on current
      CLARKE_run(clarkeHandle_I,&gAdcData.I,&Iab_pu);
      // run Clarke transform on voltage
      CLARKE_run(clarkeHandle_V,&gAdcData.V,&Vab_pu);
      // run a trajectory for Id reference, so the reference changes with a ramp instead of a step
      TRAJ_run(trajHandle_Id);
      // run the estimator
      EST_run(estHandle,
              &Iab_pu,
              &Vab_pu,
              gAdcData.dcBus,
              TRAJ_getIntValue(trajHandle_spd));
      // generate the motor electrical angle
      angle_est_pu = EST_getAngle_pu(estHandle);
      speed_est_pu = EST_getFm_pu(estHandle);
      // get Idq from estimator to avoid sin and cos
      EST_getIdq_pu(estHandle,&gIdq_pu);
      // run the appropriate controller
      if((gMotorVars.Flag_Run_Identify) || (gMotorVars.Flag_enableRsRecalc))
          _iq refValue;
          _iq fbackValue;
          _iq outMax_pu;
          // when appropriate, run the PID speed controller
          if(FS_flag_enableSpeedCtrl == true)
          if(pidCntSpeed++ >= USER_NUM_CTRL_TICKS_PER_SPEED_TICK)
              // calculate Id reference squared
              _iq Id_ref_squared_pu = _IQmpy(PID_getRefValue(pidHandle[1]),PID_getRefValue(pidHandle[1]));
              // Take into consideration that Iq^2+Id^2 = Is^2
              _iq Iq_Max_pu = _IQsqrt(gIs_Max_squared_pu - Id_ref_squared_pu);
              // clear counter
              pidCntSpeed = 0;
              // Set new min and max for the speed controller output
              PID_setMinMax(pidHandle[0], -Iq_Max_pu, Iq_Max_pu);
              // run speed controller
              PID_run_spd(pidHandle[0],TRAJ_getIntValue(trajHandle_spd),speed_pu, &speed_pid_out);
              gIdq_ref_pu.value[1] = speed_pid_out;
          else
              gIdq_ref_pu.value[1] = FS_Iq_ref_pu;
          // get the reference value from the trajectory module
          refValue = TRAJ_getIntValue(trajHandle_Id) + EST_getRsOnLineId_pu(estHandle);
          // get the feedback value
          fbackValue = gIdq_pu.value[0];
          // run the Id PID controller
          PID_run(pidHandle[1],refValue,fbackValue,&(gVdq_out_pu.value[0]));
          // set Iq reference to zero when doing Rs recalculation
          if(gMotorVars.Flag_enableRsRecalc) gIdq_ref_pu.value[1] = _IQ(0.0);
          // get the Iq reference value
          refValue = gIdq_ref_pu.value[1];
          fbackValue = gIdq_pu.value[1];
          // calculate Iq controller limits, and run Iq controller
          _iq max_vs = _IQmpy(_IQ(USER_MAX_VS_MAG_PU),EST_getDcBus_pu(estHandle));
          outMax_pu = _IQsqrt(_IQmpy(max_vs,max_vs) - _IQmpy(gVdq_out_pu.value[0],gVdq_out_pu.value[0]));
          PID_setMinMax(pidHandle[2],-outMax_pu,outMax_pu);
          PID_run(pidHandle[2],refValue,fbackValue,&(gVdq_out_pu.value[1]));
          // compensate angle for PWM delay
          angle_est_pu = angleDelayComp(speed_est_pu, angle_est_pu);
          // compute the sin/cos phasor
          phasor.value[0] = _IQcosPU(angle_pu);
          phasor.value[1] = _IQsinPU(angle_pu);
          // set the phasor in the inverse Park transform
          IPARK_setPhasor(iparkHandle,&phasor);
          // run the inverse Park module
          IPARK_run(iparkHandle,&gVdq_out_pu,&Vab_pu);
          // run the space Vector Generator (SVGEN) module
          oneOverDcBus = EST_getOneOverDcBus_pu(estHandle);
          Vab_pu.value[0] = _IQmpy(Vab_pu.value[0],oneOverDcBus);
          Vab_pu.value[1] = _IQmpy(Vab_pu.value[1],oneOverDcBus);
          SVGEN_run(svgenHandle,&Vab_pu,&(gPwmData.Tabc));
          // run the PWM compensation and current ignore algorithm
