Hi
I'm looking for SDFlash serial driver for piccolos F2803x.
SDFlash Serial v3.3 supports all F28xx except F2803x. Is there a newer version of this SDFlash serial package?
best regards
Andreas
Hi
best regards
Andreas
Quote,
I can't find such driver from Spectrum Digital website also, but you can link to codeskin website( http://www.codeskin.com/ ) to download c2prog s/w which has the same fuction as SDFlash serial.
Yanming
Yanming,
I know C2Prog of codeskin, but we want to 'costumize' the SDFlash serial driver.
Spectrum Digital told me that Texas Instruments builds and supports the serial flashing algorithms for SDFlash.
Best regards
Andreas
Andreas -
Texas Instruments stopped building serial flash algorithms for SDFlash after the Delfino devices. Due to many issues customers were having when using different PC environments and different hardware, it was decided that SDFlash serial is not a reliable serial programming interface. The recommended solution is codeskin C2kProg.
On the other hand, if you really must use SDFlash serial, it is possible to modify the algorithms for the 2803x yourself as described in the SDFlash Serial algo documentation. You will also need to download the 2803x Flash API and use the API .out file in conjunction with your new SDFlash serial algorithm.
Was Delfino before or after the Piccolo? I'd like to use SDFlash for the F28023 as we already use it for the F2801/F2802. Are there drivers available yet to do this?
