Hi Team,
I face the same issue as what this E2E talking about, the platform is 28004x, when enable HR duty and HR period for EPWM1 and EPWM2, also set EPwm2Regs.TBCTL.bit.PHSEN = 1,
If set TBPRDHR = 0, the period of PWM2A will become stable, but if set TBPRDHR not equal to 0 , the period of PWM2A will become unstable, I post the code attached and can easily reproduce this issue.
what is suggestion about this to keep HR period stable without jitter?
// FILE: hrpwm_ex2_prdupdown_sfo_v8.c
// TITLE: HRPWM SFO V8 High-Resolution Period (Up-Down Count) example
//! \addtogroup bitfield_example_list
//! <h1>HRPWM Period Up-Down Count</h1>
//! This example modifies the MEP control registers to show edge displacement
//! for high-resolution period with ePWM in Up-Down count mode
//! due to the HRPWM control extension of the respective ePWM module.
//! This example calls the following TI's MEP Scale Factor Optimizer (SFO)
//! software library V8 functions:
//! \b int \b SFO(); \n
//! updates MEP_ScaleFactor dynamically when HRPWM is in use
//! updates HRMSTEP register (exists only in EPwm1Regs register space)
//! with MEP_ScaleFactor value
//! - returns 2 if error: MEP_ScaleFactor is greater than maximum value of 255
//! (Auto-conversion may not function properly under this condition)
//! - returns 1 when complete for the specified channel
//! - returns 0 if not complete for the specified channel
//! This example is intended to explain the HRPWM capabilities. The code can be
//! optimized for code efficiency. Refer to TI's Digital power application
//! examples and TI Digital Power Supply software libraries for details.
//! To run this example:
//! -# Run this example at maximum SYSCLKOUT
//! -# Activate Real time mode
//! -# Run the code
//! \b External \b Connections \n
//! - Monitor ePWM1 A/B pins on an oscilloscope.
//! \b Watch \b Variables \n
//! - UpdateFine - Set to 1 use HRPWM capabilities and observe in fine MEP
//! steps(default)
//! Set to 0 to disable HRPWM capabilities and observe in
//! coarse SYSCLKOUT cycle steps
// $TI Release: F28004x Support Library v1.05.00.00 $
// $Release Date: Thu Oct 18 15:43:57 CDT 2018 $
// $Copyright:
// Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "F28x_Project.h"
#include "SFO_V8.h"
// Defines
#define PWM_CH 3 // # of PWM channels - 1
#define STATUS_SUCCESS 1
#define STATUS_FAIL 0
// Globals
uint16_t UpdateFine, PeriodFine, status;
int MEP_ScaleFactor; // Global variable used by the SFO library
// Result can be used for all HRPWM channels
// This variable is also copied to HRMSTEP
// register by SFO(0) function.
// Used by SFO library (ePWM[0] is a dummy value that isn't used)
volatile struct EPWM_REGS *ePWM[PWM_CH] = {&EPwm1Regs, &EPwm1Regs,&EPwm2Regs};
// Function Prototypes
void initHRPWM1GPIO(void);
void configHRPWM(uint16_t period);
void error(void);
int HrDuty = 0;
int HrPeriod = 0;
int HrPhase = 0;
// Main
void main(void)
uint16_t i;
// Initialize device clock and peripherals
InitSysCtrl();
// Initialize GPIO
InitGpio();
initHRPWM1GPIO();
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
InitPieVectTable();
// Setup example variables
UpdateFine = 1;
PeriodFine = 0;
status = SFO_INCOMPLETE;
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
// ePWM and HRPWM register initialization
for(i=1; i<PWM_CH; i++)
// Change clock divider to /1
// (PWM clock needs to be > 60MHz)
(*ePWM[i]).TBCTL.bit.HSPCLKDIV = 0;
configHRPWM(50);
// Calling SFO() updates the HRMSTEP register with calibrated MEP_ScaleFactor.
// HRMSTEP must be populated with a scale factor value prior to enabling
// high resolution period control.
while(status == SFO_INCOMPLETE)
status = SFO();
if (status == SFO_ERROR)
error(); // SFO function returns 2 if an error occurs & # of MEP
} // steps/coarse step exceeds maximum of 255.
HrPhase = 22;
while(1)
EPwm1Regs.CMPA.bit.CMPAHR = HrDuty<< 8;
EPwm2Regs.CMPA.bit.CMPAHR= HrDuty<< 8;
EPwm1Regs.TBPRDHR = HrPeriod<< 8;
EPwm2Regs.TBPRDHR = HrPeriod<< 8;
EPwm1Regs.TBPHS.bit.TBPHSHR = HrPhase<< 8;
EPwm2Regs.TBPHS.bit.TBPHSHR = HrPhase<< 8;
for(;;)
// Sweep PeriodFine as a Q16 number from 0.2 - 0.999
for(PeriodFine = 0x3333; PeriodFine < 0xFFBF; PeriodFine++)
if(UpdateFine)
// Because auto-conversion is enabled, the desired
// fractional period must be written directly to the
// TBPRDHR (or TBPRDHRM) register in Q16 format
// (lower 8-bits are ignored)
// EPwm1Regs.TBPRDHR = PeriodFine;
// The hardware will automatically scale
// the fractional period by the MEP_ScaleFactor
// in the HRMSTEP register (which is updated
// by the SFO calibration software).
// Hardware conversion:
// MEP delay movement = ((TBPRDHR(15:0) >> 8) * HRMSTEP(7:0) +
// 0x80) >> 8
(*ePWM[i]).TBPRDHR = PeriodFine; //In Q16 format
else
// No high-resolution movement on TBPRDHR.