          SVGENCURRENT_compPwmData(svgencurrentHandle,&(gPwmData.Tabc),&gPwmData_prev);
          // Run BLDC
          HALLBLDC_Ctrl_Run();
          // increase traj count
          gTrjCnt++;
      else if(gMotorVars.Flag_enableOffsetcalc == true)
          runOffsetsCalculation();
      else
          // disable the PWM
          // Set the PWMs to 50% duty cycle
          gPwmData.Tabc.value[0] = _IQ(0.0);
          gPwmData.Tabc.value[1] = _IQ(0.0);
          gPwmData.Tabc.value[2] = _IQ(0.0);
          HALLBLDC_Ctrl_Stop();
      // write the PWM compare values
      HAL_writePwmData(halHandle,&gPwmData);
      if(gTrjCnt >= gUserParams.numCtrlTicksPerTrajTick)
          // clear counter
          gTrjCnt = 0;
          // run a trajectory for speed reference, so the reference changes with a ramp instead of a step
          TRAJ_run(trajHandle_spd);
      // run function to set next trigger
      if(!gMotorVars.Flag_enableRsRecalc) runSetTrigger();
      // run field weakening
      if(USER_MOTOR_TYPE == MOTOR_Type_Pm) runFieldWeakening();
      gMotorVars.angle_est_pu = angle_pu;
      gMotorVars.speed_est_pu = speed_est_pu;
    #ifndef F2802xF
      // connect inputs of the PWMDAC module.
      gDacData.value[0] = gAdcData.I.value[0];
      gDacData.value[1] = gIdq_ref_pu.value[0];
      gDacData.value[2] = gMotorVars.speed_est_pu;
      gDacData.value[3] = gMotorVars.angle_est_pu;
      // run PwmDAC
      HAL_writeDacData(halHandle,&gDacData);
    #endif
      // read the timer 2 value and update the CPU usage module
      CPU_TIME_run(cpu_timeHandle,timer1Cnt);
      return;
    } // end of mainISR() function
    _iq angleDelayComp(const _iq fm_pu, const _iq angleUncomp_pu)
      _iq angleDelta_pu = _IQmpy(fm_pu,_IQ(USER_IQ_FULL_SCALE_FREQ_Hz/(USER_PWM_FREQ_kHz*1000.0)));
      _iq angleCompFactor = _IQ(1.0 + (float_t)USER_NUM_PWM_TICKS_PER_ISR_TICK * 0.5);
      _iq angleDeltaComp_pu = _IQmpy(angleDelta_pu, angleCompFactor);
      uint32_t angleMask = ((uint32_t)0xFFFFFFFF >> (32 - GLOBAL_Q));
      _iq angleComp_pu;
      _iq angleTmp_pu;
      // increment the angle
      angleTmp_pu = angleUncomp_pu + angleDeltaComp_pu;
      // mask the angle for wrap around
      // note: must account for the sign of the angle
      angleComp_pu = _IQabs(angleTmp_pu) & angleMask;
      // account for sign
      if(angleTmp_pu < _IQ(0.0))
          angleComp_pu = -angleComp_pu;
      return(angleComp_pu);
    } // end of angleDelayComp() function
    void runCurrentReconstruction(void)
      SVGENCURRENT_MeasureShunt_e measurableShuntThisCycle = SVGENCURRENT_getMode(svgencurrentHandle);
      SVGENCURRENT_RunRegenCurrent(svgencurrentHandle, (MATH_vec3 *)(gAdcData.I.value));
      gIavg.value[0] += (gAdcData.I.value[0] - gIavg.value[0])>>gIavg_shift;
      gIavg.value[1] += (gAdcData.I.value[1] - gIavg.value[1])>>gIavg_shift;
      gIavg.value[2] += (gAdcData.I.value[2] - gIavg.value[2])>>gIavg_shift;
      if(measurableShuntThisCycle > two_phase_measurable)
          gAdcData.I.value[0] = gIavg.value[0];
          gAdcData.I.value[1] = gIavg.value[1];
          gAdcData.I.value[2] = gIavg.value[2];
      return;
    } // end of runCurrentReconstruction() function
    void runSetTrigger(void)
      SVGENCURRENT_IgnoreShunt_e ignoreShuntNextCycle = SVGENCURRENT_getIgnoreShunt(svgencurrentHandle);
      SVGENCURRENT_VmidShunt_e midVolShunt = SVGENCURRENT_getVmid(svgencurrentHandle);
      // Set trigger point in the middle of the low side pulse
      HAL_setTrigger(halHandle,ignoreShuntNextCycle,midVolShunt);
      return;
    } // end of runSetTrigger() function
    void runFieldWeakening(void)
