Part Number: TMS320F28379D
Other Parts Discussed in Thread: C2000WARE, SYSCONFIG
I follow the CLB Tool Users Guide(SPRUIR8) to build the elb_empty project form C2000Ware, but errors occur. I don't understand why this happen?
My CCS Version is: 9.3.0.00012 , and use C2000WARE_v2.01.00.00. I verify my installation is good, and build others project without CLB successfully.
Problems as here
Description Resource Path Location Type
#10 "#" not expected here device.c /clb_empty/device line 1 C/C++ Problem
#10 "#" not expected here device.c /clb_empty/device line 3 C/C++ Problem
#10 "#" not expected here empty.c /clb_empty line 1 C/C++ Problem
#168 invalid floating constant empty.c /clb_empty line 1 C/C++ Problem
#171 expected a declaration empty.c /clb_empty line 3 C/C++ Problem
#19 extra text after expected end of number device.c /clb_empty/device line 1 C/C++ Problem
#19 extra text after expected end of number device.c /clb_empty/device line 3 C/C++ Problem
#19 extra text after expected end of number empty.c /clb_empty line 1 C/C++ Problem
#66 expected a ";" device.c /clb_empty/device line 1 C/C++ Problem
#66 expected a ";" empty.c /clb_empty line 1 C/C++ Problem
#7 unrecognized token device.c /clb_empty/device line 1 C/C++ Problem
#7 unrecognized token device.c /clb_empty/device line 2 C/C++ Problem
#7 unrecognized token device.c /clb_empty/device line 3 C/C++ Problem
#7 unrecognized token empty.c /clb_empty line 1 C/C++ Problem
#7 unrecognized token empty.c /clb_empty line 3 C/C++ Problem
#8 missing closing quote device.c /clb_empty/device line 1 C/C++ Problem
gmake: *** [device/device.obj] Error 1 clb_empty C/C++ Problem
gmake: *** [empty.obj] Error 1 clb_empty C/C++ Problem
gmake: Target 'all' not remade because of errors. clb_empty C/C++ Problem
#1-D last line of file ends without a newline empty.c /clb_empty line 3 C/C++ Problem
#1268-D null (zero) character in input line ignored device.c /clb_empty/device line 1 C/C++ Problem
#1268-D null (zero) character in input line ignored device.c /clb_empty/device line 2 C/C++ Problem
#1268-D null (zero) character in input line ignored empty.c /clb_empty line 1 C/C++ Problem
#78-D this declaration has no storage class or type specifier device.c /clb_empty/device line 1 C/C++ Problem
#78-D this declaration has no storage class or type specifier empty.c /clb_empty line 1 C/C++ Problem
And the console output as follow
**** Build of configuration Debug for project clb_empty ****
"D:\\ti\\ccs930\\ccs\\utils\\bin\\gmake" -k -j 4 all -O
Building file: "../empty.syscfg"
Invoking: SysConfig
"D:/ti/ccs930/ccs/utils/sysconfig/sysconfig_cli.bat" -d "F2837xD" -s "D:/ti/c2000/C2000Ware_2_01_00_00/utilities/clb_tool/clb_syscfg/.metadata/product.json" -o "syscfg" "../empty.syscfg"
Running script...
Validating...
Generating Code...
Writing F:\svn\DUC\DSP\TestCLB\clb_empty\Debug\syscfg\clb_config.h...
Writing F:\svn\DUC\DSP\TestCLB\clb_empty\Debug\syscfg\clb_config.c...
Writing F:\svn\DUC\DSP\TestCLB\clb_empty\Debug\syscfg\clb.dot...
Writing F:\svn\DUC\DSP\TestCLB\clb_empty\Debug\syscfg\clb_sim.cpp...
