TMS320F28379S: Watchdog Timer Reset on OSCCLK drop and WDCR
Part Number: TMS320F28379S
Have two questions about the internal Watchdog Timer function:
1. If the OSCCLK drops out, does the Watchdog Reset assert (WDRST)?
2. How is the Watchdog Configuration Register (WDCR) accessed and can it be accessed during runtime? In other words, is there a way for the processor to disable its own Watchdog Timer due to a malfunction or corrupted code?
Thanks.
  • Chad,
    Please check out the watchdog chapter (2.9), pg 113, in the F2837xS Technical Reference Manual (www.ti.com/.../spruhx5e.pdf). Section 2.9.3 explains more on the Watchdog Reset or Watchdog Interrupt Modes. Let me know if you have any other questions.
    Ozino
  • Ozino,
    Thanks for your response. Unfortunately the link you provided to the F2837xS Technical Reference Manual doesn't work.
    Chad
  • Hi Chad,
    No that would not cause reset. In that case WD counter will freeze.
    WDCR register is protected by EALLOW as well as WDCHK field (part of WDCR register) hence possibility of this is very-very remote.
    Vivek Singh
  • Also  you can find the document here,
    Vivek Singh