      if(FW_getFlag_enableFw(fwHandle) == true)
          FW_incCounter(fwHandle);
          if(FW_getCounter(fwHandle) > FW_getNumIsrTicksPerFwTick(fwHandle))
              _iq refValue;
              _iq fbackValue;
              refValue = gMotorVars.VsRef;
              fbackValue =_IQmpy(gMotorVars.Vs,EST_getOneOverDcBus_pu(estHandle));
              FW_run(fwHandle, refValue, fbackValue, &(gIdq_ref_pu.value[0]));
              gMotorVars.IdRef_A = _IQmpy(gIdq_ref_pu.value[0], _IQ(USER_IQ_FULL_SCALE_CURRENT_A));
      else
          gIdq_ref_pu.value[0] = _IQmpy(gMotorVars.IdRef_A, _IQ(1.0/USER_IQ_FULL_SCALE_CURRENT_A));
      return;
    } // end of runFieldWeakening() function
    void runOffsetsCalculation(void)
      uint16_t cnt;
      // enable the PWM
      for(cnt=0;cnt<3;cnt++)
          gPwmData.Tabc.value[cnt] = _IQ(0.0);
          // reset offsets used
          gOffsets_I_pu.value[cnt] = _IQ(0.0);
          gOffsets_V_pu.value[cnt] = _IQ(0.0);
          // run offset estimation
          FILTER_FO_run(filterHandle[cnt],gAdcData.I.value[cnt]);
          FILTER_FO_run(filterHandle[cnt+3],gAdcData.V.value[cnt]);
      if(gOffsetCalcCount++ >= gUserParams.ctrlWaitTime[CTRL_State_OffLine])
              // get calculated offsets from filter
              gOffsets_I_pu.value[cnt] = FILTER_FO_get_y1(filterHandle[cnt]);
              gOffsets_V_pu.value[cnt] = FILTER_FO_get_y1(filterHandle[cnt+3]);
              // clear filters
              FILTER_FO_setInitialConditions(filterHandle[cnt+3],_IQ(0.0),_IQ(0.0));
      return;
    } // end of runOffsetsCalculation() function
    void softwareUpdate1p6(EST_Handle handle)
      float_t fullScaleInductance = USER_IQ_FULL_SCALE_VOLTAGE_V/(USER_IQ_FULL_SCALE_CURRENT_A*USER_VOLTAGE_FILTER_POLE_rps);
      float_t Ls_coarse_max = _IQ30toF(EST_getLs_coarse_max_pu(handle));
      int_least8_t lShift = ceil(log(USER_MOTOR_Ls_d/(Ls_coarse_max*fullScaleInductance))/log(2.0));
      uint_least8_t Ls_qFmt = 30 - lShift;
      float_t L_max = fullScaleInductance * pow(2.0,lShift);
      _iq Ls_d_pu = _IQ30(USER_MOTOR_Ls_d / L_max);
      _iq Ls_q_pu = _IQ30(USER_MOTOR_Ls_q / L_max);
      // store the results
      EST_setLs_d_pu(handle,Ls_d_pu);
      EST_setLs_q_pu(handle,Ls_q_pu);
      EST_setLs_qFmt(handle,Ls_qFmt);
      return;
    } // end of softwareUpdate1p6() function
    //! \brief     Setup the Clarke transform for either 2 or 3 sensors.
    //! \param[in] handle             The clarke (CLARKE) handle
    //! \param[in] numCurrentSensors  The number of current sensors
    void setupClarke_I(CLARKE_Handle handle,const uint_least8_t numCurrentSensors)
      _iq alpha_sf,beta_sf;
      // initialize the Clarke transform module for current
      if(numCurrentSensors == 3)
          alpha_sf = _IQ(MATH_ONE_OVER_THREE);
          beta_sf = _IQ(MATH_ONE_OVER_SQRT_THREE);
      else if(numCurrentSensors == 2)
          alpha_sf = _IQ(1.0);
      else
          alpha_sf = _IQ(0.0);
          beta_sf = _IQ(0.0);
      // set the parameters
      CLARKE_setScaleFactors(handle,alpha_sf,beta_sf);
      CLARKE_setNumSensors(handle,numCurrentSensors);
      return;
    } // end of setupClarke_I() function
    //! \param[in] numVoltageSensors  The number of voltage sensors
    void setupClarke_V(CLARKE_Handle handle,const uint_least8_t numVoltageSensors)
      // initialize the Clarke transform module for voltage
      if(numVoltageSensors == 3)
     else
          beta_sf = _IQ(0.0);
      CLARKE_setNumSensors(handle,numVoltageSensors);
      return;
    } // end of setupClarke_V() function
    //! \brief     Update the global variables (gMotorVars).