(*ePWM[i]).TBPRDHR = 0;
// Call the scale factor optimizer lib function SFO(0)
// periodically to track for any change due to temp/voltage.
// This function generates MEP_ScaleFactor by running the
// MEP calibration module in the HRPWM logic. This scale
// factor can be used for all HRPWM channels. HRMSTEP
// register is automatically updated by the SFO function.
status = SFO(); // in background, MEP calibration module
// continuously updates MEP_ScaleFactor
if(status == SFO_ERROR)
// MEP steps/coarse step exceeds maximum of 255.
} // end PeriodFine for loop
} // end infinite for loop
// configHRPWM - Configures all ePWM channels and sets up HRPWM
// on ePWMxA channels & ePWMxB channels
uint16_t j;
// ePWM channel register configuration with HRPWM
// ePWMxA toggle low/high with MEP control on Rising edge
EALLOW;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0; // Disable TBCLK within the EPWM
EDIS;
for(j=1; j<PWM_CH; j++)
(*ePWM[j]).TBCTL.bit.PRDLD = TB_SHADOW; // set Shadow load
(*ePWM[j]).TBPRD = period; // PWM frequency = 1/(2*TBPRD)
(*ePWM[j]).CMPA.bit.CMPA = period / 2; // set duty 50% initially
(*ePWM[j]).CMPA.bit.CMPAHR = (1 << 8); // initialize HRPWM extension
(*ePWM[j]).CMPB.bit.CMPB = period / 2; // set duty 50% initially
(*ePWM[j]).CMPB.all |= 1;
(*ePWM[j]).TBPHS.all = 0;
(*ePWM[j]).TBCTR = 0;
(*ePWM[j]).TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Select up-down
// count mode
(*ePWM[j]).TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;
(*ePWM[j]).TBCTL.bit.HSPCLKDIV = TB_DIV1;
(*ePWM[j]).TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT
(*ePWM[j]).TBCTL.bit.FREE_SOFT = 11;
(*ePWM[j]).CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // LOAD CMPA on CTR = 0
(*ePWM[j]).CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
(*ePWM[j]).CMPCTL.bit.SHDWAMODE = CC_SHADOW;
(*ePWM[j]).CMPCTL.bit.SHDWBMODE = CC_SHADOW;
(*ePWM[j]).AQCTLA.bit.CAU = AQ_SET; // PWM toggle high/low
(*ePWM[j]).AQCTLA.bit.CAD = AQ_CLEAR;
(*ePWM[j]).AQCTLB.bit.CBU = AQ_SET; // PWM toggle high/low
(*ePWM[j]).AQCTLB.bit.CBD = AQ_CLEAR;
EALLOW;
(*ePWM[j]).HRCNFG.all = 0x0;
(*ePWM[j]).HRCNFG.bit.EDGMODE = HR_BEP; // MEP control on
// both edges.
(*ePWM[j]).HRCNFG.bit.CTLMODE = HR_CMP; // CMPAHR and TBPRDHR
// HR control.
(*ePWM[j]).HRCNFG.bit.HRLOAD = HR_CTR_ZERO_PRD; // load on CTR = 0
// and CTR = TBPRD
(*ePWM[j]).HRCNFG.bit.EDGMODEB = HR_BEP; // MEP control on
// both edges
(*ePWM[j]).HRCNFG.bit.CTLMODEB = HR_CMP; // CMPBHR and TBPRDHR
// HR control
(*ePWM[j]).HRCNFG.bit.HRLOADB = HR_CTR_ZERO_PRD; // load on CTR = 0
// and CTR = TBPRD
(*ePWM[j]).HRCNFG.bit.AUTOCONV = 1; // Enable autoconversion for
// HR period
(*ePWM[j]).HRPCTL.bit.TBPHSHRLOADE = 1; // Enable TBPHSHR sync
// (required for updwn
// count HR control)
(*ePWM[j]).HRPCTL.bit.HRPE = 1; // Turn on high-resolution
// period control.
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1; // Enable TBCLK within
// the EPWM
(*ePWM[j]).TBCTL.bit.SWFSYNC = 1; // Synchronize high
// resolution phase to
// start HR period
EDIS;
EALLOW;
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE;
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
EDIS;
// initHRPWM1GPIO - Initialize HRPWM1 GPIOs
EALLOW;
// Disable internal pull-up for the selected output pins
// for reduced power consumption
// Pull-ups can be enabled or disabled by the user.
GpioCtrlRegs.GPAPUD.bit.GPIO0 = 1; // Disable pull-up on GPIO0 (EPWM1A)
GpioCtrlRegs.GPAPUD.bit.GPIO1 = 1; // Disable pull-up on GPIO1 (EPWM1B)
// Configure EPWM-1 pins using GPIO regs
// This specifies which of the possible GPIO pins will be EPWM1 functional
// pins.
GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1; // Configure GPIO0 as EPWM1A
GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1; // Configure GPIO1 as EPWM1B
GpioCtrlRegs.GPAPUD.bit.GPIO2 = 1; // Disable pull-up on GPIO0 (EPWM1A)
GpioCtrlRegs.GPAPUD.bit.GPIO3 = 1; // Disable pull-up on GPIO1 (EPWM1B)
// pins.
GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 1; // Configure GPIO0 as EPWM1A
GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 1; // Configure GPIO1 as EPWM1B
EDIS;
// error - Halt debugger when error occurs
void error (void)
ESTOP0; // Stop here and handle error
// End of file
https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/748317?TMS320F280049-HRPWM-period-control-jitter-in-up-count-mode&keyMatch=HRPWM period&tisearch=Search-EN-Everything
