Part Number: TMS320F28379D
Other Parts Discussed in Thread: FLASH-PROGRAMMER, TMS320F28335, C2000WARE
I’m developing in Texas Instruments C2000 LaunchPadXL TMS320F28379D in version 2.0.
For a project, I need a bootloader without JTAG interface in a certified software.
I would like to download an applicative program in a flash sector.
Flash API (F021_API_F2837xD_C28x_FPU32.lib ) is a library to erase, program and verify flash.
Are code source of this library available and where can I find them ?
A second option is to use Flash Kernel B with serial_flash-programmer.exe and F021_api_F2837xD_C28x.lib.
Where I can find the code source of F2837xD_sci_flash_kernels_cpu01.out ?
I only found F2837xD_sci_flash_kernels_cpu01.txt
The last option I see is that writes a custom bootloader.
PWRITE function seems to be a good way to do this.
Where can I find an example with PWRITE, that writes a program in a flash sector, without Flash API ?
Thanks for your help.
Reference documents:
TMS320F2837xD Flash API, version 1.54 Reference Guide, spnu629a.pdf
TMS320C28x CPU and Instruction Set, spru43f.pdf (for PWRITE function)
Flash Programming Solution for the TMS320F28xxx DSCs, application report, SPRAAL3, August 2008
Serial Flash Programming of C2000 Microcontrollers, application Report, SPRABV4C, March 2014, Revised March 2019
Forum of Texas Instruments, TMS320F28335: Custom bootloader
F2837xD_fw_upgrade_example.txt in C2000Ware_2_01_00_00/utilities/flash_programmers/serial_flash_programmer
EEPROM Emulation With the TMS320F28xxx DSCs, Application Report, SPRAB69, September 2009