    //! \param[in] handle  The estimator (EST) handle
    void updateGlobalVariables(EST_Handle handle)
      // get the speed estimate
      gMotorVars.Speed_krpm = EST_getSpeed_krpm(handle);
      // get the torque estimate
        _iq Flux_pu = EST_getFlux_pu(handle);
        _iq Id_pu = PID_getFbackValue(pidHandle[1]);
        _iq Iq_pu = PID_getFbackValue(pidHandle[2]);
        _iq Ld_minus_Lq_pu = _IQ30toIQ(EST_getLs_d_pu(handle)-EST_getLs_q_pu(handle));
        _iq Torque_Flux_Iq_Nm = _IQmpy(_IQmpy(Flux_pu,Iq_pu),gTorque_Flux_Iq_pu_to_Nm_sf);
        _iq Torque_Ls_Id_Iq_Nm = _IQmpy(_IQmpy(_IQmpy(Ld_minus_Lq_pu,Id_pu),Iq_pu),gTorque_Ls_Id_Iq_pu_to_Nm_sf);
        _iq Torque_Nm = Torque_Flux_Iq_Nm + Torque_Ls_Id_Iq_Nm;
        gMotorVars.Torque_Nm = Torque_Nm;
      // get the magnetizing current
      gMotorVars.MagnCurr_A = EST_getIdRated(handle);
      // get the rotor resistance
      gMotorVars.Rr_Ohm = EST_getRr_Ohm(handle);
      // get the stator resistance
      gMotorVars.Rs_Ohm = EST_getRs_Ohm(handle);
      // get the online stator resistance
      gMotorVars.RsOnLine_Ohm = EST_getRsOnLine_Ohm(handle);
      // get the stator inductance in the direct coordinate direction
      gMotorVars.Lsd_H = EST_getLs_d_H(handle);
      // get the stator inductance in the quadrature coordinate direction
      gMotorVars.Lsq_H = EST_getLs_q_H(handle);
      // get the flux in V/Hz in floating point
      gMotorVars.Flux_VpHz = EST_getFlux_VpHz(handle);
      // get the flux in Wb in fixed point
      gMotorVars.Flux_Wb = _IQmpy(EST_getFlux_pu(handle),gFlux_pu_to_Wb_sf);
      // get the estimator state
      gMotorVars.EstState = EST_getState(handle);
      // Get the DC buss voltage
      gMotorVars.VdcBus_kV = _IQmpy(gAdcData.dcBus,_IQ(USER_IQ_FULL_SCALE_VOLTAGE_V/1000.0));
      // read Vd and Vq vectors per units
      gMotorVars.Vd = gVdq_out_pu.value[0];
      gMotorVars.Vq = gVdq_out_pu.value[1];
      // calculate vector Vs in per units
      gMotorVars.Vs = _IQsqrt(_IQmpy(gMotorVars.Vd, gMotorVars.Vd) + _IQmpy(gMotorVars.Vq, gMotorVars.Vq));
      // read Id and Iq vectors in amps
      gMotorVars.Id_A = _IQmpy(gIdq_pu.value[0], _IQ(USER_IQ_FULL_SCALE_CURRENT_A));
      gMotorVars.Iq_A = _IQmpy(gIdq_pu.value[1], _IQ(USER_IQ_FULL_SCALE_CURRENT_A));
      // calculate vector Is in amps
      gMotorVars.Is_A = _IQsqrt(_IQmpy(gMotorVars.Id_A, gMotorVars.Id_A) + _IQmpy(gMotorVars.Iq_A, gMotorVars.Iq_A));
      return;
    } // end of updateGlobalVariables() function
    //! \brief
        if(gHall_Flag_EnableStartup == true)
            gHall_PwmState = gHall_PwmIndex[gHall_State];
            if(_IQabs(speed_est_pu)  < gHall_speed_FastToBldc_low_pu)   // FAST to Hall
              if(gHall_Flag_EnableBldc == false)
                  if(gHall_Bldc_Cnt > 20)
                    gHall_Bldc_Cnt = 0;
                    if(gHall_Flag_CurrentCtrl == true)      // Torque Control Mode
                        // The following instructions load the parameters for the speed PI
                        // controller.
