Part Number: TMS320F28377S
I have configured EMIF1 to access Dual Port RAM Asyn device. I am facing a problem with WP0 and MAX_EXT_WAIT.
Test 1: Configuration:
reg_EMIF1->ASYNC_WCCR.bit.WP0 = 1u;
reg_EMIF1->ASYNC_WCCR.bit.MAX_EXT_WAIT = 0x40u;
Problem: Even though i have reduced max ext wait time to 0x40, it always wait for 0x80 time period. i don't understand why?
Test 2: Configuration:
reg_EMIF1->ASYNC_WCCR.bit.WP0 = 0u;
Problem: Even though i have set WP0 set to 0u. When WP0 is set to 1, It starts to wait for 0x80 time period. i don't understand why?
For the above tests,
/* EMIF1 ASYNC CS2 Configuration*/
#define ASIZE_16 0x01u /* 16Bit Memory Interface */
#define POLARITY_HIGH 0x01u
#define EMIF_MAJOR_REVISION 0x02u
#define EMIF_MINOR_REVISION 0x05u
#define LITTLE_ENDIAN 0x00u
#define EMIF1_CLK_ENABLE 0x01u
#define TURN_AROUND_TIME 0x03u /* Turn Around time of 1 Emif Clock */
#define RD_SETUP_TIME 0x04u /* Read Setup time of 1 Emif Clock */
#define WR_SETUP_TIME 0x04u /* Write Hold time of 1 Emif Clock */
#define RD_STROBE_TIME 0x4u /* Read Strobe time of 1 Emif Clock */
#define WR_STROBE_TIME 0x4u /* Write Setup time of 1 Emif Clock */
#define RD_HOLD_TIME 0x07u /* Read Hold time of 1 Emif Clock */
#define WR_HOLD_TIME 0x07u /* Write Hold time of 1 Emif Clock */
#define ASYNC_EW_ENABLE 0x01u
#define ASYNC_SS_DISABLE 0x00u
reg_EMIF1->ASYNC_CS2_CR.bit.ASIZE = ASIZE_16;
reg_EMIF1->ASYNC_CS2_CR.bit.TA = TURN_AROUND_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.R_HOLD = RD_HOLD_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.R_STROBE = RD_STROBE_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.R_SETUP = RD_SETUP_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.W_HOLD = WR_HOLD_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.W_STROBE = WR_STROBE_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.W_SETUP = WR_SETUP_TIME;
reg_EMIF1->ASYNC_CS2_CR.bit.SS = ASYNC_SS_DISABLE;
reg_EMIF1->ASYNC_CS2_CR.bit.EW = ASYNC_EW_ENABLE;
Saravanan