Finished building: "../empty.syscfg"
Building file: "../empty.c"
Invoking: C2000 Compiler
"D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 -Ooff --opt_for_speed=2 --fp_mode=strict --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/driverlib/f2837xd/driverlib" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/device_support/F2837xD/common/include" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/device" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/utilities/clb_tool/clb_syscfg/systemc/include" --include_path="D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/include" --define=CPU1 -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="empty.d_raw" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/Debug/syscfg" "../empty.c"
>> Compilation failure
subdir_rules.mk:9: recipe for target 'empty.obj' failed
Building file: "../device/device.c"
"D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 -Ooff --opt_for_speed=2 --fp_mode=strict --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/driverlib/f2837xd/driverlib" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/device_support/F2837xD/common/include" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/device" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/utilities/clb_tool/clb_syscfg/systemc/include" --include_path="D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/include" --define=CPU1 -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="device/device.d_raw" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/Debug/syscfg" --obj_directory="device" "../device/device.c"
>> Compilation failure
device/subdir_rules.mk:16: recipe for target 'device/device.obj' failed
"../empty.c", line 1: error #7: unrecognized token
"../empty.c", line 1: warning #78-D: this declaration has no storage class or type specifier
"../empty.c", line 1: error #66: expected a ";"
"../empty.c", line 1: error #10: "#" not expected here
"../empty.c", line 1: warning #1268-D: null (zero) character in input line ignored
"../empty.c", line 1: error #19: extra text after expected end of number
"../empty.c", line 1: error #168: invalid floating constant
"../empty.c", line 3: warning #1-D: last line of file ends without a newline
"../empty.c", line 3: error #7: unrecognized token
"../empty.c", line 3: error #171: expected a declaration
62 errors detected in the compilation of "../empty.c".
"../device/device.c", line 1: error #7: unrecognized token
"../device/device.c", line 1: warning #78-D: this declaration has no storage class or type specifier
"../device/device.c", line 1: error #66: expected a ";"
"../device/device.c", line 1: error #10: "#" not expected here
"../device/device.c", line 1: warning #1268-D: null (zero) character in input line ignored
"../device/device.c", line 1: error #19: extra text after expected end of number
"../device/device.c", line 1: error #8: missing closing quote
"../device/device.c", line 2: error #7: unrecognized token
"../device/device.c", line 2: warning #1268-D: null (zero) character in input line ignored
"../device/device.c", line 3: error #7: unrecognized token
"../device/device.c", line 3: error #10: "#" not expected here
"../device/device.c", line 3: error #19: extra text after expected end of number
Error limit reached.
100 errors detected in the compilation of "../device/device.c".
Compilation terminated.
Building file: "../device/F2837xD_CodeStartBranch.asm"
"D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 -Ooff --opt_for_speed=2 --fp_mode=strict --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/driverlib/f2837xd/driverlib" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/device_support/F2837xD/common/include" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/device" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/utilities/clb_tool/clb_syscfg/systemc/include" --include_path="D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/include" --define=CPU1 -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="device/F2837xD_CodeStartBranch.d_raw" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/Debug/syscfg" --obj_directory="device" "../device/F2837xD_CodeStartBranch.asm"
Finished building: "../device/F2837xD_CodeStartBranch.asm"
Building file: "syscfg/clb_sim.cpp"
"D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 -Ooff --opt_for_speed=2 --fp_mode=strict --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/driverlib/f2837xd/driverlib" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/device_support/F2837xD/common/include" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/device" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/utilities/clb_tool/clb_syscfg/systemc/include" --include_path="D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/include" --define=CPU1 -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="syscfg/clb_sim.d_raw" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/Debug/syscfg" --obj_directory="syscfg" "syscfg/clb_sim.cpp"
Finished building: "syscfg/clb_sim.cpp"
Building file: "syscfg/clb_config.c"
"D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 -Ooff --opt_for_speed=2 --fp_mode=strict --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/driverlib/f2837xd/driverlib" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/device_support/F2837xD/common/include" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/device" --include_path="D:/ti/c2000/C2000Ware_2_01_00_00/utilities/clb_tool/clb_syscfg/systemc/include" --include_path="D:/ti/ccs930/ccs/tools/compiler/ti-cgt-c2000_18.12.4.LTS/include" --define=CPU1 -g --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="syscfg/clb_config.d_raw" --include_path="F:/svn/DUC/DSP/TestCLB/clb_empty/Debug/syscfg" --obj_directory="syscfg" "syscfg/clb_config.c"
Finished building: "syscfg/clb_config.c"
**** Build Finished ****