                        PID_setGains(pidHandle[0],_IQ(0.1),_IQ(0.005),_IQ(0.0));
                        // Set the initial condition value for the integrator output to 0
                        PID_setUi(pidHandle[3], _IQmpy(pid[2].Ui, gFast2Hall_Ui_coef));
                    else        // Speed Control Mode
                        // controller.
                        gHall_PwmDuty = pid[2].Ui;
                        PID_setUi(pidHandle[0], _IQmpy(pid[2].Ui, gFast2Hall_Spd_coef));
                  else
                    gHall_Bldc_Cnt++;
            else if(_IQabs(gHall_speed_fdb_pu) > gHall_speed_BldcToFast_high_pu)            // Hall to FAST
              if(gHall_Flag_EnableBldc == true)
                  if(gHall_Fast_Cnt > 20)
                      gHall_Flag_EnableBldc = false;
                      gHall_Fast_Cnt = 0;
                          // controller.
                          PID_setGains(pidHandle[0],_IQ(2.0),_IQ(0.02),_IQ(0.0));
                          // Set the initial condition value for the integrator output to 0, Id
                          // Set the initial condition value for the integrator output to 0, Iq
                          PID_setUi(pidHandle[2], _IQmpy(pid[3].Ui, _IQ(0.25)));
                      else              // speed control
                          // controller.
                          // Set the initial condition value for the integrator output to 0, speed
                          PID_setUi(pidHandle[0], _IQmpy(gHall_PwmDuty, gHall2Fast_Spd_Coef));
                          PID_setUi(pidHandle[2], _IQmpy(gHall_PwmDuty, gHall2Fast_Iq_coef));
                          PID_setUi(pidHandle[1],_IQmpy(gHall_PwmDuty, _IQ(0.0)));
                      PWM_setSocAPulseSrc(hal.pwmHandle[PWM_Number_1],PWM_SocPulseSrc_CounterEqualZero);
                  else
                      gHall_Fast_Cnt++;
            if(gHall_Flag_EnableBldc)
                angle_pu = angle_est_pu;
                speed_pu = gHall_speed_fdb_pu;
                    gHall_BLDC_Is_fdb_pu = gAdcData.I.value[gHall_BLDC_Flag_Is_fdb];
                        gHall_BLDC_Is_ref_pu = speed_pid_out;
                    else
                        gHall_BLDC_Is_ref_pu = FS_Iq_ref_pu;
                    // BLDC current loop
                    PID_run(pidHandle[3],gHall_BLDC_Is_ref_pu,gHall_BLDC_Is_fdb_pu,&gHall_PwmDuty);
                    HALLBLDC_Ctrl_PwmSet(gHall_PwmState, gHall_PwmDuty);
                    gHall_PwmDuty = speed_pid_out;
            else
              speed_pu = speed_est_pu;
        else    //(gHall_Flag_EnableStartup == false)
        return;
    //! \brief
    // Hall_A, Hall_B, Hall_C
        gHall_GpioData  = (~HAL_readGpio(halHandle, (GPIO_Number_e)HAL_HallGpio_C) & 0x1) << 2;   //CAP1->J10/J4_1->green
        gHall_GpioData += (~HAL_readGpio(halHandle, (GPIO_Number_e)HAL_HallGpio_B) & 0x1) << 1;   //CAP2->J10/J4_2->green&white
        gHall_GpioData += (~HAL_readGpio(halHandle, (GPIO_Number_e)HAL_HallGpio_A) & 0x1);        //CAP3->J10/J4_3->gray&white
        gHall_State = gHall_GpioData;
        if(gHall_State != gHall_PrevState)
            gHall_timer_now = HAL_readTimerCnt(halHandle,2);
            gHall_time_delta_now = gHall_timer_prev - gHall_timer_now;
            gHall_timer_prev = gHall_timer_now;
            gHall_time_delta = (gHall_time_delta_now + gHall_time_delta_prev)>>1;
            gHall_time_delta_prev = gHall_time_delta_now;
            gHall_speed_fdb_0p01Hz = gHall_speed_scale/gHall_time_delta;
            gHall_speed_fdb_pu = gHall_speed_fdb_0p01Hz*gHall_Speed_0p01hz_to_pu_sf;
    //      if(TRAJ_getIntValue(trajHandle_spd) < _IQ(0.0))
    //          gHall_speed_fdb_pu = -gHall_speed_fdb_pu;
            //direction check
            gHall_State_delta = gHall_PwmIndex[gHall_State] - gHall_PwmIndex[gHall_PrevState];
            if((gHall_State_delta == -1) || (gHall_State_delta == 5))
                gHall_dir = 1;      // positive direction
            else if((gHall_State_delta == 1) || (gHall_State_delta == -5))
                gHall_dir = 2;      // negative direction
            else
                gHall_dir = 0;      // direction change
            //check if dirction is chagned.
