Part Number: TMS320F28069M
After our last message conversation the problem did not ocuur for a certain period of time. But for one week it occurs again. I have read the document you advised.
When I check the TRSTn pin voltage it should be low during normal operation mode. It should be high at debugging configuration.
But in my case, during my debug attempts I cannot connect to the board if it is low, I can connect if it is high. Normally it should be high while connecting.
So the problem is TRSTn pin voltage. But why does it change during different attempts? There is a 2.2kohm pull down resistor at that pin as TI recommends in the hardware design guide
