CCS/TMS320F280048: C2000Ware
Part Number: TMS320F280048
I tried installing the C2000Ware from the website. The installation was sucessfull and the file are present in their installed path (C/ti/ccs930). However, when trying to open a project (developped by a collegue and working on his computer), I get the following error: "Product c2000ware_software_package v2.1.0.00 is not currently installed and no compatible version is available. Please install this product or a compatible version."
The software package seems not to be recognised:
What I tried so far, but didn't work:
- install C2000Ware from website in different locations -> but not found by CCS
- install C2000Ware from the package manager directly in CCS -> couldn't install because of some permission issue (ERPM operation not permitted)
Thank you for your help,
Coline
  • Hi Coline,
    If the installation was successful, it should appear in installed products of CCS.
    Please go to menu Window -> Preferences. On the left panel, select Code Composer Studio -> Products.
    It will show Products Discovery Path and Installed Products on right panel.
  • Hi Santosh,
    My installation path was in the product discovery path but the C2000Ware was not shown in the installed products (even clicking refresh and reopening CCS).
    In the end, I found my problem: Windows had removed the '.' at the beginning of the folder metadata and metadata/tirex folder. I had to manually add it wia the command prompt as windows doesn"t allow us to do it in the file explorer to get the following path: .metadata/.tirex
    That done, CSS managed to find it in the Installed products window.
    Thank for your answer,
    Coline