            //if direction is changed, speed feedback is reset.
            if(gHall_dir != gHall_dir_prev)
                gHall_dir_change = 1;
            gHall_LastState = gHall_PrevState;
            gHall_PrevState = gHall_State;
            gHall_dir_prev = gHall_dir;
            gHall_Flag_State_Change = true;
            gHall_PwmCnt = 0;
        else
            gHall_PwmCnt++;
            if(gHall_PwmCnt > gHall_PwmCntMax)
                gHall_PwmCnt = 0;
        return;
    //! \brief
    //! \brief
      switch(PwmState)
        case 0:     // V+/W-
            PWM_setOneShotTrip(hal.pwmHandle[PWM_Number_1]);
            PWM_clearOneShotTrip(hal.pwmHandle[PWM_Number_2]);
            PWM_clearOneShotTrip(hal.pwmHandle[PWM_Number_3]);
            gPwmData.Tabc.value[1] = PwmDuty;
            gPwmData.Tabc.value[2] = -PwmDuty;
            gHall_BLDC_Flag_Is_fdb = 1;
            break;
        case 1:     // U+/W-
            PWM_clearOneShotTrip(hal.pwmHandle[PWM_Number_1]);
            PWM_setOneShotTrip(hal.pwmHandle[PWM_Number_2]);
            gPwmData.Tabc.value[0] = PwmDuty;
            break;
        case 2:     //U+/V-
            PWM_setOneShotTrip(hal.pwmHandle[PWM_Number_3]);
            gPwmData.Tabc.value[1] = -PwmDuty;
            break;
        case 3:     //W+/V-
            gPwmData.Tabc.value[2] = PwmDuty;
            gHall_BLDC_Flag_Is_fdb = 2;
            break;
        case 4:     //W+/U-
            gPwmData.Tabc.value[0] = -PwmDuty;
            break;
        case 5:     // V+/U-
            break;
        case 6:     // V+/W-
            break;
        default:    // N/A
            break;
    //@} //defgroup
    // end of file
    If you are using the drv8301-69m board, you must set JH_10 in hal.h and change the numbers of the hall pins:
    // select whether to use the hall input on connector J4 or J10 of the EVM
    //#define JH_J4
    #define JH_J10
    #ifdef JH_J4
    //! \brief Enumeration for the Hall GPIO numbers
    typedef enum
      HAL_HallGpio_A=GPIO_Number_20,  //!< GPIO pin number for Hall Sensor A
      HAL_HallGpio_B=GPIO_Number_21,  //!< GPIO pin number for Hall Sensor B
      HAL_HallGpio_C=GPIO_Number_23   //!< GPIO pin number for Hall Sensor C
    } HAL_HallGpio_e;
    #else
    typedef enum
      HAL_HallGpio_A=GPIO_Number_40,  //!< GPIO pin number for Hall Sensor A
      HAL_HallGpio_B=GPIO_Number_41,  //!< GPIO pin number for Hall Sensor B
      HAL_HallGpio_C=GPIO_Number_42   //!< GPIO pin number for Hall Sensor C
    } HAL_HallGpio_e;
    #endif
  • For lab11e, please check the steps as below
    1. The hall sensor is connected to the right interface which is defined in hal.h,
    2. The right commutation order is defined in gHall_PwmIndex[].
    3. Set gHall_speed_FastToBldc_low_pu and gHall_speed_BldcToFast_high_pu per the motor and system requirement.
    4. Set gFast2Hall_Spd_coef, gFast2Hall_Iq_coef and gFast2Hall_Ui_coef based on the motor running state.
    5. Set required control mode, set gHall_Flag_CurrentCtrl to false for speed close loop which is the default mode, set gHall_Flag_CurrentCtrl to true for torque control mode. Make sure the current is sampling correctly if you want to implement torque mode.
  • Hi Daniel,
    Thanks for your reply, you just saved the day!
    apparently i missed to consider the IqRef_A's value i tested with very low values and though it was not working but after observing your code i see my mistakes.. appreciate the help!
